No, I am blind. I didn't see the enormous white arrow.
Yes that double entry is a known bug that's already been reported.
If you do still need to fix the MP3 list, then a search for something like "ID3 tag editor" would be a good start.
I assume he reffers to double "START" entry on left bar unless I am blind.
Tahnk you. I
and found it
I already thougt that can't be the solution for my problem but who knows![]()
be fair - be friends
welcome to the football WM 2006
This is a known bug in the menu and the setting of the button actions... It will be fixed in the upcoming release...Originally Posted by mrsony6
david
The GodFather is an awesome editing program.... it will add all your tags based on the filename, or let you mass edit albums, genres, etc...Originally Posted by mrsony6
david
when i set cf to go to standby or hibernation (whats the difference) whent he ignition is turned off, it goes then when i come back it goes to a black screen
I saw this reported in one other place. I have tried and cannot reproduce this behavior. Is there anything in your error.log file? Can you do anything to make the screen comeback? Does the audio still play?Originally Posted by Bboy_jon
standby powers down to memory, but still uses power to keep the memory on. This will eventually run your battery down if you don't use your car everyday, but it is a lot faster.
hibernation powers down to the hard drive, so it uses no power, but it's slower.
david
