you can just leave it blank... I will be removing this field once I get better native support for more radios.Originally Posted by mmk999
david
Daivd,
In post 7 above you say to make sure you have the Radio set to use RadioXtreme. I do, but what should I use for the Path setting on page 2 of FM setup? I'm currently using C:\Program Files\RadioXtreme\RX Radiator. If Radiator doesn't need to be installed, what should I use in the Path setting?
Thanks,
Mark
david
