Page 7 of 17 FirstFirst 12345678910111213141516 ... LastLast
Results 61 to 70 of 163
Thread: Centrafuse 1.5 Bugs
  1. #61
    Maximum Bitrate Frankino's Avatar
    Nov 2004
    Italy
    at 800*600 in embedded apps the keyboard - close - maximize buttons are messed up
    Peugeot 206 1.4 HDi
    Intel Mini-ITX Mainboard
    Celeron 1.2ghz
    256mb DDR-2 533
    80gig 3.5" SATA HDD
    Sb Live 5.1 w/ KXProject Drivers
    M2-ATX
    8" Lilliput TS LCD
    100% installed and working :D
  2. #62
    Raw Wave tj!2k4's Avatar
    Oct 2004
    Just a tip for those weary to replace 1.4 on their systems:
    Don't uninstall 1.4 and just make sure you select a different install directory for 1.5 (e.g. C:\Program Files\Flux Media\Centrafuse 1.5) when you install 1.5.
    This will give you the ability to beta test the latest version, but retain the stability of 1.4.
  3. #63
    Raw Wave justintime's Avatar
    Apr 2005
    Pause icon switches over
    Description: Pause icon siwtches from one image to another under certain conditions
    Reproduce:
    1)Start playing a song, and go to HOME.
    2) While in HOME, press the Pause button
    3) Switch to MEDIA
    4) Pause button has now refreshed... and displays the 'other' image.
    2002 Honda CR-V
    Spent so far: $1105.90
    ...or even Listen to my music
  4. #64
    Apr 2005
    Scrolling text doesn't always 'blank' before refresh
    scrolling main title clears before it displays truncated text
    That worked for me initially, but all of a sudden, the 'clearing' has ceased. It behaves like CF 1.4
    Also, can you increase the scrolling speed? Twice faster at least! It takes forever to stare and watch the whole thing scroll through. While driving, no less!
    Thanks a bunch.
    2002 Honda CR-V
  5. #65
    Maximum Bitrate P3rv3rt B3ar's Avatar
    Jul 2005
    Funland
    Plugin specific languages are broken!!!!
    (atleast this is the case on destinator plugin)
    instead of fetching plugin specific languages... centrafuse fetches available languages for plugins from main language directory meant for core centrafuse. Now this could be feature instead of bug, like microsoft likes to comment. But then why the hell there is language selection separately for each plugin.
  6. #66
    VENDOR - Centrafuse veetid's Avatar
    Quote Originally Posted by Dhaark
    my volume stat goes from 100% to 30% never below like kbyrd's.
    I think urosbe is trying to say that when he jumps from media to anywhere (Mixer, Apps, DVD...) when he returns to media the volume is on 30% and when he left it was higher.
    the volume does not go below 30%(2) asmentioned on top of post and the mute button is green but i can hear sound and the "mute" word (1) is off so the sound is on.
    I think you will know what i mean.
    your right.. that is a bug... it really is at 0, just a percent calculation problem...
    david
  7. #67
    Quote Originally Posted by urosbe
    I was just playing with my Powermate...
    by default settings in Powermate program are set that Powermate (right, left and click) control Windows volume. In this case, in CF if you have volume set to about 70% and you slowly move it to the left, in next moment volume shows 30%... but this can be changed... in Powermate program, change that Rotate Left/Right means sending keys "Control+Alt+Up" and "Contrl+Alt+Down", but changing volume from 30-100 then takes about 3 or 4 circles of Powermate rotating Unusefull.
    And I also noticed a bug - in Windows if you increase volume from min to max, everything goes linear, but in CF 1.5, volume starts at 30% and at 52% reaches maximum! At 53% is minimum again and 100% is maximum. I have Via Epia SP with default (latest) drivers.
    For now I am staying at 1.4, hopefully in next release it will be possible to manual set linear/logaritmic increasing of volume.
    Best regards!
    Uros
    I set my powermate to send ctrl-alt-up and at the fastest rate and it seems fine to me...
    david
  8. #68
    Quote Originally Posted by defsquad
    Guys, I know exactly what David is referring to. I had mentioned this "annoyance" yesterday to him, but after his explaination, it makes total sense. We are used to seeing volume represented by a 0-100% slider, whereas, high end audio gear, specifically for the house, gauges volume by the dB level, which is what David has coded into the application. I think if he were to remove the "%" sign from after the integer it would make less confusion, or even better if he would have the integer divided by a specific amount to get the lowest (30db in this case) to display as 0dB, however, this would mean 100 as we know it (being a percentage) would now be something like 60-70db and would max out there.
    I hope that makes sense. Unfortunately we have the mindset of volume being represented as a percentage of 0-100%, so we're confusing our selves with his new representation of volume level.
    exactly... I use DB now, but still converted to percent and their is just some math problems with the display... will be easy to fix and properly represent...
    david
  9. #69
    Quote Originally Posted by justintime
    Reproduce:
    3) Switch to MEDIA
    if another song that is not the current playing song is highlighted in the list, the icon changes to play because that is the action it will perform... if you click to go back to home, then the action of the button again becomes pause...
    basically it always should show what it will do...
    david
  10. #70
    Quote Originally Posted by P3rv3rt B3ar
    yep... that is a bug... will get it fixed... had a path wrong
    david
  1. New Release Centrafuse 1.20
    By veetid in forum Centrafuse
    Last Post: 10-10-2007, 08:12 PM
  2. Centrafuse SDK Information
    By veetid in forum CF SDK
    Last Post: 11-03-2005, 04:18 AM
  3. New Release Centrafuse 1.5
    Last Post: 11-02-2005, 01:48 PM
  4. Centrafuse 1.4 Bugs
    By veetid in forum CF Bug Reports
    Last Post: 09-27-2005, 10:58 PM
  5. Centrafuse 1.3 Bugs
    By rickster in forum CF Bug Reports
    Last Post: 07-26-2005, 08:51 PM
