Results 11 to 20 of 27
Thread: OBD-II Not working for scantool.net ISO
  1. #11
    VENDOR - Centrafuse
    raygun's Avatar
    Dec 2004
    Atlanta
    jibberjabbs: what device are you using and what kind of car?
    Which of the sensors do you suspect are incorrect?
    I'm pretty sure I can make it poll the data faster as well.
    raygun
    Reagan
    Formerly from Centrafuse
  2. #12
    Jan 2006
    Arizona
    02 WRX with a ISO elmscan from scantool.net. The RPM sensor is very spuratic. I'll have too look at it again to see what others are off.
  3. #13
    Mar 2006
    Lol... Found out why my OBD was not showing. Forgot to select Elmscan 5.
    Works fine now, but some parameters dont show, and updates are slow.
    Looks really great!
    Improvement wishes:
    Is there a way to calculate fuel consumption?
    Is there a way to calculate remaining fuel level?
    Is there a way to calculate remaining km based on average fuel consumption and remaining fuel level?
    Can OBD sensors be used to trigger stuff in CF?
    For example:
    Rear view camera when car is in reverse.
    Forward looking IR camera when turning on night lights...
    Trip data used in Destinator?
  4. #14
    Newbie kujosan's Avatar
    Oct 2004
    edit.... found the answer to my question in another thread
  5. #15
    VENDOR - Centrafuse
    raygun's Avatar
    Dec 2004
    Atlanta
    @cirion
    Fuel Consumption
    Some extended manufacturer specific cars have FLI or Fuel Level Indicator. Fords from what I can tell have this.
    I don't believe we are able to get fuel levels from the standard OBDII, and since we're not planning on doing anything (at this point) for specific makes or models, I wouldn't count on fuel level, although it would be nice...
    Yes and no.
    The plugin system allows to for plugin to plugin communication, so its definitely possible. However to get something like rear cam when you go in reverse would be tough b/c OBDII doesnt (from what I can tell) know what gear its in. You'd need to wire a relay up for that yourself. I think that is what other folks are doing. Same for the lights I believe. So yes, while its possible for OBDII sensors to trigger things in CF, the really neat stuff isn't availble from OBDII.
    The next release will have the bugs fixed and should poll the ELM chip faster.
    --raygun
    Reagan
  6. #16
    VENDOR - Centrafuse
    raygun's Avatar
    Dec 2004
    Atlanta
    @jibberjabbs
    We are working on getting the sensors to poll faster. Should help w/ RPM.
    --raygun
    Reagan
  7. #17
    Oct 2004
    Hey david have a question for you maybe a known problem but her goes. i just got my OBDPro serial scan tool in the mail hooked it up it works fine with the software it came with but, in CF when i put it on the right com por and select 327 it connects jstu fine but everythign always stays n/a once in a while certain things will come up with the correct temperature or what ever but the values will never change so far i got intake temp throttle position and oen other pne i think, but once it finaly gets a value of one of them it never seems to update. hopefully you may know why and can help me out!! or anybody
  8. #18
    Dec 2006
    Quote Originally Posted by nadforever View Post
    seem to have the same problem here, tried about everything in the meanwhile, port-speed, other than 327 ..
    other port-speeds just gave me a disconnected ..
    anybody a solution ? please ?
  9. #19
    Newbie BrianFerry's Avatar
    Sep 2007
    Russia, Moscow
    I have the same problem with N/A everywhere on my Subaru Forester XT 2002 year SG5 (Japanese made right-handed car).
    Subaru Forester SG5 2.0 XT - 2002г
    Made in Japan, Made for Japan.
    http://board.forester-moscowclub.ru/...ead.php?t=2031
  10. #20
    VENDOR - Centrafuse smeesseman's Avatar
    Mar 2007
    Detroit, MI
    Quote Originally Posted by BrianFerry View Post
    These issues should have since been fixed since the last post on this thread. Are you running CF version 1.47? You can also post your OBDII log, we can have a look at that to see any issues... You will find that I believe in <LocalSettings>/ApplicationData/Centrafuse/Plugins/OBDII/log.txt. Logging must also be enabled in obdii settings.
  1. can some one recomend a OBD II reader
    By crash893 in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 05-05-2011, 05:55 PM
  2. Confused about OBD II
    By tom2112 in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 10-19-2007, 01:06 AM
  3. OBD II RS232 or USB Interface
    By bklynkaos in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 01-24-2006, 11:42 AM
  4. OBD II Interface with Software
    By cpeek in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 02-07-2004, 12:53 AM
  5. obd II datalogger building and software
    By backpack09 in forum Off Topic
    Last Post: 08-22-2002, 08:03 PM
