Results 21 to 30 of 34
Thread: 1.6 Phone Control Issues
  1. #21
    May 2005
    Champaign IL
    e815 and v710 still not showing contacts
    I followed the instruction below posted by Zorro, but nothing changed.
    Open Extended Configurator (PhoneCtlConfig.exe) from the PhoneControl.NET directory, go to the Motorola V710 Communication section, look up for the option SMSTextmode and add the attributes name, date and time and set their content to 0.
    I tried the fix you posted above for the Motorola 710, but I'm not sure what problem this fix is suppose to correct. I have a e815, will changing the Motorola 710 config affect my phone since there different models?
    The two problems I'm having is...
    1. Can't see my address book
    2. No alert pops up when I receive a new text msg....should I get an alert? or am I only able to view my inbox to see if I have a new one.
    My main concern is my contacts not showing. How do I correct this?
  2. #22
    Aug 2004
    Black Hills, SD
    There is another bug when using the phone control plugin to connect to my phone it does it via the bluetooth modem as my phone (anointed as well) doesn't have a serial connection. This works just fine however, if I want to connect to the internet I can't because the modem is in use. Is there a way you can have it so we may disconnect/reconnect to our phones to use the internet or encase we loose connection to our phones?
    Hardware: VIA Epia MS 12000, 512 DDR, 60GB HD, 7" Xenarc, GM-210, Wi-Fi, Bluetooth, Radio Xtreme
    Software: Centrafuse2, Phonecontrol.net, nLite, TopoUSA 5.0, iGuidance, Girder, Winc
  3. #23
    May 2005
    Champaign IL
    Well Floating looks like we're going to be stuck with no contacts showing....lol
    He keeps telling us to do the same thing
    http://zhorvat.dyndns.org/PCForums/S...px?PostID=2317
    You've done it and I have as well and still no changes
  4. #24
    Aug 2004
    Black Hills, SD
    Yea I think we will be out of luck.. I still don't think its phoco but the plugin... Its reading the contacts just fine just not displaying them... I keep getting a list error in the log file (already posted) with the list items. If you look in the phoco directory at the phonebook xml file you will see our contacts!
  5. #25
    FLAC coucouillu's Avatar
    Nov 2004
    FRANCE
    Quote Originally Posted by skeltonmfc
    hi i cant see my phone book or messages and i cant see any icoming calls but i can dial out buy mannual typing in the number i have a nokia 6680 cheers
    with my 6680 I have nothing.
    The phone is connected to the PC but actions in CF don't do anything...
    You say that you can type the number, could you send me you Phoco config?
  6. #26
    Phone Control Moderator zorro's Avatar
    Mar 2004
    Munich, Germany
    This fault will be fixed as soon as possible. Please standy by.
    Skinning to go... VisualDesigner2!
  7. #27
    Raw Wave
    Jun 2002
    Virginia
    Quote Originally Posted by Floatingpi
    Also like Anointed I can't see my phone book, are we the only ones having this problem?
    Same problem here with my Moto V710.
    Also, when loading CF after setting up phone in Phoco, a black box with only a cancel button visible now appears over the CF splash screen. If I hit cancel, CF continues to load. This appears to be related to Phoco. Anybody else getting this?
  8. #28
    Oct 2004
    Netherlands
    Not that its really a bug but i'm having great dificulties finding out how to set everything up :P
    like do jou need two BT connections for headset and control (so a COM and HEADSET connection?) i know its just BETA but phoco is already being sold and as i will Buy CF its a but a waste of money to buy a phoco license for the support and have to buy it again when i buy CF (as part of the price will be for Phoco )
    even more offtopic, i have a SE K750i and cant get it to work as a headset when i say connect with bluetooth tot the PC it connects 2 sec later it disconnects :S when i do use secure connection the whole connection failes (does not even establish a connection)
    my destinator map resource down permanently
  9. #29
    Mar 2004
    Munich, Germany
    It's better to post obvious integation problems between PhoCo and CF (such as the disapearing contacts - which is well known) in this thread than to go about PhoCo issues. There's no difference between the PhoCo version and the one CF uses.
    If you have problems with PhoCo go to the PhoCo Forum. There you'll find a pretty good collection of problems and solutions.
  10. #30
    May 2005
    Champaign IL
    Hey Zorro hows that fix coming along for contacts not showing for the v710 and e815 phones?
  1. GPS to cell phone output somehow ???
    By gadget in forum General MP3Car Discussion
    Last Post: 06-11-2007, 09:22 AM
  2. Software Review: PhoneControl.NET
    By zorro in forum The Review Palace
    Last Post: 11-20-2006, 09:01 AM
  3. Phone Control Mute
    By Cheekz185 in forum PhoneControl
    Last Post: 06-04-2005, 11:14 AM
  4. auto launch phone control
    By robr in forum MediaCar
    Last Post: 05-17-2004, 12:54 PM
  5. Replies: 22
    Last Post: 08-13-2001, 02:42 PM
