Page 5 of 6 FirstFirst 123456 LastLast
Results 41 to 50 of 58
Thread: Centrafuse 1.6 Bugs
  1. #41
    Low Bitrate mrsony6's Avatar
    Nov 2005
    Munich (Ger)
    hi veetid
    great version :-)
    But the Hotkeys are not releesed for changing Media Folder with the remote :-(
    Mfg I
    be fair - be friends
    welcome to the football WM 2006
  2. #42
    Raw Wave
    Jun 2002
    Virginia
    Album Art/ Media Bugs
    Album art for some of my albums doesn't show. I have a valid folder.jpg file in each folder, but for some reason some of them (maybe 4%) don't show up. I can rebuild the library and the same ones won't show.
    I also get the message "Playlist is empty" when trying to play some albums. I have verified that the files are there and can see them in directory view within CF, but they won't show up in my library. There doesn't seem to be any connection between missing album art and the albums for which I get the playlist is empty message. For some albums I don't see the art, but can play the songs in the album. In other cases, I see the art but get the playlist is empty message. And in others I don't see the art and I also get the playlist is empty message. Neither the missing art or playlist is empty error message were problems in 1.5.
  3. #43
    Maximum Bitrate buurin's Avatar
    Sep 2005
    Seattle, WA
    Quote Originally Posted by kbreeden
    Me too. I got all my ID3 tags etc fixed for using 1.5 and now I am missing entire albums and album art.
    I will do more investigation to isolate the bug.
    B Smoov
    Project Status: 90% Complete
    Next Step: TIVO for Radio
    Ampie Case :: MII10000 Mobo :: M1-ATX PSU :: 512MB RAM :: 2.5" HD, 60GB, 5400rpm, 16MB Buffer :: DWW-700H :: Centrafuse
  4. #44
    Low Bitrate DaveTN's Avatar
    Aug 2005
    album art..additional problems
    It seems that with 1.6, album art shows up in my playlist. If I am playing songs in random, when it lands on "album art" it just stays there and waits for me to hit the forward button or select another song.
    I am using the same music folder that I used for previous versions and this has not happened before.
    Otherwise, I really like the improvements and like some other users said, the sound quality is great. I switch back and forthe between RR and CF and there is a big difference.
    Thanks David
    David
  5. #45
    Raw Wave
    Jun 2002
    Virginia
    Yes, I agree there is something funny going on with the library build. It seems to miss some album art and songs for no apparent reason. I've reviewed many of the missed items and see nothing different about them that would cause them to be skipped. Interestingly, I have the identical music directory on my desktop and carputer and the build misses the same artwork and songs on each.
  6. #46
    Zerach's Avatar
    Jul 2005
    some Bugs I found
    Have some bugs to report with my testing:
    Visualizations - screen worked for a little while then locked up, I was unable to exit the visual screen back to the media menu. However my music didn't skip a beat (at least it's performing well as far as song playing).
    external programs - in the settings menu the option buttons are all messed up. i.e. if I turn full screen on it pauses the music when the program runs. If I turn pause menu on it makes the program full screen. The other options are all messed as well, most likely coordinates issue in the skin.xml.
    set Password option - this is a great tease (I hope it will expand) so far I've found a lock screen in the tools menu which uses the password option. I was hoping the password option could be expanded to use on startup and entering the settings section. It would definately be a great security feature.
    button layout assignments - I'm missing the ability to put some of the other nav buttons in to the main menu, such as settings I think it's the only one missing, haven't double checked that.
    - Shutdown button when put on the main menu does not shrink font shows up as SHUTDOW, not sure if this can be fixed.
    External application - made my own with a description of "sync network" when display as a main page button goes behind the icon (left justify?) again maybe some sort of font size calc routine to display the icon nicely. Also limit the input field to 8-10 characters or so might fix it as well.
    Zerach
  7. #47
    Oct 2005
    Switzerland
    Hide Mouse dont work
    In my configuration, the mouse cursor doesn't hide even if the option is set. It works fine until hibernation, after resuming the cursor shows until restarting CF. The same happened with 1.5.
    Epia M10000, winXP-Home, Touchscreen
    Sachmet.
  8. #48
    Raw Wave
    Jun 2002
    Virginia
    Problem with Drop Down Menu
    Quote Originally Posted by Frankino
    by the way I have noticed a problem on the dropdown menu, both on my carpc and my desk machine.. launch CF, click menu and click media. instead of launching media it launchs mixer which is the button below (I edited the positions)
    again I click on mixer and it launches GPS (button below again)
    after few times using the menu this issue disappears and it works well
    I'm having the same problem on my carputer. Everytime I open CF the drop down menu shows up with two "Main" buttons at the top. When in that state, I have the same symptoms as decribed by Frankino: I must click the button above the action I want in order to launch the action. For example, if I want Nav and the XM button is directly above it, clicking the XM button will launch Nav. If I click the first "Main" button on the menu the second "Main" button disappears and everything works fine.
    I have reconfigured the main menu in settings and am wondering if that has caused this behavior. I'll test to see if the same problem occurs with an unmodified menu. I do note that the problem doesn't exist on my desktop computer on which I have not modified the menu.
    Frankino, when you're having the problem does the drop down menu show two "Main" buttons at the top? If so, does clicking the first "Main" button fix it? Finally, have you modified the main menu using settings?
  9. #49
    Low Bitrate ccrobin's Avatar
    Apr 2005
    XMPCR Not Working (CF keeps muting my inputs)
    I have an XMPCR and I can get it to work fine outside of CF, but whenever I load CF, I can see the channels in the XM screen, but I get no audio. I have tried every combination of line input from the CF Settings screen, and when I select the input that should work, I get a really static/white noise sound. When I turn the volume WAYYYYY up, I can hear the XM feed, but it is very muffled, and barely audivle over the loud static. (NOTE: I have been sure to check that the XM-Bundled software is NOT running when CF is running).
    I noticed that if I then if I exit CF and open my master volume control, the line input that the XM audio comes into is muted. If I then "unmute" my line input and start the XM-Bundled software (not CF) it works fine.
    I'm not sure, but it appears that starting CF mutes my line inputs so the sound from the XMPCR cannot be heard. And the only way I can find to unmute the line input is to exit CF and open my volume controls.
    I know my cables and connections are good, becuse I get nice clear audio with the XM bundled software. I just can't seem to get it to work within CF.
    Anyone have this problem, or any ideas how to fix it?
  10. #50
    VENDOR - Centrafuse veetid's Avatar
    Quote Originally Posted by ccrobin
    It is suppose to mute the line you choose.. It mutes and selectes the line and records the input, then plays it back.. This is how you are to pause, rewind, use the mixer, etc...
    not sure what is going on though... Anything in the error.log?
    david
  1. Centrafuse 1.6 Released
    By veetid in forum Centrafuse
    Last Post: 04-06-2006, 01:37 PM
  2. 1.6 Bugs (sorry)
    By GReeToZ in forum Centrafuse
    Last Post: 03-06-2006, 11:08 PM
  3. Centrafuse 1.5 Bugs
    By veetid in forum CF Bug Reports
    Last Post: 01-14-2006, 08:03 PM
  4. Centrafuse 1.4 Bugs
    Last Post: 09-27-2005, 10:58 PM
  5. Centrafuse 1.3 Bugs
    By rickster in forum CF Bug Reports
    Last Post: 07-26-2005, 08:51 PM
