cross fade does pretty much just that... it fades one song straight into another with no pause...Originally Posted by Lum
david
While I'm here, this is more of a feature request than a bug report. But I would really like it if there was no pause at all between songs. IE if CF could start work on processing the next MP3 before the current one is finished playing and just dump it into the sound buffer as if it were one stream.
Anyone who has ever ripped a mixed CD, or an album where the songs run into each other slightly, will understand why this is a good thing. Perhaps it could be set at album level somewhere?
david
this is the way on-the-fly normalization works... otherwise each time you got to a song you would have to analyze the entire file and rebuild a playback routine, or rewrite the file.. not efficient and not, if any, applications implement on-the-fly normalization this way...Originally Posted by justintime
the current method isn't perfect, but it's how you do on-the-fly normalization... if you want it done the other way the recommended method is for you to turn off normalization, and normalize your all your music files yourself with one of the many file normalization softwares out their... this is not on-the-fly normalization and does exactly what you want...
david
Thanks for clarifying that Daivd. I thought you could do on the fly normalization for the whole song. (ie., pre-analyze the peak levels of the next song prior to playing it, and then do a one-time-only adjustment of the output volume - up or down - for that song. (behind the scenes).
Is this not possible?
2002 Honda CR-V
Spent so far: $1105.90
...or even Listen to my music
It's possible, but much more complex... I will look into it after I get a lot of these other features/bugs completed...Originally Posted by justintime
david
When I hold down the Next or Previous buttons to rewind and Fast Forward, it starts rewinding/fwding for about 3 or 4 seconds, and then just goes to the previous or next song.
2000 Sunfire build 100%, or is it ever really 100%?
You most likely have right click functionality enabled on your touchscreen. Go to your touchscreen setup and disable hold and right click feature, then it should work.Originally Posted by CavityCr33p
david
The problem:
Ok, so it just happened that media player on 1.6 wouldn't import my music, videos or anything. I followed this process:
1. I set up my folders for music, videos and pictures. Since my OS is in spanish, my music folder is "Mi Música", my pictures folder is "Mis Imágenes" and mi video folder is "Mis Vídeos". Note that all names have accentes characters.
2. I ran rebuild media library, and it detected nothing.
3. I tried to browse my videos using media manager, and got the following error: "Not a valid directory". Same happened to pictures.
The workaround:
I checked that my folder was ok, and that i had installed audio drivers. Then i realized the issue might be with accented characters. So i opened the config.xml file, and looked under <MUSICPATH> and <VIDEOPATH>. It had some kind of code (i guess its unicode or something) to represent the accented character. So i changed that code for the appropriate character, saved the file and reopened it on Internet Explorer. I got a message telling me there was an error with an unsupported character.
Being a bit curious, I opened my old CF1.5 installation folder (on another computer) and found that 1.5's XML had the accented characters on the folder path, not the code. If i opened this XML on IE, it would show it with no problems. So my guess its some kind of difference between both XML's because one supports accented characters and the other one doesnt.
So i copied the old CF 1.5 config file, and copied/pasted the entire content of the 1.6 file on the 1.5 file, so i would have a 1.6 XML with accented character support. Then edited the MUSICPATH and videopath for this:
<APPCONFIG>
<VIDEOEXT>avi|qt|mov|mpg|mpeg|m1v|wmv|bin</VIDEOEXT>
<APPLANG>English</APPLANG>
<MUSICPATH>C:\Documents and Settings\Gilberto\Mis documentos\Mi música</MUSICPATH>
<VIDEOPATH>C:\Documents and Settings\Gilberto\Mis documentos\Mis vídeos\</VIDEOPATH>
I had to add an extra slash at the end of the videopath, and picturepath since i kept getting the invalid directory error. However when i go to the video section in media library, my first selection (which should be "mis vídeos") is blank. Same happens for pics. My guess here is the difference in the browsing method because music uses a media library, but videos/pics just lets you browse the files.
This is indeed a bug, since it was ok on 1.5, and now it presents an issue.
By the way I'm no XML programmer, so most of these are guesses, but they have proved apparently right, since now i have imported everything. The point is it shouldn't happen.
Other than that, this program is just awesome, and it runs faster than 1.5 (for me at least)
El Volcho is in progress... Got almost everything
-Via EPIA M10000, Super 7'' Touchscreen, Morex Cubid 3677 Case, Fujitsu 40Gb, 512DDR RAM, Sony DVD-CDRW...
Planning 80%
Parts 60%
Building 40%
Take the ending backslash '\' off of the video and picture path and then they should work fine. The problem is I HTMLEncode all input now, which I did not do previously. This was to ensure that people could enter characters without breaking the XML...Originally Posted by EvilAngel
It appears the html encoding is breaking spanish letters... I will look into this...
david
The problem is that if I take the backslash i will get an "invalid directory" error message
Planning 80%
Parts 60%
Building 40%
