Page 15 of 17 FirstFirst ... 567891011121314151617 LastLast
Results 141 to 150 of 163
Thread: Centrafuse 1.5 Bugs
  1. #141
    MySQL Error jcdillin's Avatar
    May 2003
    Miami, FL
    it's full of this
    11/14/2005 7:05:48 PM
    Object reference not set to an instance of an object.
    at centrafuse.id3reader.readFile(String filename)
    Key cannot be null.
    Parameter name: key
    at System.Collections.Hashtable.ContainsKey(Object key)
    at centrafuse.config.readTag(Int32 stream, String whichtag, String filename)
    Key cannot be null.
    Parameter name: key
    肚子笑痛了
    S60 Install
  2. #142
    VENDOR - Centrafuse veetid's Avatar
    Quote Originally Posted by jcdillin
    it's full of this
    I will check it out... not sure... have you ever loaded this music with 1.5 and had it work?
    david
  3. #143
    May 2003
    Miami, FL
    yup, worked perfectly before I reloaded
    肚子笑痛了
    S60 Install
  4. #144
    May 2003
    Miami, FL
    ok this is extremely strange, I finally got fed up with it and just installed frodoplayer, installed the computer in the car, been driving it all week. I got bored sitting in traffic last night and decided to try building the library again, and of course it worked perfectly.
    肚子笑痛了
    S60 Install
  5. #145
    Oct 2004
    NY
    I have a problem... when I first loaded cf my music & video files were on a drive labeled as E:..... I built the library.... took forever with 500 gigs... then tagged a whole bunch as favorites & playlists.....
    a week later I get around to installing my slot load dvd.... this makes my former E: drive now become my F: drive.... I didn't bother to re map the drive back to E:, I changed the paths & rebuilt the library but after that my playlists & favorites no longer worked... I spent some time re setting some up...
    now, a week later all of a sudden cf doesn't play... all my songs are there(or is it the previous saved library that I'm seeing?) but none will play... when I check the music path it is now back to E:!!!
    I just now changed the paths back to F: & am rebuilding the library again as I type.... I'm hoping since the playlists were built from F: they'll still work .....I'll know soon enough...
    my question is is there any dependancy of any of the settings that are associated with the skins... I think this problem happened after reloading an earlier skin back into cf.... (perhaps the skin that I used to originally set the path to E:?)
    I'm really doubting this is possible, probably just a coincidence... I didn't see any entrys for it in the skin xml's
    is there a way to save playlists that won't be lost.... if I add another hardrive could I run into this again?
    any idea about this???
  6. #146
    Oct 2004
    NY
    playlists don't work after rebuilding the library again.....
  7. #147
    Quote Originally Posted by turbocad6
    the playlists are simply a list of filepaths... if the filepaths are valid, they will work... manually open the .mpl files in the playlists directory and see what files they are pointing to and if they exist...
    david
  8. #148
    May 2004
    CD/DVD can eject
    Anyone having the same prob? The Cd/Dvd drive cannot eject if it is empty. Even when loaded, it takes forever to eject, unlike 1.4
  9. #149
    Low Bitrate DoubleC's Avatar
    Nov 2005
    ATX
    When connecting with my bluetooth setup CF will freeze while trying to connect for a good 1:30. 1.4 never really had any issue like this. I had a script running for 1.4 that would auto connect when windows loaded but now if I use that for 1.5 will stall at the load screen and get me for the minute and a half there.
    On the Weather plugin I can only get the big current forecast the 3 day on the bottom is always empty not really a big deal just wondering if it is just me.
    Quick playlist don't remain after hibernation it will keep 1 but the rest vanish.
    Lots of freezing and general slowness when saving settings mostly. I also get some stuttering for ~5 seconds of so during music/video playback
    I will post logs if it ever makes em.
    Running it on 2 systems
    Home machine - 3.4 P4 1Gig of ram XP Pro
    Car system- Sempron 3200+ 512MB ram XP Pro
  10. #150
    Lum
    Lum is offline
    Variable Bitrate Lum's Avatar
    Jan 2005
    Liverpool, England
    Blank screen after hibernate
    Searched this thread but couldn't find this fault already.
    If you set your PC to hibernate on a press of the power switch, then do this with CentraFuse running. The next time you start the system, you will get a blank screen and the only way to get out of it is to press one of the side buttons to change screen, then everything is redrawn and it works fine.
    I have tried this with the startup screen set to Media, Home and Previous
  1. New Release Centrafuse 1.20
    By veetid in forum Centrafuse
    Last Post: 10-10-2007, 08:12 PM
  2. Centrafuse SDK Information
    By veetid in forum CF SDK
    Last Post: 11-03-2005, 04:18 AM
  3. New Release Centrafuse 1.5
    Last Post: 11-02-2005, 01:48 PM
  4. Centrafuse 1.4 Bugs
    By veetid in forum CF Bug Reports
    Last Post: 09-27-2005, 10:58 PM
  5. Centrafuse 1.3 Bugs
    By rickster in forum CF Bug Reports
    Last Post: 07-26-2005, 08:51 PM
