Page 5 of 17 FirstFirst 123456789101112131415 ... LastLast
Results 41 to 50 of 163
Thread: Centrafuse 1.5 Bugs
  1. #41
    Feb 2005
    Quote Originally Posted by veetid
    download again... this was happening in the version people downloaded before it was ready for release and I made my post...
    david
    I didn't download the earlier version. The new version is what I am using. I was experimenting with the bug more today and realized that if I played a DVD, subsequent DVD requests with an empty drive would work fine. It only freezes if the initial DVD request is done without a DVD inserted.
  2. #42
    Aug 1999
    Birmingham, Alabama (War Eagle!)
    Quote Originally Posted by alti
    My volume also only goes down to 30% at 30% it is equivelent to 0% percent volume. but i only have in the range of 30-100 to move it.
    Alti, below is what David posted when I asked this question:
    It's logarithmic volume control... it gives much better controll than the windows linear one... move the slider around the bottom in windows and see how much the volume changes... then move the slider in the top range and notice there is pretty much no change... I now change the volume based on decibels, like professional audio equipment....
    iTunes implemented it in their latest version... don't compare based on looking at the windows slider, which is linear and wrong for audio, but listen with your ears... you will notice that it's a perfect audible transition all the way up the scale now...
    david
  3. #43
    FLAC alti's Avatar
    NY
    Quote Originally Posted by defsquad
    david
    right, but is it supposed to start @ 30%? why not 0?
    My Install
    Software:
    CFiG v1
    iGuidance Plugin for CF
    CarShell
    Working shell for a CarPC
    StopWatch
    StopWatch plugin remade for centrafuse RC1
  4. #44
    Maximum Bitrate kbyrd's Avatar
    Nov 2003
    Northern Arizona
    Problems with ID3 tags.
    Several of my songs don't display right. It's much better than 1.4's crazy characters. In 1.5, I get the name for album, artist, and track title, but there is garbage at the end of the string. Maybe a buffer overrun? I'm not sure, but this may be on files that have ID3 v1 and v2 tags in them.
    My worklog.
    Status: VM GTI sold, got out of the CarPC tinkering hobby, but I still think about getting back in.
  5. #45
    Oct 2005
    Poland -> Mi, USA
    the volume indicator goes down form 100% -99% - 98% -...-70% and then immediatly to 40%
    and when i press the mute button i centrafuse it lights on green and i click it one more time and the green light does not turn off (sometimes it does - once turns off and 7 times it doesn't)
    does this happen to anybody else??
    Dhaark
  6. #46
    Constant Bitrate urosbe's Avatar
    Mar 2005
    Quote Originally Posted by Dhaark
    Dhaark
    I have exactly the same problems (buttons stay "clicked"-green colored).
    I control the volume with Powermate and I have to say "older" way was better to me. In my opinion, the best for all would be that it is possible to enabe/disable "logaritmic function".
    And something strange is also happening to me. When I go from Media to anywhere (Mixer, Apps, DVD...) when I return back to Media, volume always resets to 30% (minimum).
  7. #47
    The Lavender Tie Just
    Made It Obvious
    Rafster's Avatar
    Aug 2003
    San Diego, CA
    error.log file will help... you can email to support@fluxmedia.net if you don't want to post...
    david
    Hi,
    A solution to the problem was found. All you have to do is delete the registration file from the directory. CF will then ask you to register the software again, and all works.
    Thanks,
    Rafster
  8. #48
    VENDOR - Centrafuse veetid's Avatar
    it doesn't start at 30%... that is just where you stop being able to hear....
    my high end denon receiver goes from 0 to -70dB, which is what I wrote into Centrafuse... the ear can't hear much below -50db, so it appears to be at 0 at 30%...
    same as all high end audio equipment....
    david
  9. #49
    Nov 2003
    Northern Arizona
    I think what he's saying is that the display never goes below 30%. Mine is the same.
    My worklog.
  10. #50
    Oct 2005
    Poland -> Mi, USA
    my volume stat goes from 100% to 30% never below like kbyrd's.
    I think urosbe is trying to say that when he jumps from media to anywhere (Mixer, Apps, DVD...) when he returns to media the volume is on 30% and when he left it was higher.
    the volume does not go below 30%(2) asmentioned on top of post and the mute button is green but i can hear sound and the "mute" word (1) is off so the sound is on.
    I think you will know what i mean.
  1. New Release Centrafuse 1.20
    By veetid in forum Centrafuse
    Last Post: 10-10-2007, 08:12 PM
  2. Centrafuse SDK Information
    By veetid in forum CF SDK
    Last Post: 11-03-2005, 04:18 AM
  3. New Release Centrafuse 1.5
    Last Post: 11-02-2005, 01:48 PM
  4. Centrafuse 1.4 Bugs
    By veetid in forum CF Bug Reports
    Last Post: 09-27-2005, 10:58 PM
  5. Centrafuse 1.3 Bugs
    By rickster in forum CF Bug Reports
    Last Post: 07-26-2005, 08:51 PM
