Results 1 to 10 of 18
Thread: 1.6 Internet connection bugs
    May 2005
    Champaign IL
    Thumbs up 1.6 Internet connection bugs
    I think it's best to seperate all our bugs into categories as suggested in the forums. This way David can focus on one section at a time.
    May 2005
    Champaign IL
    Web Plugin won't open new windows
    When you use the web plugin and you go to a website where you click and links open in a new windows the window doesn't pop up. It stays on the same window, you never see the other window pop-up. I mentioned this a long time ago because it did the same thing in 1.5, maybe david forgot
    May 2005
    Champaign IL
    Internet connection not working
    My internet connection is not working as it was in 1.5. I set up the connectiong entering the
    Connection name
    Phone
    Username
    Password
    (all filled in correctly)
    It doesn't connect at all, I see a status window but it's just blank and has a button that says OK. Whats up with that?
    VENDOR - Centrafuse veetid's Avatar
    Quote Originally Posted by Anointed
    Connection name
    Phone
    Username
    Password
    I will get this fixed, it's a bug...
    david
    May 2005
    Champaign IL
    Thank you David. Is there any temporary fixes? Or a way I can pull up my windows internet connection through CF as an external app or something.
    I guess the only other option is to connect to the net then start CF.
    FLAC alti's Avatar
    NY
    i was able to get mjne working by just going into settings a few times and re-entering the phone number.
    in case it helps, david here is my error log
    3/6/2006 11:15:17 PM
    Index was out of range. Must be non-negative and less than the size of the collection.
    Parameter name: index
    at System.Collections.ArrayList.get_Item(Int32 index)
    at centrafuse.section6.saveEntry()
    3/6/2006 11:17:10 PM
    3/6/2006 11:17:32 PM
    My Install
    Software:
    CFiG v1
    iGuidance Plugin for CF
    CarShell
    Working shell for a CarPC
    StopWatch
    StopWatch plugin remade for centrafuse RC1
    Banned RPM_VR4's Avatar
    Nov 2004
    L.A.
    ??? I never understood why a connection dialog is needed in CF. I set up windows to auto-connect via my cell phone. All I have to do is open the web browser (or anything else that uses the net) and windows does the rest without having to do anything through CF.
    Quote Originally Posted by RPM_VR4
    It's just to show the status of the internet dialing... It can be disabled from settings...
    The reason for having the internet connection settings in CF is because CF is meant to replace windows shell, so you need to be able to set everything up from within CF settings...
    david
    Raw Wave
    Jun 2002
    Virginia
    RPM, have you found an easy way to disconnect?
    Quote Originally Posted by kbreeden
    If you hit the green connection icon in the top header and you are connected to a dialup networking connection setup through Centrafuse, it will disconnect it for you and turn red...
    There are some bugs in this release related to setting up dialup networking connections in Centrafuse though, but they should be addressed in the next release...
    david
  1. Instructions on getting FREE wireless internet from T-Mobile using GPRS
    By bankingdom in forum Wireless Communications
    Last Post: 08-16-2011, 03:37 PM
  2. Replies: 35
    Last Post: 08-01-2006, 11:35 AM
  3. Imaginative Uses Of Internet Connection
    By wolfebaine in forum Wireless Communications
    Last Post: 07-16-2006, 04:32 AM
  4. 1.6 Bugs (sorry)
    By GReeToZ in forum Centrafuse
    Last Post: 03-06-2006, 11:08 PM
