Page 1 of 6 123456 LastLast
Results 1 to 10 of 54
Thread: 1.6 GPS Bugs
    May 2005
    Champaign IL
    Thumbs up 1.6 GPS Bugs
    I think it's best to seperate all our bugs into categories as suggested in the forums. This way David can focus on one section at a time.
    May 2005
    Champaign IL
    Intergrating Iguidance into 1.6 - Worked fine in 1.5, acting up in 1.6
    I tried intergrating iGuidance and when I click any buttons on iguidance it takes me back to the CF main screen. It seems like the layers could be out of wack. The window name is correct. Any input?
    Jul 2005
    When my pc comes out of sleep mode Destinator reports that there is no gps signal which is fair enough. But to get destinator to start navigating again i have to go in setup/plugins/destinator and reset the com port. Is there anyway to get over this problem ?
    VENDOR - Centrafuse veetid's Avatar
    Quote Originally Posted by clarkie
    Are you using a USB GPS mouse? If so try updating your drivers...
    david
    EL CAMINO's Avatar
    Jul 2005
    upland california us
    i have the same problem,i try to embbed iguidance and i just get the main window again over and over,man without my gps i cant use centrafuse what a shame.....
    May 2005
    Champaign IL
    David is fixing Iguidance embed problem
    Davids aware of the IGUIDANCE problem an is in the process of fixing it. In the mean time I guess we are out of luck, unless we go back to 1.5....lol
    Jan 2005
    Problem with correct location on map
    In CF 1.5 with Destinator I had no problem with my gps and position.
    After I have installed CF 1.6 my GPS shows a wrong position on the map. In Destinator I am driving about 500 meters next to the road....
    Am I the only one with this problem. I am using a Danish map from Destinator v. 3
    Jun 2005
    Brisbane
    Bug or Feature request?
    It annoys me the way the audio pauses when a voice prompt plays in the GPS plugin. Can you make it configurable so it doesnt pause.
    Also, if you have the music paused (cause your on the phone or something) and a voice prompt sounds, it un-pauses the music.
    Jul 2005
    Quote Originally Posted by veetid
    david
    Installed new Drivers and moved the GPS mouse connection to its own usb port.
    Previously it was plugged in a hub, only two ports on the AOpen mini pc.
    Problem now fixed thanks very much.
    Newbie newers's Avatar
    Jan 2006
    Melbourne, Australia
    Imperial to Metric
    Is there a way to change from Imperial to Metric measurements?
  1. Replies: 91
    Last Post: 11-07-2006, 04:47 PM
  2. Several Bugs - GPS, Interface, Upgrade
    By DReffects in forum CF Bug Reports
    Last Post: 12-14-2005, 02:23 AM
  3. GlobalSat BT-338 Review
    By tom2112 in forum The Review Palace
    Last Post: 06-27-2005, 11:02 AM
  4. Alturion GPS Pro 5 + few bugs
    By SuperSonic in forum MediaCar
    Last Post: 08-07-2004, 11:54 AM
  5. Mediacar V1.8.5
    By coyote in forum MediaCar
    Last Post: 02-16-2004, 01:16 PM
