YesOriginally Posted by veetid
These bugs seem to be associated only with single click mode on
Same here. Also, it doesn't seem to accept keyboard inputs on a web page. If, for example, I go to google, type something in the search box and hit enter nothing happens.Originally Posted by OoNikFraleyoO
I've noticed when useing the hotkeys excessivly for changing volume, the centrafuse display will freeze. Music continues to play and CF can still be controlled by hotkeys, but the screen will not refresh. I wish i could get more info on this, but it doesn't error out so i have to error log to offer.
Other than this, it seems to be quite stable. I still have some issues with skinbedder embedding iGuidance correctly but i may just have to edit the config file.
I really like the change to the volume control. I run the carputer strait to an amp, no headunit, and the volume curve is way better now. The only issue is the volume % meter, but to offer a suggestion, I'd rather have a meter bar* like this:
and have it light up the squares as to what the volume percentage is.
The text that shows volume percentage is too small to read and determine the digits at a glance even on an 8" LCD.
Keep up the good work David!
#1. Almost nothing will embed anymore. This is a complete regression from the last release. iGuidance and Explorer specifically refuse to embed.
#2. It's possible to run two instances of Centrafuse at the same time. Very annoying. This can very easily be fixed with the CreateMutex() named mutex technique mentioned in a billion Visual Studio samples.
#3. Now that I can't use iGuidance anymore because of the embed issue (the GPS plugin issue can be worked around by renaming a dummy file over the .dll name), I need Destinator maps now. Which version of Destinator do I need to buy to get these? And no I can't wait until the final release - you shouldn't have killed iGuidance with these bugs.
Yeah, lack of iGuidance totally turned me off, I didn't spend more time with 1.5. I will wait for 1.6 to see if things get better.
2002 Honda CR-V
Spent so far: $1105.90
...or even Listen to my music
I have both embeded fine. I do iGuidance through iGmod though. But explorer embeds just fine. I also don't have the GPS problems that some are having. My BU-303 works fine in iGmod even with the destinator plugin loaded. My only complaint about embedding has already been addressed (the header being optional)Originally Posted by Merzbow
David,
I have noticed 3 times already that when adding a new external app, it requires me to quit/restart CF in order to see it in the available options under the "Set Actions' section. I think this is easily reproducible.
2002 Honda CR-V
My Install
Software:
CFiG v1
iGuidance Plugin for CF
CarShell
Working shell for a CarPC
StopWatch
StopWatch plugin remade for centrafuse RC1
Alti! what version of iG are you using?
replicant
Audi A4 (flickr pics)
you guys are lame... IG will be fazed out becuase of the new destinator that is comming out. There is no way in IG to adjust volume there are many ways with in Destinator. Sure some of the maps aren't the greatest in Destinator right now but the next release which is soon will be much better. I would just say drop the whole IG deal........
2005 Ford Mustang GT <- - - UPDATED PICTURES
2003 KAWASAKI Z1000 - CUSTOM MODZ
MBK (AIM = IllMBKllI)
