Results 1 to 10 of 12
Thread: 1.6 Radio Bugs
    May 2005
    Champaign IL
    Thumbs up 1.6 Radio Bugs
    I think it's best to seperate all our bugs into categories as suggested in the forums. This way David can focus on one section at a time.
    Variable Bitrate bishooman's Avatar
    Jan 2006
    Kuwait
    my card is generic WDM card i wish david add support for fm and tv
    thanks
    We Exist because there is no patch for human Stupidity !!
    We need you ALL Here !!
    Variable Bitrate inniss777's Avatar
    Oct 2003
    SOCAL
    RadioXtreme problem
    David: When I start the fm tuner it seems that I am getting a constant repeat of everything. It's a 2 sec delay with the live radio playing as well. When I pause it, no repeat but then when I switch to media the radio still continues to play. I setup centrefuse for both radiator and radioextreme plug in with the same results. If I just use radiator by itself radioexteme works fine.
    Opus case. MB 899 core duo 2.0ghz
    Dual vga out, 400 gb hard drive, Centrefuse front end
    zapco 1000.4 for zapco 6.5 componets
    zapco 1100.1 for 2 13" W6.
    VENDOR - Centrafuse veetid's Avatar
    Quote Originally Posted by inniss777
    Not sure why it continued to play when you went to Media, I will look into it..
    There is some delay because I have it buffered to allow for the Tivo like functionality...
    david
    Oct 2003
    SOCAL
    I know about the tivo function but it seems as thoe that the buffer audio will not play by itself. It play with the live radio at the same time. If I pause it then the live radio will play by itself. When radio is selected I can not get it to stop playing unless I exit out of centrefuse.
    Constant Bitrate Meta's Avatar
    Dec 2004
    Indiana
    Per recommendations, I bought a RadioXtreme. With Radiator, it works pretty well.
    But in CF...
    1. I could never get the "Tune" function to work. I would enter a desired station, and it would ignore me and stay at 87.00. So I eventually edited the XML file to get the presets to work so I wouldn't have to spend 10 minutes getting to the station I wanted.
    2. Radiator seems to work just fine, but in CF, anywhere from 20 to 90 seconds, the sound goes silent. I have to re-hit my preset station or re-hit "Radio". It then starts up right away... for another 20-90 seconds.
    Quote Originally Posted by Meta
    But in CF...
    Did you set RadioXtreme in Radio device settings or Radiator? You should select RadioXtreme and you don't need radiator installed...
    There is a bug with the tune button in 1.6.. But you should be able to use the seek arrows and then fine tune with the tune arrows... You should also be able to use scan...
    if you had it set to radiator then scan and seek do not work, limitation of current radiator implementation...
    david
    Jan 2006
    Kuwait
    CF FM has very poor interface i did some changes in Photoshop tell me what do you think ??
    1- save button will open OSK to enter the name of current chanal and it will add it to the list
    2-in setup there should be an opption to sort the list by frequency or by name
    3-list is unlimited (not only 10 entries)
    4- visuals should be add to fm also !!
    Dec 2004
    Indiana
    Quote Originally Posted by veetid
    david
    Thanks, David. I set it up using the RadioXtreme device settings. I only used Radiator outside of CF, just to verify the device worked. I'll play with it some more to see if I can figure out why it's going quiet after playing a bit.
    Constant Bitrate 2 STanGeR's Avatar
    Aug 2005
    Terre Haute, IN
    David,
    Whenever I try to use the RadioXtreme plugin, the audio skips. Is there something that I am missing on the setup?
  1. 1.6 GPS Bugs
    By Anointed in forum CF Bug Reports
    Last Post: 06-09-2006, 01:10 PM
  2. 1.6 Internet connection bugs
    Last Post: 06-01-2006, 04:04 AM
  3. 1.6 DVD Bugs
    Last Post: 04-26-2006, 05:12 PM
  4. XM Satellite Radio to Unveil XM Advanced Services at 2006 Consumer
    By Will Albers in forum General MP3Car Discussion
    Last Post: 03-27-2006, 08:49 PM
  5. 1.6 Bugs (sorry)
    By GReeToZ in forum Centrafuse
    Last Post: 03-06-2006, 10:08 PM
