wintv problem. bt878 pci card
SPEC:
P3 933
384mb ram
Ge-force 4 mx440
wi-fi pci card
wintv pci analogue card (with fm radio)
lilliput 7" touchscreen
60gig 2.5"hd
dvd combo slot loading drive (laptop drive)
OPUS 150w
Windows xp pro sp2
centrafuse 1.6
all the latest drivers
I have a problem when trying to go into tv mode, I have set up centrafuse to use the wintv card but when i click the tv button an error message appears and I have to control, alt del to get away from it.
here is the stat of the error file.
Quote:
10/03/2006 12:01:26
Class not registered
at System.Windows.Forms.AxHost.CreateInstance()
at System.Windows.Forms.AxHost.GetOcxCreate()
at System.Windows.Forms.AxHost.TransitionUpTo(Int32 state)
at System.Windows.Forms.AxHost.CreateHandle()
at System.Windows.Forms.Control.CreateControl(Boolean fIgnoreVisible)
at System.Windows.Forms.AxHost.EndInit()
at centrafuse.tv.CF_pluginInit()
10/03/2006 12:01:42
at System.Windows.Forms.Control.CreateControl()
at System.Windows.Forms.Control.OnVisibleChanged(Even tArgs e)
at System.Windows.Forms.Control.OnParentVisibleChange d(EventArgs e)
at System.Windows.Forms.ScrollableControl.OnVisibleCh anged(EventArgs e)
at System.Windows.Forms.Form.OnVisibleChanged(EventAr gs e)
at System.Windows.Forms.Control.SetVisibleCore(Boolea n value)
at System.Windows.Forms.Form.SetVisibleCore(Boolean value)
at System.Windows.Forms.Control.set_Visible(Boolean value)
at centrafuse.tv.CF_pluginShow()
at centrafuse.main.CF_Main_systemCommands(CF_Actions command, String param1, String param2, String param3)
10/03/2006 12:01:52
Exception of type InvalidActiveXStateException was thrown.
at AxWinTV.AxWinTVControl.ChannelUp()
at centrafuse.tv.channelDown()
at centrafuse.tvslider.chandown_Click(Object sender, MouseEventArgs e)
at centrafuse.Plugins.skinButton.fireClick(MouseEvent Args e)
at centrafuse.Plugins.CFPlugin.CFPlugin_MouseUp(Objec t sender, MouseEventArgs e)
10/03/2006 12:01:53
at AxWinTV.AxWinTVControl.ChannelDown()
at centrafuse.tv.channelUp()
at centrafuse.tvslider.chanup_Click(Object sender, MouseEventArgs e)
the error list just keeps repaeting from this point
"10/03/2006 12:01:53
at centrafuse.Plugins.CFPlugin.CFPlugin_MouseUp(Objec t sender, MouseEventArgs e)"
I have a pci tv card I dont know if this will make much difference as I have noticed that a lot of people seen to be using usb wintv ?
Forgot to mention, wintv runs fine on its own app - wintv2000
I am also having a lot of problems trying to integrate the radio into centrafuse, it keeps hanging when trying to scan? although this does not create an error log? I have tried it with the bt878driver and with the radiator app, cant get it to work properly at all.. :confused:
p.s. check out my install!! :)
http://www.mp3car.com/vbulletin/show-off-your-project/71840-ford-focus-2000-finished-at-last.html
