Page 3 of 17 FirstFirst 12345678910111213 ... LastLast
Results 21 to 30 of 163
Thread: Centrafuse 1.5 Bugs
  1. #21
    Maximum Bitrate P3rv3rt B3ar's Avatar
    Jul 2005
    Funland
    Quote Originally Posted by Rafster
    Just reinstall. It's my 5th time uninstalling and reinstalling.
    Peace,
    Rafster
    Oh my god!! thanx for doing good work to replace scouses avatar :P :P :P
  2. #22
    FLAC alti's Avatar
    NY
    shutdown and restart dont work either with centrafuse set as shell or with explorer as shell
    hibernate and standby do.
    My Install
    Software:
    CFiG v1
    iGuidance Plugin for CF
    CarShell
    Working shell for a CarPC
    StopWatch
    StopWatch plugin remade for centrafuse RC1
  3. #23
    The Lavender Tie Just
    Made It Obvious
    Rafster's Avatar
    Aug 2003
    San Diego, CA
    Quote Originally Posted by P3rv3rt B3ar
    MAN, People REALLY like this new avatar.
    Hehe, my classmates were complaining that they had nothing to oggle at anymore during class. So, I figured I'd replace mine with something nice.
    Actually, Scouse helpedf me resize this thing so that it would fit as an avatar.
    Peace,
    Rafster
  4. #24
    FLAC alti's Avatar
    NY
    I have it working as a shell (execpt that i cannot shut it down or restart)
    ... snip
    I see that you have the anti-lag code in, works well.
    My Install
    Software:
    CFiG v1
    CarShell
    StopWatch
  5. #25
    Banned xdjxklusivex's Avatar
    Dec 2004
    Diamond Bar, CA (909,951)
    Quote Originally Posted by Mbai2
    I think I figured out what is causing this. CF is trying to read the old license file and it crashes. Just delete the license file from the program directory (centrafuse.exe.license.xxxxxx) and reopen CF. It will then ask you to register. Enter the new serial number and everything starts working.
    u were right :-) works now
  6. #26
    Variable Bitrate lazy_g's Avatar
    May 2005
    Netherlands (Bergen (NH))
    The sound quality with me is better in 1.4 then in 1.5....
    www.superchargedmiata.net - all about roadster lifestyle
  7. #27
    FLAC aoLhaTer's Avatar
    Mar 2003
    Rohnert Park, CA
    Using the GPS to add a POI desination seems to cause some real problems
    After adding a destination I get a gray screen that says "Static"
  8. #28
    Zerach's Avatar
    Jul 2005
    Bugs Bugs Bugs
    First Bug, also in V1.4:
    When having both fullscreen mode and always on top set to on and in an evaluation mode. The evaluation splash screen is not visible...seemingly locked up, press ALT-T (same as clicking try button) and CF starts
    Second Bug, Video Path in Settings
    1) click on the +
    2) try to add a directory with spaces i.e. C:\Music Videos
    3) Click Ok
    List is empty and sometimes it's hard to get back to the main settings screen (complains, locks up etc)
    This also happens in the plugins weather location screen.
    Third bug, in mixer using volume controls
    1) Go to the mixer
    2) fool around with volume up and volume down in the lower left corner (not the mixer controls)
    Seems to have weird things happen, volume goes up and down, sound levels go out of the expected levels. USB locked up at one point similar experience to previous poster (can't remember who)
    I also had the display mode mess up button arragements etc in 600x480 mode. switched to 800x600 and all is layed out correctly.
    Complaints:
    Rebuild library task - shows song names rather than song count, personally I much prefered seeing a number, at least I could ballpark around when it would be complete, I wouldn't mind song names if I had a progress bar or some other indication of when this would be done.
    General Sound quality - I'm not sure if it's the fact that the mixer and volume levels seem REALLY low or if it's just I haven't fiddled enough with it, but sound quality seems to have taken a big dive. The sound sounds distorted and not clear, the controls and EQ do not seem to work as well as 1.4 did, I would go as far as saying the mixer controls make it sound worse, I couldn't get my ears to agree with the settings (hard to explain) but with 1.4 I knew exactly how the EQ tuning controls would sound like...like tuning a guitar. With 1.5, what I hear coming out of the speakers in conjunction with adjusting the controls just doesn't work right.
    Strike the thing about sound quality it was as settings issue with the mixer and my big fingers, when I upped a few EQ bands it maked out the levels and made the sounds staticy and choppy, put them down to a reasonable level and all is good, some other bugs in sound volume stoped it from going loud enough and the PRE was low fixed that. So my comments were premature and I didn't fiddle enough, sound quality is just as good as 1.4.
    some of the features look promising but I haven't played around with it enough to find the new things useful.
    I noted that some of the hotspots are off which I compensated for with my fingers...
  9. #29
    VENDOR - Centrafuse veetid's Avatar
    Quote Originally Posted by justintime
    Not sure if a bug or not, but If you are listening to an album, and click the header, you get the Quick Album dialog. Howerver, there seems to be no way to load a full album from this screen. (you can only load a single track!).
    Is this by design?
    highlight the album in the quick library and it will load the entire album...
    david
  10. #30
    Quote Originally Posted by alti
    I cannot enter in location in the car for the web plugin
    singleclick mode
    went to plugins
    choose weather
    clicked on location
    osk came up, entered in zip and CF froze for 3 -4 minutes then went back to the setup weather plugin screen sith nothing entered for location
    I then changed to double click mode
    closed and reopened CF
    tried to enter in a location and this time there was not delay but nothing gets entered in to the location field after pressing enter on the OSK
    it appears to be timing out searching for your location... try something more general... try typing less information about your location... no commas or anything...
    david
  1. New Release Centrafuse 1.20
    By veetid in forum Centrafuse
    Last Post: 10-10-2007, 08:12 PM
  2. Centrafuse SDK Information
    By veetid in forum CF SDK
    Last Post: 11-03-2005, 04:18 AM
  3. New Release Centrafuse 1.5
    Last Post: 11-02-2005, 01:48 PM
  4. Centrafuse 1.4 Bugs
    By veetid in forum CF Bug Reports
    Last Post: 09-27-2005, 10:58 PM
  5. Centrafuse 1.3 Bugs
    By rickster in forum CF Bug Reports
    Last Post: 07-26-2005, 08:51 PM
