if you set your clock back to the proper date it should load...
note: you need to set it back to the same date the clock was set when you instaleld Centrafuse... Otherwise uninstall Centrafuse, manually delete the directory Centrafuse was installed in, fix your machines date problems, re-install Centrafuse and the license should work again...
david
LinkBack URL
About LinkBacks
