Page 11 of 17 FirstFirst ... 234567891011121314151617 LastLast
Results 101 to 110 of 163
Thread: Centrafuse 1.5 Bugs
  1. #101
    Maximum Bitrate kbyrd's Avatar
    Nov 2003
    Northern Arizona
    not reading track number?
    This may be pilot error:
    What does the "track sorting" do? Off or On doesn't appear to sort my tracks in album order. I know the id3 tags have track numbers in them. I wonder if CF isn't reading my track numbers right? Their in the form of: "01/13" or "3/11". That is, 3rd track our of 11.
    As I said, might be a bug, might be me.
    My worklog.
    Status: VM GTI sold, got out of the CarPC tinkering hobby, but I still think about getting back in.
  2. #102
    VENDOR - Centrafuse veetid's Avatar
    Quote Originally Posted by kbyrd
    yeah... I assume the track numbers are integers so I can actually sort on them with my SQL query... since you are using strings, that option will change nothing...
    david
  3. #103
    Nov 2003
    Northern Arizona
    Quote Originally Posted by veetid
    david
    It's a common enough format, I think iTunes tagged songs does the same thing. you could do an atoi on the string before sticking in the DB table, it'll stop at the "/" or whatever.
    My worklog.
  4. #104
    I will add it in....
    david
  5. #105
    Nov 2003
    Northern Arizona
    You know, I could help bug squash if you want (not that you would accept the help, but it would get a 1.6 in my hands faster.
    My worklog.
  6. #106
    Variable Bitrate bns2000's Avatar
    Nov 2004
    Russellville, AR
    I found another problem some areas of the program text on buttons are way off the destinator proram the buttons on top of the program go off the screen so i cant use them and like when i go to to GPS settings the text isnt even on the buttons I will take screen shots later. My CarPC is 640x480 by the way
    CENTRAFUSE™ From Flux Media
    The Ultimate Infotainment Interface
    Download V1.20 from there site now!!!!
    Download the new 2.0 RC1 From here Linky
  7. #107
    Newbie sailcat's Avatar
    May 2004
    The Netherlands
    Quote Originally Posted by tj!2k4
    Destinator 3 issue:
    I'm using Xport3 to split the GPS COM3 to three ports: COM14, COM15, COM16, however the D3 plugin only lists the physical COM1 and the GPS COM3.. the higher ports aren't available.
    I'll play around with this some more, might be something on my end though. Have any other Xport3 users come across this?
    Use a hexeditor to edit destinator.ini and put in the desired comport.
    Epia M10000 512Mb 80GB, Xenarc 7", Holux GM-210, still doing the Destinator vs. iGuidance challenge in europe.....
    SAILCAT
  8. #108
    Raw Wave tj!2k4's Avatar
    Oct 2004
    Quote Originally Posted by sailcat
    Thanks, will give it a shot..
  9. #109
    Jul 2005
    Sweden
    Reproducible:
    * Add a folder to your video paths
    * Click - (minus)
    * msgbox with the text "are you sure you want to remove this folder from your music path" (or something like that)
  10. #110
    Variable Bitrate lazy_g's Avatar
    May 2005
    Netherlands (Bergen (NH))
    Use GpsGate....
    does the same as Xport, but does work with the plug-in! (after reboot)
    www.superchargedmiata.net - all about roadster lifestyle
  1. New Release Centrafuse 1.20
    By veetid in forum Centrafuse
    Last Post: 10-10-2007, 07:12 PM
  2. Centrafuse SDK Information
    By veetid in forum CF SDK
    Last Post: 11-03-2005, 03:18 AM
  3. New Release Centrafuse 1.5
    Last Post: 11-02-2005, 12:48 PM
  4. Centrafuse 1.4 Bugs
    By veetid in forum CF Bug Reports
    Last Post: 09-27-2005, 09:58 PM
  5. Centrafuse 1.3 Bugs
    By rickster in forum CF Bug Reports
    Last Post: 07-26-2005, 07:51 PM
