Page 3 of 3 FirstFirst 123
Results 21 to 27 of 27
Thread: OBD-II Not working for scantool.net ISO
  1. #21
    Newbie BrianFerry's Avatar
    Sep 2007
    Russia, Moscow
    Ok, I'll make a log file.
    I am using the latest version of CF 1.47. And the problem still exist.
    Subaru Forester SG5 2.0 XT - 2002г
    Made in Japan, Made for Japan.
    http://board.forester-moscowclub.ru/...ead.php?t=2031
  2. #22
    Sep 2007
    Russia, Moscow
    So, here is the LOG-information:
    P.S.
    I Have a strange feeling, that my ECU didn't allow to read any information... Maybe I am wrong...
    57:43:67>
    58:01:12> openComPort(): Serial connection made, COM4 @ 38400bps
    58:01:12> initDevice()
    58:01:12> TX: atz<CR>
    58:02:23> RX: atz<CR><CR><CR>ELM327 v1.2a<CR><CR>>
    58:02:25> initDevice(): <ATZ Response> atz<CR><CR><CR>ELM327 v1.2a<CR><CR>>
    58:02:25> TX: ate0<CR>
    58:02:28> RX: ate0<CR>OK<CR><CR>>
    58:02:31> TX: 0100<CR>
    58:05:71> RX: 41 00 80 00 00 00 <CR><CR>>
    58:05:71> initDevice(ELM327): <PIDS_SUPPORTED_00 Response> 41 00 80 00 00 00 <CR><CR>>
    58:05:75> TX: 0100<CR>
    58:05:89> RX: 41 00 80 00 00 00 <CR>
    58:06:10> RX: 41 00 80 00 00 00 <CR><CR>>
    58:06:14> TX: 0120<CR>
    58:06:15> RXMSG: 41 00 80 00 00 00 <CR><CR>
    58:06:17> 1a: 10000000000000000000000000000000
    58:06:29> RX: 7F 01 11 <CR>
    58:06:50> RX: 7F 01 11 <CR><CR>>
    58:06:53> TX: 011C<CR>
    58:06:68> RX: 7F 01 11 <CR>
    58:06:87> RX: 7F 01 11 <CR><CR>>
    58:08:79> TX: 03<CR>
    58:08:95> RX: 43 00 00 00 00 00 00 <CR>
    58:09:04> RX: 43 00 00 00 00 00 00 <CR><CR>>
    58:09:04> RXMSG: 43 00 00 00 00 00 00 <CR><CR>
    58:09:07> TX: 0120<CR>
    58:09:23> RX: 7F 01 11 <CR>
    58:09:29> RX: 7F 01 11 <CR><CR>>
    58:11:23> TX: 03<CR>
    58:11:40> RX: 43 00 00 00 00 00 00 <CR>
    58:11:45> RX: 43 00 00 00 00 00 00 <CR><CR>>
    58:11:45> RXMSG: 43 00 00 00 00 00 00 <CR><CR>
    58:11:50> TX: 0120<CR>
    58:11:68> RX: 7F 01 11 <CR>
    58:11:71> RX: 7F 01 11 <CR><CR>>
    58:13:65> TX: 03<CR>
    58:13:79> RX: 43 00 00 00 00 00 00 <CR>
    58:13:85> RX: 43 00 00 00 00 00 00 <CR><CR>>
    58:13:85> RXMSG: 43 00 00 00 00 00 00 <CR><CR>
    58:13:90> TX: 0120<CR>
    58:14:04> RX: 7F 01 11 <CR>
    58:14:12> RX: 7F 01 11 <CR><CR>>
    58:15:84> RX: <CR><CR>ELM327 v1.2a<CR><CR>>
    58:16:04> TX: 03<CR>
    58:16:07> RX: 03<CR>
    58:16:95> RX: 03<CR>SEARCHING...<CR>
    58:16:95> RX(-):
    58:19:53> Max read() loops reached!!
    58:21:25> RX: UNABLE TO CONNECT<CR><CR>>
    58:31:45> COM_MONITOR_DELAY reached
    58:40:06> SENSOR1_CLICK Pg.1 False
    58:40:67> SENSOR1_CLICK Pg.1 True
    58:41:09> SENSOR1_CLICK Pg.1 False
    58:41:53> SENSOR1_CLICK Pg.1 True
    58:59:46> wThread2() exiting
    58:59:53> wThread1() exiting
    58:59:54> closeComPort(): COM port closed
  3. #23
    VENDOR - Centrafuse smeesseman's Avatar
    Mar 2007
    Detroit, MI
    OK I got the log entries I will look into these as soon as I can, been busy lately with the latest release but will get to these OBDII issue as soon as I can...
    Also, try turning the "Ignore Supported PID List" on in the OBDII settings, see if that does anything for you...
  4. #24
    Sep 2007
    Russia, Moscow
    I tried to set "Ignore Supported PID List", but after that Centrafuse didn't connect to ELM327 at all.
  5. #25
    Maximum Bitrate NiSlo's Avatar
    Nov 2006
    Gold Coast, Australia
    Was there any fix for this issue at all?
    I'm having thr problem where it connects and displays data fine for a while (sometimes a few seconds, sometimes a few minutes) before the data 'freezes' and no longer updates.
    I'm using the ODBPros interface
    Log data:
    45:46:33> a(): openComPort(): Serial connection made, COM6 @ 57600bps
    45:46:33> a(): initDevice()
    45:46:33> a(): TX: atz<CR>
    45:47:49> a(): RX: <CR><LF><CR><LF>ELM327 v1.0a compatible<CR><LF>>
    45:47:50> a(): initDevice(): <ATZ Response> <CR><LF><CR><LF>ELM327 v1.0a compatible<CR><LF>>
    45:47:50> a(): TX: ate0<CR>
    45:47:55> a(): RX: ate0<CR><LF>OK<CR><LF>>
    45:47:56> a(): TX: 0100<CR>
    45:50:97> a(): RX: BUS INIT: OK<CR><LF>NO DATA<CR><LF>>
    45:50:98> a(): initDevice(ELM327): <PIDS_SUPPORTED_00 Response> BUS INIT: OK<CR><LF>NO DATA<CR><LF>>
    45:51:10> a(): TX: 011C<CR>
    45:51:25> a(): RX: 41 1C 06 <CR><LF>
    45:51:41> a(): RX: 41 1C 06 <CR><LF>>
    45:51:44> a(): RXMSG: 41 1C 06 <CR><LF>
    45:51:48> a(): TX: 010D<CR>
    45:51:63> a(): RX: 41 0D 00 <CR><LF>
    45:51:79> a(): RX: 41 0D 00 <CR><LF>>
    45:51:80> a(): RXMSG: 41 0D 00 <CR><LF>
    45:51:81> a(): TX: 010C<CR>
    45:51:96> a(): RX: 41 0C 0A BE <CR><LF>
    45:52:12> a(): RX: 41 0C 0A BE <CR><LF>>
    45:52:13> a(): RXMSG: 41 0C 0A BE <CR><LF>
    45:52:20> a(): TX: 0105<CR>
    45:52:50> a(): RX: NO DATA<CR><LF>>
    45:52:69> a(): TX: 010D<CR>
    45:52:80> a(): RX: 41 0D 00 <CR><LF>
    45:53:00> a(): RX: 41 0D 00 <CR><LF>>
    45:53:01> a(): RXMSG: 41 0D 00 <CR><LF>
    45:53:01> a(): TX: 010C<CR>
    45:53:15> a(): RX: 41 0C 0A BE <CR><LF>
    45:53:32> a(): RX: 41 0C 0A BE <CR><LF>>
    45:53:33> a(): RXMSG: 41 0C 0A BE <CR><LF>
    45:53:37> a(): TX: 0105<CR>
    45:53:47> a(): RX: 41 05 87 <CR><LF>
    45:53:70> a(): RX: 41 05 87 <CR><LF>>
    45:53:71> a(): RXMSG: 41 05 87 <CR><LF>
    45:53:85> a(): TX: 010D<CR>
    45:54:00> a(): RX: 41 0D 00 <CR><LF>
    45:54:17> a(): RX: 41 0D 00 <CR><LF>>
    45:54:19> a(): RXMSG: 41 0D 00 <CR><LF>
    45:54:21> a(): TX: 010C<CR>
    45:54:34> a(): RX: 41 0C 0A 8C <CR><LF>
    45:54:52> a(): RX: 41 0C 0A 8C <CR><LF>>
    45:54:54> a(): RXMSG: 41 0C 0A 8C <CR><LF>
    45:54:57> a(): TX: 0105<CR>
    45:54:70> a(): RX: 41 05 87 <CR><LF>
    45:54:90> a(): RX: 41 05 87 <CR><LF>>
    45:54:91> a(): RXMSG: 41 05 87 <CR><LF>
    45:55:03> a(): TX: 010D<CR>
    45:55:16> a(): RX: 41 0D 00 <CR><LF>
    45:55:33> a(): RX: 41 0D 00 <CR><LF>>
    45:55:35> a(): RXMSG: 41 0D 00 <CR><LF>
    45:55:35> a(): TX: 010C<CR>
    45:55:48> a(): RX: 41 0C 0A 8C <CR><LF>
    45:55:69> a(): RX: 41 0C 0A 8C <CR><LF>>
    45:55:71> a(): RXMSG: 41 0C 0A 8C <CR><LF>
    45:55:88> a(): TX: 010D<CR>
    45:56:01> a(): RX: 41 0D 00 <CR><LF>
    45:56:20> a(): RX: 41 0D 00 <CR><LF>>
    45:56:22> a(): RXMSG: 41 0D 00 <CR><LF>
    45:56:22> a(): TX: 010C<CR>
    45:56:35> a(): RX: 41 0C 0A BE <CR><LF>
    45:56:52> a(): RX: 41 0C 0A BE <CR><LF>>
    45:56:53> a(): RXMSG: 41 0C 0A BE <CR><LF>
    45:56:85> a(): TX: 03<CR>
    45:57:00> a(): RX: 43 00 00 00 00 00 00 <CR><LF>
    45:57:16> a(): RX: 43 00 00 00 00 00 00 <CR><LF>>
    45:57:18> a(): RXMSG: 43 00 00 00 00 00 00 <CR><LF>
    45:57:21> a(): TX: 010D<CR>
    45:57:31> a(): RX: 41 0D 00 <CR><LF>
    45:57:52> a(): RX: 41 0D 00 <CR><LF>>
    45:57:53> a(): RXMSG: 41 0D 00 <CR><LF>
    45:57:55> a(): TX: 010C<CR>
    45:57:70> a(): RX: 41 0C 0A BE <CR><LF>
    45:57:88> a(): RX: 41 0C 0A BE <CR><LF>>
    45:57:90> a(): RXMSG: 41 0C 0A BE <CR><LF>
    45:57:93> a(): TX: 0105<CR>
    45:58:05> a(): RX: 41 05 87 <CR><LF>
    45:58:24> a(): RX: 41 05 87 <CR><LF>>
    45:58:25> a(): RXMSG: 41 05 87 <CR><LF>
    45:58:37> a(): TX: 010D<CR>
    45:58:52> a(): RX: 41 0D 00 <CR><LF>
    45:58:70> a(): RX: 41 0D 00 <CR><LF>>
    45:58:72> a(): RXMSG: 41 0D 00 <CR><LF>
    45:58:74> a(): TX: 010C<CR>
    45:58:84> a(): RX: 41 0C 0A BE <CR><LF>
    45:59:04> a(): RX: 41 0C 0A BE <CR><LF>>
    45:59:05> a(): RXMSG: 41 0C 0A BE <CR><LF>
    45:59:11> a(): TX: 0105<CR>
    45:59:21> a(): RX: 4
    45:59:25> a(): RX: 41 05 87 <CR><LF>
    45:59:44> a(): RX: 41 05 87 <CR><LF>>
    45:59:45> a(): RXMSG: 41 05 87 <CR><LF>
    45:59:57> a(): TX: 010D<CR>
    45:59:72> a(): RX: 41 0D 00 <CR><LF>
    45:59:87> a(): RX: 41 0D 00 <CR><LF>>
    45:59:88> a(): RXMSG: 41 0D 00 <CR><LF>
    45:59:90> a(): TX: 010C<CR>
    46:00:05> a(): RX: 41 0C 0A 8C <CR><LF>
    46:00:21> a(): RX: 41 0C 0A 8C <CR><LF>>
    46:00:24> a(): RXMSG: 41 0C 0A 8C <CR><LF>
    46:00:30> a(): TX: 0105<CR>
    46:00:44> a(): RX: 41 05 87 <CR><LF>
    46:00:69> a(): RX: 41 05 87 <CR><LF>>
    46:00:71> a(): RXMSG: 41 05 87 <CR><LF>
    46:00:87> a(): TX: 010D<CR>
    46:01:01> a(): RX: 41 0D 00 <CR><LF>
    46:01:18> a(): RX: 41 0D 00 <CR><LF>>
    46:01:20> a(): RXMSG: 41 0D 00 <CR><LF>
    46:01:21> a(): TX: 010C<CR>
    46:01:35> a(): RX: 41 0C 0A BE <CR><LF>
    46:01:53> a(): RX: 41 0C 0A BE <CR><LF>>
    46:01:54> a(): RXMSG: 41 0C 0A BE <CR><LF>
    46:01:80> a(): TX: 010D<CR>
    46:01:93> a(): RX: 41 0D 00 <CR><LF>
    46:02:13> a(): RX: 41 0D 00 <CR><LF>>
    46:02:16> a(): RXMSG: 41 0D 00 <CR><LF>
    46:02:16> a(): TX: 010C<CR>
    46:02:31> a(): RX: 41 0C 0A 8C <CR><LF>
    46:02:47> a(): RX: 41 0C 0A 8C <CR><LF>>
    46:02:49> a(): RXMSG: 41 0C 0A 8C <CR><LF>
    46:02:68> a(): TX: 03<CR>
    46:02:80> a(): RX: 43 00 00 00 00 00 00 <CR><LF>
    46:03:00> a(): RX: 43 00 00 00 00 00 00 <CR><LF>>
    46:03:01> a(): RXMSG: 43 00 00 00 00 00 00 <CR><LF>
    46:03:07> a(): TX: 010D<CR>
    46:03:40> a(): RX: NO DATA<CR><LF>>
    46:03:41> a(): TX: 010C<CR>
    46:03:51> a(): RX: 41 0C 0A 8C <CR><LF>
    46:03:72> a(): RX: 41 0C 0A 8C <CR><LF>>
    46:03:73> a(): RXMSG: 41 0C 0A 8C <CR><LF>
    46:03:76> a(): TX: 0105<CR>
    46:03:88> a(): RX: 41 05 87 <CR><LF>
    46:04:06> a(): RX: 41 05 87 <CR><LF>>
    46:04:08> a(): RXMSG: 41 05 87 <CR><LF>
    46:04:20> a(): TX: 010D<CR>
    46:04:32> a(): RX: 41 0D 00 <CR><LF>
    46:04:52> a(): RX: 41 0D 00 <CR><LF>>
    46:04:53> a(): RXMSG: 41 0D 00 <CR><LF>
    46:04:56> a(): TX: 010C<CR>
    46:04:70> a(): RX: 41 0C 0A 8C <CR><LF>
    46:04:88> a(): RX: 41 0C 0A 8C <CR><LF>>
    46:04:89> a(): RXMSG: 41 0C 0A 8C <CR><LF>
    46:04:93> a(): TX: 0105<CR>
    46:05:04> a(): RX: 41 05 87 <CR><LF>
    46:05:24> a(): RX: 41 05 87 <CR><LF>>
    46:05:25> a(): RXMSG: 41 05 87 <CR><LF>
    46:05:39> a(): TX: 010D<CR>
    46:05:52> a(): RX: 41 0D 00 <CR><LF>
    46:05:73> a(): RX: 41 0D 00 <CR><LF>>
    46:05:75> a(): RXMSG: 41 0D 00 <CR><LF>
    46:05:77> a(): TX: 010C<CR>
    46:05:88> a(): RX: 41 0C 0A BE <CR><LF>
    46:06:08> a(): RX: 41 0C 0A BE <CR><LF>>
    46:06:17> a(): RXMSG: 41 0C 0A BE <CR><LF>
    46:06:27> a(): TX: 0105<CR>
    46:06:43> a(): RX: 41 05 88 <CR><LF>
    46:06:75> a(): RX: 41 05 88 <CR><LF>>
    46:06:76> a(): RXMSG: 41 05 88 <CR><LF>
    46:06:94> a(): TX: 010D<CR>
    46:07:37> a(): RX: 41 0D 00 <CR><LF>>
    46:07:39> a(): RXMSG: 41 0D 00 <CR><LF>
    46:07:39> a(): TX: 010C<CR>
    46:07:52> a(): RX: 41 0C 0B EA <CR><LF>
    46:07:70> a(): RX: 41 0C 0B EA <CR><LF>>
    46:07:73> a(): RXMSG: 41 0C 0B EA <CR><LF>
    46:07:89> a(): TX: 010D<CR>
    46:08:08> a(): RX: 41 0D 00 <CR><LF>
    46:08:21> a(): RX: 41 0D 00 <CR><LF>>
    46:08:24> a(): RXMSG: 41 0D 00 <CR><LF>
    46:08:24> a(): TX: 010C<CR>
    46:08:40> a(): RX: 41 0C 0C E4 <CR><LF>
    46:08:57> a(): RX: 41 0C 0C E4 <CR><LF>>
    46:08:74> a(): RXMSG: 41 0C 0C E4 <CR><LF>
    46:08:91> a(): TX: 03<CR>
    46:09:05> a(): RX: 43 00 00 00 00 00 00 <CR><LF>
    46:09:25> a(): RX: 43 00 00 00 00 00 00 <CR><LF>>
    46:09:29> a(): RXMSG: 43 00 00 00 00 00 00 <CR><LF>
    46:09:33> a(): TX: 010D<CR>
    46:09:46> a(): RX: 41 0D 00 <CR><LF>
    46:09:70> a(): RX: 41 0D 00 <CR><LF>>
    46:09:73> a(): RXMSG: 41 0D 00 <CR><LF>
    46:09:77> a(): TX: 010C<CR>
    46:09:92> a(): RX: 41 0C 0B EA <CR><LF>
    46:10:08> a(): RX: 41 0C 0B EA <CR><LF>>
    46:10:10> a(): RXMSG: 41 0C 0B EA <CR><LF>
    46:10:12> a(): TX: 0105<CR>
    46:10:26> a(): RX: 41 05 88 <CR><LF>
    46:10:43> a(): RX: 41 05 88 <CR><LF>>
    46:10:44> a(): RXMSG: 41 05 88 <CR><LF>
    46:10:57> a(): TX: 010D<CR>
    46:10:73> a(): RX: 41 0D 00 <CR><LF>
    46:10:88> a(): RX: 41 0D 00 <CR><LF>>
    46:10:89> a(): RXMSG: 41 0D 00 <CR><LF>
    46:10:91> a(): TX: 010C<CR>
    46:11:04> a(): RX: 41 0C 0B B8 <CR><LF>
    46:11:24> a(): RX: 41 0C 0B B8 <CR><LF>>
    46:11:25> a(): RXMSG: 41 0C 0B B8 <CR><LF>
    46:11:36> a(): TX: 0105<CR>
    46:11:48> a(): RX: 41 05 88 <CR><LF>
    46:11:70> a(): RX: 41 05 88 <CR><LF>>
    46:11:71> a(): RXMSG: 41 05 88 <CR><LF>
    46:11:82> a(): TX: 010D<CR>
    46:11:96> a(): RX: 41 0D 00 <CR><LF>
    46:12:13> a(): RX: 41 0D 00 <CR><LF>>
    46:12:14> a(): RXMSG: 41 0D 00 <CR><LF>
    46:12:16> a(): TX: 010C<CR>
    46:12:28> a(): RX: 41 0C 0B 22 <CR><LF>
    46:12:48> a(): RX: 41 0C 0B 22 <CR><LF>>
    46:12:49> a(): RXMSG: 41 0C 0B 22 <CR><LF>
    46:12:56> a(): TX: 0105<CR>
    46:12:74> a(): RX: 41 05 88 <CR><LF>
    46:12:88> a(): RX: 41 05 88 <CR><LF>>
    46:12:90> a(): RXMSG: 41 05 88 <CR><LF>
    46:13:05> a(): TX: 010D<CR>
    46:13:15> a(): RX: 41 0D 00 <CR><LF>
    46:13:37> a(): RX: 41 0D 00 <CR><LF>>
    46:13:38> a(): RXMSG: 41 0D 00 <CR><LF>
    46:13:40> a(): TX: 010C<CR>
    46:13:53> a(): RX: 41 0C 0B 22 <CR><LF>
    46:13:71> a(): RX: 41 0C 0B 22 <CR><LF>>
    46:13:73> a(): RXMSG: 41 0C 0B 22 <CR><LF>
    46:13:95> a(): TX: 010D<CR>
    46:14:09> a(): RX: 41 0D 00 <CR><LF>
    46:14:28> a(): RX: 41 0D 00 <CR><LF>>
    46:14:30> a(): RXMSG: 41 0D 00 <CR><LF>
    46:14:33> a(): TX: 010C<CR>
    46:14:44> a(): RX: 41 0C 0B 54 <CR><LF>
    46:14:73> a(): RX: 41 0C 0B 54 <CR><LF>>
    46:14:74> a(): RXMSG: 41 0C 0B 54 <CR><LF>
    46:14:99> a(): TX: 03<CR>
    46:15:11> a(): RX: 43 00 00 00 00 00 00 <CR><LF>
    46:15:29> a(): RX: 43 00 00 00 00 00 00 <CR><LF>>
    46:15:32> a(): RXMSG: 43 00 00 00 00 00 00 <CR><LF>
    46:15:36> a(): TX: 010D<CR>
    46:15:49> a(): RX: 41 0D 00 <CR><LF>
    46:15:70> a(): RX: 41 0D 00 <CR><LF>>
    46:15:71> a(): RXMSG: 41 0D 00 <CR><LF>
    46:15:74> a(): TX: 010C<CR>
    46:15:87> a(): RX: 41 0C 0B 22 <CR><LF>
    46:16:09> a(): RX: 41 0C 0B 22 <CR><LF>>
    46:16:11> a(): RXMSG: 41 0C 0B 22 <CR><LF>
    46:16:16> a(): TX: 0105<CR>
    46:16:29> a(): RX: 41 05 88 <CR><LF>
    46:16:47> a(): RX: 41 05 88 <CR><LF>>
    46:16:48> a(): RXMSG: 41 05 88 <CR><LF>
    46:16:68> a(): TX: 010D<CR>
    46:16:79> a(): RX: 41 0D 00 <CR><LF>
    46:17:00> a(): RX: 41 0D 00 <CR><LF>>
    46:17:01> a(): RXMSG: 41 0D 00 <CR><LF>
    46:17:02> a(): TX: 010C<CR>
    46:17:17> a(): RX: 41 0C 0B 22 <CR><LF>
    46:17:32> a(): RX: 41 0C 0B 22 <CR><LF>>
    46:17:33> a(): RXMSG: 41 0C 0B 22 <CR><LF>
    46:17:36> a(): TX: 0105<CR>
    46:17:48> a(): RX: 41 05 88 <CR><LF>
    46:17:69> a(): RX: 41 05 88 <CR><LF>>
    46:17:70> a(): RXMSG: 41 05 88 <CR><LF>
    46:17:81> a(): TX: 010D<CR>
    46:17:95> a(): RX: 41 0D 00 <CR><LF>
    46:18:12> a(): RX: 41 0D 00 <CR><LF>>
    46:18:13> a(): RXMSG: 41 0D 00 <CR><LF>
    46:18:15> a(): TX: 010C<CR>
    46:18:28> a(): RX: 41 0C 0B 54 <CR><LF>
    46:18:45> a(): RX: 41 0C 0B 54 <CR><LF>>
    46:18:46> a(): RXMSG: 41 0C 0B 54 <CR><LF>
    46:18:51> a(): TX: 0105<CR>
    46:18:70> a(): RX: 41 05 88 <CR><LF>
    46:18:84> a(): RX: 41 05 88 <CR><LF>>
    46:18:85> a(): RXMSG: 41 05 88 <CR><LF>
    46:18:96> a(): TX: 010D<CR>
    46:19:08> a(): RX: 41 0D 00 <CR><LF>
    46:19:27> a(): RX: 41 0D 00 <CR><LF>>
    46:19:28> a(): RXMSG: 41 0D 00 <CR><LF>
    46:19:30> a(): TX: 010C<CR>
    46:19:45> a(): RX: 41 0C 0B 22 <CR><LF>
    46:19:70> a(): RX: 41 0C 0B 22 <CR><LF>>
    46:19:72> a(): RXMSG: 41 0C 0B 22 <CR><LF>
    46:19:94> a(): TX: 010D<CR>
    46:20:08> a(): RX: 41 0D 00 <CR><LF>
    46:20:26> a(): RX: 41 0D 00 <CR><LF>>
    46:20:28> a(): RXMSG: 41 0D 00 <CR><LF>
    46:20:28> a(): TX: 010C<CR>
    46:20:42> a(): RX: 41 0C 0B 22 <CR><LF>
    46:20:60> a(): RX: 41 0C 0B 22 <CR><LF>>
    46:20:69> a(): RXMSG: 41 0C 0B 22 <CR><LF>
    46:20:88> a(): TX: 03<CR>
    46:21:02> a(): RX: 43 00 00 00 00 00 00 <CR><LF>
    46:21:20> a(): RX: 43 00 00 00 00 00 00 <CR><LF>>
    46:21:21> a(): RXMSG: 43 00 00 00 00 00 00 <CR><LF>
    46:21:25> a(): TX: 010D<CR>
    46:21:40> a(): RX: 41 0D 00 <CR><LF>
    46:21:55> a(): RX: 41 0D 00 <CR><LF>>
    46:21:57> a(): RXMSG: 41 0D 00 <CR><LF>
    46:21:60> a(): TX: 010C<CR>
    46:21:73> a(): RX: 41 0C 0B 54 <CR><LF>
    46:21:90> a(): RX: 41 0C 0B 54 <CR><LF>>
    46:21:91> a(): RXMSG: 41 0C 0B 54 <CR><LF>
    46:21:97> a(): TX: 0105<CR>
    46:22:09> a(): RX: 41 05 88 <CR><LF>
    46:22:27> a(): RX: 41 05 88 <CR><LF>>
    46:22:28> a(): RXMSG: 41 05 88 <CR><LF>
    46:22:40> a(): TX: 010D<CR>
    46:22:49> a(): RX: 4
    46:22:52> a(): RX: 41 0D 00 <CR><LF>
    46:22:72> a(): RX: 41 0D 00 <CR><LF>>
    46:22:74> a(): RXMSG: 41 0D 00 <CR><LF>
    46:22:78> a(): TX: 010C<CR>
    46:22:88> a(): RX: 41 0C 0B 54 <CR><LF>
    46:23:08> a(): RX: 41 0C 0B 54 <CR><LF>>
    46:23:09> a(): RXMSG: 41 0C 0B 54 <CR><LF>
    46:23:12> a(): TX: 0105<CR>
    46:23:27> a(): RX: 41 05 88 <CR><LF>
    46:23:48> a(): RX: 41 05 88 <CR><LF>>
    46:23:50> a(): RXMSG: 41 05 88 <CR><LF>
    46:23:81> a(): TX: 010D<CR>
    46:24:13> a(): RX: NO DATA<CR><LF>>
    46:24:27> a(): TX: 010C<CR>
    46:24:40> a(): RX: 41 0C 0B 22 <CR><LF>
    46:24:75> a(): RX: 41 0C 0B 22 <CR><LF>>
    46:24:76> a(): RXMSG: 41 0C 0B 22 <CR><LF>
    46:24:91> a(): TX: 0105<CR>
    46:25:04> a(): RX: 41 05 87 <CR><LF>
    46:25:23> a(): RX: 41 05 87 <CR><LF>>
    46:25:24> a(): RXMSG: 41 05 87 <CR><LF>
    46:25:48> a(): TX: 010D<CR>
    46:25:76> a(): RX: 41 0D 00 <CR><LF>
    46:25:78> a(): RX: 41 0D 00 <CR><LF>>
    46:25:81> a(): RXMSG: 41 0D 00 <CR><LF>
    46:25:93> a(): TX: 010C<CR>
    46:26:05> a(): RX: 41 0C 0B 54 <CR><LF>
    46:26:25> a(): RX: 41 0C 0B 54 <CR><LF>>
    46:26:26> a(): RXMSG: 41 0C 0B 54 <CR><LF>
    46:26:55> a(): TX: 010D<CR>
    46:26:71> a(): RX: 41 0D 00 <CR><LF>
    46:26:87> a(): RX: 41 0D 00 <CR><LF>>
    46:26:89> a(): RXMSG: 41 0D 00 <CR><LF>
    46:26:99> a(): TX: 010C<CR>
    46:27:13> a(): RX: 41 0C 0B 22 <CR><LF>
    46:27:29> a(): RX: 41 0C 0B 22 <CR><LF>>
    46:27:31> a(): RXMSG: 41 0C 0B 22 <CR><LF>
    46:27:59> a(): TX: 03<CR>
    46:27:76> a(): RX: 43 00 00 00 00 00 00 <CR><LF>
    46:27:92> a(): RX: 43 00 00 00 00 00 00 <CR><LF>>
    46:27:94> a(): RXMSG: 43 00 00 00 00 00 00 <CR><LF>
    46:28:04> a(): TX: 010D<CR>
    46:28:19> a(): RX: 41 0D 00 <CR><LF>
    46:28:36> a(): RX: 41 0D 00 <CR><LF>>
    46:28:37> a(): RXMSG: 41 0D 00 <CR><LF>
    46:28:47> a(): TX: 010C<CR>
    46:28:60> a(): RX: 41 0C 0B 54 <CR><LF>
    46:28:80> a(): RX: 41 0C 0B 54 <CR><LF>>
    46:28:82> a(): RXMSG: 41 0C 0B 54 <CR><LF>
    46:28:95> a(): TX: 0105<CR>
    46:29:11> a(): RX: 41 05 87 <CR><LF>
    46:29:29> a(): RX: 41 05 87 <CR><LF>>
    46:29:31> a(): RXMSG: 41 05 87 <CR><LF>
    46:29:52> a(): TX: 010D<CR>
    46:29:72> a(): RX: 41 0D 00 <CR><LF>
    46:29:82> a(): RX: 41 0D 00 <CR><LF>>
    46:29:83> a(): RXMSG: 41 0D 00 <CR><LF>
    46:29:95> a(): TX: 010C<CR>
    46:30:05> a(): RX: 41 0C 0B 54 <CR><LF>
    46:30:28> a(): RX: 41 0C 0B 54 <CR><LF>>
    46:30:29> a(): RXMSG: 41 0C 0B 54 <CR><LF>
    46:30:43> a(): TX: 0105<CR>
    46:30:58> a(): RX: 41 05 86 <CR><LF>
    46:30:76> a(): RX: 41 05 86 <CR><LF>>
    46:30:78> a(): RXMSG: 41 05 86 <CR><LF>
    46:31:01> a(): TX: 010D<CR>
    46:31:15> a(): RX: 41 0D 00 <CR><LF>
    46:31:32> a(): RX: 41 0D 00 <CR><LF>>
    46:31:34> a(): RXMSG: 41 0D 00 <CR><LF>
    46:31:46> a(): TX: 010C<CR>
    46:31:82> a(): RX: NO DATA<CR><LF>>
    46:31:96> a(): TX: 0105<CR>
    46:32:08> a(): RX: 41 05 86 <CR><LF>
    46:32:28> a(): RX: 41 05 86 <CR><LF>>
    46:32:29> a(): RXMSG: 41 05 86 <CR><LF>
    46:32:53> a(): TX: 010D<CR>
    46:32:81> a(): RX: 41 0D 00 <CR><LF>
    46:32:85> a(): RX: 41 0D 00 <CR><LF>>
    46:32:86> a(): RXMSG: 41 0D 00 <CR><LF>
    46:32:97> a(): TX: 010C<CR>
    46:33:09> a(): RX: 41 0C 0B 54 <CR><LF>
    46:33:29> a(): RX: 41 0C 0B 54 <CR><LF>>
    46:33:30> a(): RXMSG: 41 0C 0B 54 <CR><LF>
    46:33:59> a(): TX: 010D<CR>
    46:33:80> a(): RX: 41 0D 00 <CR><LF>
    46:33:92> a(): RX: 41 0D 00 <CR><LF>>
    46:33:94> a(): RXMSG: 41 0D 00 <CR><LF>
    46:34:04> a(): TX: 010C<CR>
    46:34:16> a(): RX: 41 0C 0B 54 <CR><LF>
    46:34:36> a(): RX: 41 0C 0B 54 <CR><LF>>
    46:34:37> a(): RXMSG: 41 0C 0B 54 <CR><LF>
    46:34:77> a(): TX: 03<CR>
    46:34:91> a(): RX: 43 00 00 00 00 00 00 <CR><LF>
    46:35:08> a(): RX: 43 00 00 00 00 00 00 <CR><LF>>
    46:35:09> a(): RXMSG: 43 00 00 00 00 00 00 <CR><LF>
    46:35:20> a(): TX: 010D<CR>
    46:35:36> a(): RX: 41 0D 00 <CR><LF>
    46:35:51> a(): RX: 41 0D 00 <CR><LF>>
    46:35:53> a(): RXMSG: 41 0D 00 <CR><LF>
    46:35:69> a(): TX: 010C<CR>
    46:35:91> a(): RX: 41 0C 0B 54 <CR><LF>
    46:36:06> a(): RX: 41 0C 0B 54 <CR><LF>>
    46:36:09> a(): RXMSG: 41 0C 0B 54 <CR><LF>
    46:36:22> a(): TX: 0105<CR>
    46:36:37> a(): RX: 41 05 86 <CR><LF>
    46:36:52> a(): RX: 41 05 86 <CR><LF>>
    46:36:53> a(): RXMSG: 41 05 86 <CR><LF>
    46:36:85> a(): TX: 010D<CR>
    46:37:00> a(): RX: 41 0D 00 <CR><LF>
    46:37:16> a(): RX: 41 0D 00 <CR><LF>>
    46:37:17> a(): RXMSG: 41 0D 00 <CR><LF>
    46:37:29> a(): TX: 010C<CR>
    46:37:43> a(): RX: 41 0C 0B 22 <CR><LF>
    46:37:74> a(): RX: 41 0C 0B 22 <CR><LF>>
    46:37:77> a(): RXMSG: 41 0C 0B 22 <CR><LF>
    46:37:92> a(): TX: 0105<CR>
    46:38:03> a(): RX: 41 05 85 <CR><LF>
    46:38:24> a(): RX: 41 05 85 <CR><LF>>
    46:38:25> a(): RXMSG: 41 05 85 <CR><LF>
    46:38:48> a(): TX: 010D<CR>
    46:38:75> a(): RX: 41 0D 00 <CR><LF>
    46:38:77> a(): RX: 41 0D 00 <CR><LF>>
    46:38:80> a(): RXMSG: 41 0D 00 <CR><LF>
    46:38:91> a(): TX: 010C<CR>
    46:39:03> a(): RX: 41 0C 0B 54 <CR><LF>
    46:39:23> a(): RX: 41 0C 0B 54 <CR><LF>>
    46:39:24> a(): RXMSG: 41 0C 0B 54 <CR><LF>
    46:39:40> a(): TX: 0105<CR>
    46:39:51> a(): RX: 41 05 85 <CR><LF>
    46:39:72> a(): RX: 41 05 85 <CR><LF>>
    46:39:74> a(): RXMSG: 41 05 85 <CR><LF>
    46:39:96> a(): TX: 010D<CR>
    46:40:10> a(): RX: 41 0D 00 <CR><LF>
    46:40:28> a(): RX: 41 0D 00 <CR><LF>>
    46:40:29> a(): RXMSG: 41 0D 00 <CR><LF>
    46:40:40> a(): TX: 010C<CR>
    46:40:55> a(): RX: 41 0C 0B 54 <CR><LF>
    46:40:75> a(): RX: 41 0C 0B 54 <CR><LF>>
    46:40:77> a(): RXMSG: 41 0C 0B 54 <CR><LF>
    46:41:04> a(): TX: 010D<CR>
    46:41:15> a(): RX: 41 0D 00 <CR><LF>
    46:41:36> a(): RX: 41 0D 00 <CR><LF>>
    46:41:37> a(): RXMSG: 41 0D 00 <CR><LF>
    46:41:48> a(): TX: 010C<CR>
    46:41:70> a(): RX: 41 0C 0B 22 <CR><LF>
    46:41:81> a(): RX: 41 0C 0B 22 <CR><LF>>
    46:41:85> a(): RXMSG: 41 0C 0B 22 <CR><LF>
    46:42:24> a(): TX: 03<CR>
    46:42:42> a(): RX: 43 00 00 00 00 00 00 <CR><LF>
    46:42:56> a(): RX: 43 00 00 00 00 00 00 <CR><LF>>
    46:42:58> a(): RXMSG: 43 00 00 00 00 00 00 <CR><LF>
    46:42:69> a(): TX: 010D<CR>
    46:42:80> a(): RX: 41 0D 00 <CR><LF>
    46:43:01> a(): RX: 41 0D 00 <CR><LF>>
    46:43:02> a(): RXMSG: 41 0D 00 <CR><LF>
    46:43:02> a(): TX: 010C<CR>
    46:43:13> a(): RX: 41 0C 0B 54 <CR><LF>
    46:43:36> a(): RX: 41 0C 0B 54 <CR><LF>>
    46:43:37> a(): RXMSG: 41 0C 0B 54 <CR><LF>
    46:43:40> a(): TX: 0105<CR>
    46:43:52> a(): RX: 41 05 85 <CR><LF>
    46:43:72> a(): RX: 41 05 85 <CR><LF>>
    46:43:73> a(): RXMSG: 41 05 85 <CR><LF>
    46:43:91> a(): TX: 010D<CR>
    46:44:04> a(): RX: 41 0D 00 <CR><LF>
    46:44:23> a(): RX: 41 0D 00 <CR><LF>>
    46:44:24> a(): RXMSG: 41 0D 00 <CR><LF>
    46:44:25> a(): TX: 010C<CR>
    46:44:39> a(): RX: 41 0C 0B 54 <CR><LF>
    46:44:55> a(): RX: 41 0C 0B 54 <CR><LF>>
    46:44:56> a(): RXMSG: 41 0C 0B 54 <CR><LF>
    46:44:60> a(): TX: 0105<CR>
    46:44:74> a(): RX: 41 05 85 <CR><LF>
    46:44:92> a(): RX: 41 05 85 <CR><LF>>
    46:44:93> a(): RXMSG: 41 05 85 <CR><LF>
    46:45:06> a(): TX: 010D<CR>
    46:45:15> a(): RX: 4
    46:45:16> a(): RX: 41 0D 00 <CR><LF>
    46:45:36> a(): RX: 41 0D 00 <CR><LF>>
    46:45:37> a(): RXMSG: 41 0D 00 <CR><LF>
    46:45:38> a(): TX: 010C<CR>
    46:45:52> a(): RX: 41 0C 0B 54 <CR><LF>
    46:45:69> a(): RX: 41 0C 0B 54 <CR><LF>>
    46:45:71> a(): RXMSG: 41 0C 0B 54 <CR><LF>
    46:45:74> a(): TX: 0105<CR>
    46:45:87> a(): RX: 41 05 84 <CR><LF>
    46:46:04> a(): RX: 41 05 84 <CR><LF>>
    46:46:05> a(): RXMSG: 41 05 84 <CR><LF>
    46:46:19> a(): TX: 010D<CR>
    46:46:32> a(): RX: 41 0D 00 <CR><LF>
    46:46:53> a(): RX: 41 0D 00 <CR><LF>>
    46:46:54> a(): RXMSG: 41 0D 00 <CR><LF>
    46:46:55> a(): TX: 010C<CR>
    46:46:70> a(): RX: 41 0C 0B 54 <CR><LF>
    46:46:86> a(): RX: 41 0C 0B 54 <CR><LF>>
    46:46:89> a(): RXMSG: 41 0C 0B 54 <CR><LF>
    46:47:08> a(): TX: 010D<CR>
    46:47:18> a(): RX: 41 0D 00 <CR><LF>
    46:47:41> a(): RX: 41 0D 00 <CR><LF>>
    46:47:42> a(): RXMSG: 41 0D 00 <CR><LF>
    46:47:42> a(): TX: 010C<CR>
    46:47:56> a(): RX: 41 0C 0B 54 <CR><LF>
    46:47:73> a(): RX: 41 0C 0B 54 <CR><LF>>
    46:47:75> a(): RXMSG: 41 0C 0B 54 <CR><LF>
    46:47:94> a(): TX: 03<CR>
    46:48:21> a(): RX: NO DATA<CR><LF>>
    46:48:28> a(): TX: 010D<CR>
    46:48:41> a(): RX: 41 0D 00 <CR><LF>
    46:48:69> a(): RX: 41 0D 00 <CR><LF>>
    46:48:72> a(): RXMSG: 41 0D 00 <CR><LF>
    46:48:74> a(): TX: 010C<CR>
    46:48:85> a(): RX: 41 0C 0B 54 <CR><LF>
    46:49:04> a(): RX: 41 0C 0B 54 <CR><LF>>
    46:49:05> a(): RXMSG: 41 0C 0B 54 <CR><LF>
    46:49:10> a(): TX: 0105<CR>
    46:49:24> a(): RX: 41 05 84 <CR><LF>
    46:49:41> a(): RX: 41 05 84 <CR><LF>>
    46:49:43> a(): RXMSG: 41 05 84 <CR><LF>
    46:49:53> a(): TX: 010D<CR>
    46:49:72> a(): RX: 41 0D 00 <CR><LF>
    46:49:83> a(): RX: 41 0D 00 <CR><LF>>
    46:49:84> a(): RXMSG: 41 0D 00 <CR><LF>
    46:49:85> a(): TX: 010C<CR>
    46:51:57> a(): RX: 41 0C 0B 54 <CR><LF>>
    46:51:58> a(): RXMSG: 41 0C 0B 54 <CR><LF>
    46:51:62> a(): TX: 0105<CR>
    46:51:75> a(): RX: 41 05 84 <CR><LF>
    46:51:93> a(): RX: 41 05 84 <CR><LF>>
    46:51:94> a(): RXMSG: 41 05 84 <CR><LF>
    46:52:08> a(): TX: 010D<CR>
    46:52:20> a(): RX: 41 0D 00 <CR><LF>
    46:52:38> a(): RX: 41 0D 00 <CR><LF>>
    46:52:40> a(): RXMSG: 41 0D 00 <CR><LF>
    46:52:40> a(): TX: 010C<CR>
    46:52:53> a(): RX: 41 0C 10 36 <CR><LF>
    46:52:72> a(): RX: 41 0C 10 36 <CR><LF>>
    46:52:73> a(): RXMSG: 41 0C 10 36 <CR><LF>
    46:52:79> a(): TX: 0105<CR>
    46:52:92> a(): RX: 41 05 84 <CR><LF>
    46:53:10> a(): RX: 41 05 84 <CR><LF>>
    46:53:11> a(): RXMSG: 41 05 84 <CR><LF>
    46:53:21> a(): TX: 010D<CR>
    46:53:37> a(): RX: 41 0D 00 <CR><LF>
    46:53:53> a(): RX: 41 0D 00 <CR><LF>>
    46:53:54> a(): RXMSG: 41 0D 00 <CR><LF>
    46:53:55> a(): TX: 010C<CR>
    46:53:72> a(): RX: 41 0C 12 C0 <CR><LF>
    46:53:86> a(): RX: 41 0C 12 C0 <CR><LF>>
    46:53:88> a(): RXMSG: 41 0C 12 C0 <CR><LF>
    46:54:08> a(): TX: 010D<CR>
    46:54:21> a(): RX: 41 0D 00 <CR><LF>
    46:54:38> a(): RX: 41 0D 00 <CR><LF>>
    46:54:41> a(): RXMSG: 41 0D 00 <CR><LF>
    46:54:41> a(): TX: 010C<CR>
    46:54:54> a(): RX: 41 0C 12 2A <CR><LF>
    46:54:71> a(): RX: 41 0C 12 2A <CR><LF>>
    46:54:73> a(): RXMSG: 41 0C 12 2A <CR><LF>
    46:54:93> a(): TX: 03<CR>
    46:55:02> a(): RX: 43 00 00 00 00 00 00 <CR><LF>
    46:55:25> a(): RX: 43 00 00 00 00 00 00 <CR><LF>>
    46:55:26> a(): RXMSG: 43 00 00 00 00 00 00 <CR><LF>
    46:55:29> a(): TX: 010D<CR>
    46:55:38> a(): RX: 41 0D 00 <CR><LF>
    46:55:69> a(): RX: 41 0D 00 <CR><LF>>
    46:55:71> a(): RXMSG: 41 0D 00 <CR><LF>
    46:55:71> a(): TX: 010C<CR>
    46:55:85> a(): RX: 41 0C 0C B2 <CR><LF>
    46:56:02> a(): RX: 41 0C 0C B2 <CR><LF>>
    46:56:05> a(): RXMSG: 41 0C 0C B2 <CR><LF>
    46:56:23> a(): TX: 0105<CR>
    46:56:37> a(): RX: 41 05 83 <CR><LF>
    46:56:54> a(): RX: 41 05 83 <CR><LF>>
    46:56:56> a(): RXMSG: 41 05 83 <CR><LF>
    46:56:80> a(): TX: 010D<CR>
    46:56:93> a(): RX: 41 0D 00 <CR><LF>
    46:57:10> a(): RX: 41 0D 00 <CR><LF>>
    46:57:12> a(): RXMSG: 41 0D 00 <CR><LF>
    46:57:22> a(): TX: 010C<CR>
    46:57:37> a(): RX: 41 0C 0A BE <CR><LF>
    46:57:54> a(): RX: 41 0C 0A BE <CR><LF>>
    46:57:55> a(): RXMSG: 41 0C 0A BE <CR><LF>
    46:57:72> a(): TX: 0105<CR>
    46:57:85> a(): RX: 41 05 83 <CR><LF>
    46:58:02> a(): RX: 41 05 83 <CR><LF>>
    46:58:05> a(): RXMSG: 41 05 83 <CR><LF>
    46:58:33> a(): TX: 010D<CR>
    46:58:51> a(): RX: 41 0D 00 <CR><LF>
    46:58:73> a(): RX: 41 0D 00 <CR><LF>>
    46:58:75> a(): RXMSG: 41 0D 00 <CR><LF>
    46:58:88> a(): TX: 010C<CR>
    46:59:00> a(): RX: 41 0C 0B 22 <CR><LF>
    46:59:21> a(): RX: 41 0C 0B 22 <CR><LF>>
    46:59:23> a(): RXMSG: 41 0C 0B 22 <CR><LF>
    46:59:39> a(): TX: 0105<CR>
    46:59:70> a(): RX: 41 05 83 <CR><LF>
    46:59:71> a(): RX: 41 05 83 <CR><LF>>
    46:59:73> a(): RXMSG: 41 05 83 <CR><LF>
    46:59:99> a(): TX: 010D<CR>
    47:00:38> a(): RX: 41 0D 00 <CR><LF>>
    47:00:39> a(): RXMSG: 41 0D 00 <CR><LF>
    47:00:50> a(): TX: 010C<CR>
    47:00:73> a(): RX: 41 0C 0A BE <CR><LF>
    47:00:99> a(): RX: 41 0C 0A BE <CR><LF>>
    47:01:00> a(): RXMSG: 41 0C 0A BE <CR><LF>
    47:01:35> a(): TX: 010D<CR>
    47:01:46> a(): RX: 41 0D 00 <CR><LF>
    47:01:71> a(): RX: 41 0D 00 <CR><LF>>
    47:01:73> a(): RXMSG: 41 0D 00 <CR><LF>
    47:01:85> a(): TX: 010C<CR>
    47:01:98> a(): RX: 41 0C 0A BE <CR><LF>
    47:02:16> a(): RX: 41 0C 0A BE <CR><LF>>
    47:02:17> a(): RXMSG: 41 0C 0A BE <CR><LF>
    47:02:52> a(): TX: 03<CR>
    47:02:81> a(): RX: NO DATA<CR><LF>>
    47:02:95> a(): TX: 010D<CR>
    47:03:06> a(): RX: 41 0D 00 <CR><LF>
    47:03:25> a(): RX: 41 0D 00 <CR><LF>>
    47:03:27> a(): RXMSG: 41 0D 00 <CR><LF>
    47:03:38> a(): TX: 010C<CR>
    47:03:50> a(): RX: 41 0C 0A BE <CR><LF>
    47:03:71> a(): RX: 41 0C 0A BE <CR><LF>>
    47:03:72> a(): RXMSG: 41 0C 0A BE <CR><LF>
    47:03:87> a(): TX: 0105<CR>
    47:03:97> a(): RX: 41 05 83 <CR><LF>
    47:04:17> a(): RX: 41 05 83 <CR><LF>>
    47:04:18> a(): RXMSG: 41 05 83 <CR><LF>
    47:04:41> a(): TX: 010D<CR>
    47:04:52> a(): RX: 41 0D 00 <CR><LF>
    47:04:72> a(): RX: 41 0D 00 <CR><LF>>
    47:04:75> a(): RXMSG: 41 0D 00 <CR><LF>
    47:04:86> a(): TX: 010C<CR>
    47:04:97> a(): RX: 41 0C 0A BE <CR><LF>
    47:05:18> a(): RX: 41 0C 0A BE <CR><LF>>
    47:05:19> a(): RXMSG: 41 0C 0A BE <CR><LF>
    47:05:37> a(): TX: 0105<CR>
    47:05:50> a(): RX: 41 05 83 <CR><LF>
    47:05:72> a(): RX: 41 05 83 <CR><LF>>
    47:05:75> a(): RXMSG: 41 05 83 <CR><LF>
    47:05:98> a(): TX: 010D<CR>
    47:06:09> a(): RX: 41 0D 00 <CR><LF>
    47:06:29> a(): RX: 41 0D 00 <CR><LF>>
    47:06:30> a(): RXMSG: 41 0D 00 <CR><LF>
    47:06:42> a(): TX: 010C<CR>
    47:06:76> a(): RX: 41 0C 0A BE <CR><LF>>
    47:06:77> a(): RXMSG: 41 0C 0A BE <CR><LF>
    47:06:90> a(): TX: 0105<CR>
    47:07:02> a(): RX: 41 05 83 <CR><LF>
    47:07:23> a(): RX: 41 05 83 <CR><LF>>
    47:07:25> a(): RXMSG: 41 05 83 <CR><LF>
    47:07:47> a(): TX: 010D<CR>
    47:07:57> a(): RX: 41 0D 00 <CR><LF>
    47:07:77> a(): RX: 41 0D 00 <CR><LF>>
    47:08:01> a(): RXMSG: 41 0D 00 <CR><LF>
    47:08:10> a(): TX: 010C<CR>
    47:08:28> a(): RX: 41 0C 0A 8C <CR><LF>
    47:08:40> a(): RX: 41 0C 0A 8C <CR><LF>>
    47:08:41> a(): RXMSG: 41 0C 0A 8C <CR><LF>
    47:08:82> a(): TX: 010D<CR>
    47:08:96> a(): RX: 41 0D 00 <CR><LF>
    47:09:15> a(): RX: 41 0D 00 <CR><LF>>
    47:09:16> a(): RXMSG: 41 0D 00 <CR><LF>
    47:09:27> a(): TX: 010C<CR>
    47:09:40> a(): RX: 41 0C 0A 8C <CR><LF>
    47:09:58> a(): RX: 41 0C 0A 8C <CR><LF>>
    47:09:59> a(): RXMSG: 41 0C 0A 8C <CR><LF>
    47:09:85> a(): TX: 03<CR>
    47:10:13> a(): RX: NO DATA<CR><LF>>
    47:10:25> a(): TX: 010D<CR>
    47:10:37> a(): RX: 41 0D 00 <CR><LF>
    47:10:57> a(): RX: 41 0D 00 <CR><LF>>
    47:10:58> a(): RXMSG: 41 0D 00 <CR><LF>
    47:10:71> a(): TX: 010C<CR>
    47:10:85> a(): RX: 41 0C 0A 8C <CR><LF>
    47:11:02> a(): RX: 41 0C 0A 8C <CR><LF>>
    47:11:04> a(): RXMSG: 41 0C 0A 8C <CR><LF>
    47:11:18> a(): TX: 0105<CR>
    47:11:28> a(): RX: 41 05 83 <CR><LF>
    47:11:49> a(): RX: 41 05 83 <CR><LF>>
    47:11:50> a(): RXMSG: 41 05 83 <CR><LF>
    47:11:80> a(): TX: 010D<CR>
    47:11:92> a(): RX: 41 0D 00 <CR><LF>
    47:12:12> a(): RX: 41 0D 00 <CR><LF>>
    47:12:15> a(): RXMSG: 41 0D 00 <CR><LF>
    47:12:25> a(): TX: 010C<CR>
    47:12:38> a(): RX: 41 0C 0A 5A <CR><LF>
    47:12:57> a(): RX: 41 0C 0A 5A <CR><LF>>
    47:12:58> a(): RXMSG: 41 0C 0A 5A <CR><LF>
    47:12:72> a(): TX: 0105<CR>
    47:12:82> a(): RX: 41 05 83 <CR><LF>
    47:13:02> a(): RX: 41 05 83 <CR><LF>>
    47:13:04> a(): RXMSG: 41 05 83 <CR><LF>
    47:13:25> a(): TX: 010D<CR>
    47:13:37> a(): RX: 41 0D 00 <CR><LF>
    47:13:54> a(): RX: 41 0D 00 <CR><LF>>
    47:13:56> a(): RXMSG: 41 0D 00 <CR><LF>
    47:13:69> a(): TX: 010C<CR>
    47:13:82> a(): RX: 41 0C 0A 8C <CR><LF>
    47:14:00> a(): RX: 41 0C 0A 8C <CR><LF>>
    47:14:01> a(): RXMSG: 41 0C 0A 8C <CR><LF>
    47:14:16> a(): TX: 0105<CR>
    47:14:25> a(): RX: 41 05 83 <CR><LF>
    47:14:45> a(): RX: 41 05 83 <CR><LF>>
    47:14:46> a(): RXMSG: 41 05 83 <CR><LF>
    47:14:75> a(): TX: 010D<CR>
    47:14:88> a(): RX: 41 0D 00 <CR><LF>
    47:15:05> a(): RX: 41 0D 00 <CR><LF>>
    47:15:07> a(): RXMSG: 41 0D 00 <CR><LF>
    47:15:17> a(): TX: 010C<CR>
    47:15:30> a(): RX: 41 0C 0A 8C <CR><LF>
    47:15:47> a(): RX: 41 0C 0A 8C <CR><LF>>
    47:15:48> a(): RXMSG: 41 0C 0A 8C <CR><LF>
    47:15:80> a(): TX: 010D<CR>
    47:15:93> a(): RX: 41 0D 00 <CR><LF>
    47:16:10> a(): RX: 41 0D 00 <CR><LF>>
    47:16:12> a(): RXMSG: 41 0D 00 <CR><LF>
    47:16:25> a(): TX: 010C<CR>
    47:16:35> a(): RX: 41 0C 0A BE <CR><LF>
    47:16:55> a(): RX: 41 0C 0A BE <CR><LF>>
    47:16:56> a(): RXMSG: 41 0C 0A BE <CR><LF>
    47:16:85> a(): TX: 03<CR>
    47:16:97> a(): RX: 43 00 00 00 00 00 00 <CR><LF>
    47:17:15> a(): RX: 43 00 00 00 00 00 00 <CR><LF>>
    47:17:16> a(): RXMSG: 43 00 00 00 00 00 00 <CR><LF>
    47:17:27> a(): TX: 010D<CR>
    47:17:40> a(): RX: 41 0D 00 <CR><LF>
    47:17:57> a(): RX: 41 0D 00 <CR><LF>>
    47:17:58> a(): RXMSG: 41 0D 00 <CR><LF>
    47:17:70> a(): TX: 010C<CR>
    47:18:02> a(): RX: NO DATA<CR><LF>>
    47:18:17> a(): TX: 0105<CR>
    47:18:28> a(): RX: 41 05 83 <CR><LF>
    47:18:49> a(): RX: 41 05 83 <CR><LF>>
    47:18:50> a(): RXMSG: 41 05 83 <CR><LF>
    47:18:78> a(): TX: 010D<CR>
    47:18:90> a(): RX: 41 0D 00 <CR><LF>
    47:19:09> a(): RX: 41 0D 00 <CR><LF>>
    47:19:10> a(): RXMSG: 41 0D 00 <CR><LF>
    47:19:22> a(): TX: 010C<CR>
    47:19:34> a(): RX: 41 0C 0A 8C <CR><LF>
    47:19:54> a(): RX: 41 0C 0A 8C <CR><LF>>
    47:19:55> a(): RXMSG: 41 0C 0A 8C <CR><LF>
    47:19:72> a(): TX: 0105<CR>
    47:19:85> a(): RX: 41 05 83 <CR><LF>
    47:20:02> a(): RX: 41 05 83 <CR><LF>>
    47:20:04> a(): RXMSG: 41 05 83 <CR><LF>
    47:20:25> a(): TX: 010D<CR>
    47:20:37> a(): RX: 41 0D 00 <CR><LF>
    47:20:57> a(): RX: 41 0D 00 <CR><LF>>
    47:20:58> a(): RXMSG: 41 0D 00 <CR><LF>
    47:20:69> a(): TX: 010C<CR>
    47:20:79> a(): RX: 41 0C 0A 8C <CR><LF>
    47:20:99> a(): RX: 41 0C 0A 8C <CR><LF>>
    47:21:00> a(): RXMSG: 41 0C 0A 8C <CR><LF>
    47:21:16> a(): TX: 0105<CR>
    47:21:25> a(): RX: 41 05 84 <CR><LF>
    47:21:48> a(): RX: 41 05 84 <CR><LF>>
    47:21:49> a(): RXMSG: 41 05 84 <CR><LF>
    47:21:75> a(): TX: 010D<CR>
    47:21:87> a(): RX: 41 0D 00 <CR><LF>
    47:22:05> a(): RX: 41 0D 00 <CR><LF>>
    47:22:06> a(): RXMSG: 41 0D 00 <CR><LF>
    47:22:17> a(): TX: 010C<CR>
    47:22:30> a(): RX: 41 0C 0A 8C <CR><LF>
    47:22:47> a(): RX: 41 0C 0A 8C <CR><LF>>
    47:22:48> a(): RXMSG: 41 0C 0A 8C <CR><LF>
    47:22:82> a(): TX: 010D<CR>
    47:22:92> a(): RX: 41 0D 00 <CR><LF>
    47:23:15> a(): RX: 41 0D 00 <CR><LF>>
    47:23:16> a(): RXMSG: 41 0D 00 <CR><LF>
    47:23:27> a(): TX: 010C<CR>
    47:23:40> a(): RX: 41 0C 0A 8C <CR><LF>
    47:23:57> a(): RX: 41 0C 0A 8C <CR><LF>>
    47:23:58> a(): RXMSG: 41 0C 0A 8C <CR><LF>
    47:23:85> a(): TX: 03<CR>
    47:23:98> a(): RX: 43 00 00 00 00 00 00 <CR><LF>
    47:24:17> a(): RX: 43 00 00 00 00 00 00 <CR><LF>>
    47:24:19> a(): RXMSG: 43 00 00 00 00 00 00 <CR><LF>
    47:24:29> a(): TX: 010D<CR>
    47:24:42> a(): RX: 41 0D 00 <CR><LF>
    47:24:60> a(): RX: 41 0D 00 <CR><LF>>
    47:24:78> a(): RXMSG: 41 0D 00 <CR><LF>
    47:24:88> a(): TX: 010C<CR>
    47:24:98> a(): RX: 41 0C 0A BE <CR><LF>
    47:25:20> a(): RX: 41 0C 0A BE <CR><LF>>
    47:25:21> a(): RXMSG: 41 0C 0A BE <CR><LF>
    47:25:38> a(): TX: 0105<CR>
    47:25:83> a(): RX: NO DATA<CR><LF>>
    47:26:07> a(): TX: 010D<CR>
    47:26:17> a(): RX: 41 0D 00 <CR><LF>
    47:26:49> a(): RX: 41 0D 00 <CR><LF>>
    47:26:50> a(): RXMSG: 41 0D 00 <CR><LF>
    47:26:50> a(): TX: 010C<CR>
    47:26:72> a(): RX: 41 0C 0A 8C <CR><LF>
    47:26:82> a(): RX: 41 0C 0A 8C <CR><LF>>
    47:26:83> a(): RXMSG: 41 0C 0A 8C <CR><LF>
    47:26:91> a(): TX: 0105<CR>
    47:27:02> a(): RX: 41 05 84 <CR><LF>
    47:27:22> a(): RX: 41 05 84 <CR><LF>>
    47:27:24> a(): RXMSG: 41 05 84 <CR><LF>
    47:27:34> a(): TX: 010D<CR>
    47:27:47> a(): RX: 41 0D 00 <CR><LF>
    47:27:69> a(): RX: 41 0D 00 <CR><LF>>
    47:27:70> a(): RXMSG: 41 0D 00 <CR><LF>
    47:27:71> a(): TX: 010C<CR>
    47:27:85> a(): RX: 41 0C 0A 8C <CR><LF>
    47:28:02> a(): RX: 41 0C 0A 8C <CR><LF>>
    47:28:05> a(): RXMSG: 41 0C 0A 8C <CR><LF>
    47:28:08> a(): TX: 0105<CR>
    47:28:18> a(): RX: 41 05 84 <CR><LF>
    47:28:40> a(): RX: 41 05 84 <CR><LF>>
    47:28:41> a(): RXMSG: 41 05 84 <CR><LF>
    47:28:53> a(): TX: 010D<CR>
    47:28:72> a(): RX: 41 0D 00 <CR><LF>
    47:28:85> a(): RX: 41 0D 00 <CR><LF>>
    47:28:86> a(): RXMSG: 41 0D 00 <CR><LF>
    47:28:87> a(): TX: 010C<CR>
    47:29:00> a(): RX: 41 0C 0A 8C <CR><LF>
    47:29:18> a(): RX: 41 0C 0A 8C <CR><LF>>
    47:29:19> a(): RXMSG: 41 0C 0A 8C <CR><LF>
    47:29:35> a(): TX: 010D<CR>
    47:29:48> a(): RX: 41 0D 00 <CR><LF>
    47:29:71> a(): RX: 41 0D 00 <CR><LF>>
    47:29:72> a(): RXMSG: 41 0D 00 <CR><LF>
    47:29:72> a(): TX: 010C<CR>
    47:29:85> a(): RX: 41 0C 0A 8C <CR><LF>
    47:30:05> a(): RX: 41 0C 0A 8C <CR><LF>>
    47:30:06> a(): RXMSG: 41 0C 0A 8C <CR><LF>
    47:30:22> a(): TX: 03<CR>
    47:30:35> a(): RX: 43 00 00 00 00 00 00 <CR><LF>
    47:30:52> a(): RX: 43 00 00 00 00 00 00 <CR><LF>>
    47:30:55> a(): RXMSG: 43 00 00 00 00 00 00 <CR><LF>
    47:30:57> a(): TX: 010D<CR>
    47:30:72> a(): RX: 41 0D 00 <CR><LF>
    47:30:87> a(): RX: 41 0D 00 <CR><LF>>
    47:30:88> a(): RXMSG: 41 0D 00 <CR><LF>
    47:30:89> a(): TX: 010C<CR>
    47:31:02> a(): RX: 41 0C 0A BE <CR><LF>
    47:31:20> a(): RX: 41 0C 0A BE <CR><LF>>
    47:31:21> a(): RXMSG: 41 0C 0A BE <CR><LF>
    47:31:28> a(): TX: 0105<CR>
    47:31:39> a(): RX: 41 05 84 <CR><LF>
    47:31:58> a(): RX: 41 05 84 <CR><LF>>
    47:31:59> a(): RXMSG: 41 05 84 <CR><LF>
    47:31:80> a(): TX: 010D<CR>
    47:31:92> a(): RX: 41 0D 00 <CR><LF>
    47:32:12> a(): RX: 41 0D 00 <CR><LF>>
    47:32:14> a(): RXMSG: 41 0D 00 <CR><LF>
    47:32:15> a(): TX: 010C<CR>
    47:32:25> a(): SENSOR3_CLICK Pg.1 True
    47:32:32> a(): RX: 41 0C 0A BE <CR><LF>
    47:32:45> a(): RX: 41 0C 0A BE <CR><LF>>
    47:32:47> a(): RXMSG: 41 0C 0A BE <CR><LF>
    47:32:48> a(): TX: 010F<CR>
    47:32:60> a(): RX: 41 0F 5F <CR><LF>
    47:32:80> a(): RX: 41 0F 5F <CR><LF>>
    47:32:81> a(): RXMSG: 41 0F 5F <CR><LF>
    47:32:86> a(): TX: 0105<CR>
    47:32:99> a(): RX: 41 05 84 <CR><LF>
    47:33:17> a(): RX: 41 05 84 <CR><LF>>
    47:33:18> a(): RXMSG: 41 05 84 <CR><LF>
    47:33:30> a(): TX: 010D<CR>
    47:33:42> a(): RX: 41 0D 00 <CR><LF>
    47:33:70> a(): RX: 41 0D 00 <CR><LF>>
    47:33:71> a(): RXMSG: 41 0D 00 <CR><LF>
    47:33:72> a(): TX: 010C<CR>
    47:33:84> a(): RX: 41 0C 0A 8C <CR><LF>
    47:34:02> a(): RX: 41 0C 0A 8C <CR><LF>>
    47:34:04> a(): RXMSG: 41 0C 0A 8C <CR><LF>
    47:34:08> a(): TX: 010F<CR>
    47:34:22> a(): RX: 41 0F 5F <CR><LF>
    47:34:39> a(): RX: 41 0F 5F <CR><LF>>
    47:34:41> a(): RXMSG: 41 0F 5F <CR><LF>
    47:34:44> a(): TX: 0105<CR>
    47:34:54> a(): RX: 41 05 85 <CR><LF>
    47:34:75> a(): RX: 41 05 85 <CR><LF>>
    47:34:76> a(): RXMSG: 41 05 85 <CR><LF>
    47:34:90> a(): TX: 010D<CR>
    47:35:05> a(): RX: 41 0D 00 <CR><LF>
    47:35:22> a(): RX: 41 0D 00 <CR><LF>>
    47:35:23> a(): RXMSG: 41 0D 00 <CR><LF>
    47:35:25> a(): TX: 010C<CR>
    47:35:38> a(): RX: 41 0C 0A BE <CR><LF>
    47:35:57> a(): RX: 41 0C 0A BE <CR><LF>>
    47:35:58> a(): RXMSG: 41 0C 0A BE <CR><LF>
    47:35:72> a(): TX: 010F<CR>
    47:35:85> a(): RX: 41 0F 5F <CR><LF>
    47:36:03> a(): RX: 41 0F 5F <CR><LF>>
    47:36:05> a(): RXMSG: 41 0F 5F <CR><LF>
    47:36:18> a(): TX: 010D<CR>
    47:36:28> a(): RX: 41 0D 00 <CR><LF>
    47:36:47> a(): RX: 41 0D 00 <CR><LF>>
    47:36:48> a(): RXMSG: 41 0D 00 <CR><LF>
    47:36:49> a(): TX: 010C<CR>
    47:36:70> a(): RX: 41 0C 0A 8C <CR><LF>
    47:36:80> a(): RX: 41 0C 0A 8C <CR><LF>>
    47:36:81> a(): RXMSG: 41 0C 0A 8C <CR><LF>
    47:37:02> a(): TX: 03<CR>
    47:37:15> a(): RX: 43 00 00 00 00 00 00 <CR><LF>
    47:37:32> a(): RX: 43 00 00 00 00 00 00 <CR><LF>>
    47:37:35> a(): RXMSG: 43 00 00 00 00 00 00 <CR><LF>
    47:37:37> a(): TX: 010D<CR>
    47:37:47> a(): RX: 41 0D 00 <CR><LF>
    47:37:70> a(): RX: 41 0D 00 <CR><LF>>
    47:37:71> a(): RXMSG: 41 0D 00 <CR><LF>
    47:37:72> a(): TX: 010C<CR>
    47:37:85> a(): RX: 41 0C 0A 8C <CR><LF>
    47:38:02> a(): RX: 41 0C 0A 8C <CR><LF>>
    47:38:05> a(): RXMSG: 41 0C 0A 8C <CR><LF>
    47:38:05> a(): TX: 010F<CR>
    47:38:17> a(): RX: 41 0F 5F <CR><LF>
    47:38:35> a(): RX: 41 0F 5F <CR><LF>>
    47:38:36> a(): RXMSG: 41 0F 5F <CR><LF>
    47:38:37> a(): TX: 0105<CR>
    47:38:49> a(): RX: 41 05 85 <CR><LF>
    47:38:70> a(): RX: 41 05 85 <CR><LF>>
    47:38:71> a(): RXMSG: 41 05 85 <CR><LF>
    47:38:82> a(): TX: 010D<CR>
    47:38:95> a(): RX: 41 0D 00 <CR><LF>
    47:39:12> a(): RX: 41 0D 00 <CR><LF>>
    47:39:22> a(): RXMSG: 41 0D 00 <CR><LF>
    47:40:17> a(): TX: 03<CR>
    47:40:27> a(): RX: 43 00 00 00 00 00 00 <CR><LF>
    47:40:47> a(): RX: 43 00 00 00 00 00 00 <CR><LF>>
    47:40:48> a(): RXMSG: 43 00 00 00 00 00 00 <CR><LF>
    47:41:45> a(): TX: 03<CR>
    47:41:57> a(): RX: 43 00 00 00 00 00 00 <CR><LF>
    47:41:74> a(): RX: 43 00 00 00 00 00 00 <CR><LF>>
    47:41:76> a(): RXMSG: 43 00 00 00 00 00 00 <CR><LF>
    47:42:71> a(): SENSOR1_CLICK Pg.2 True
    47:42:79> a(): TX: 03<CR>
    47:42:92> a(): RX: 43 00 00 00 00 00 00 <CR><LF>
    47:43:10> a(): RX: 43 00 00 00 00 00 00 <CR><LF>>
    47:43:11> a(): RXMSG: 43 00 00 00 00 00 00 <CR><LF>
    47:43:15> a(): TX: 010E<CR>
    47:43:25> a(): RX: 41 0E A0 <CR><LF>
    47:43:45> a(): RX: 41 0E A0 <CR><LF>>
    47:43:47> a(): RXMSG: 41 0E A0 <CR><LF>
    47:43:72> a(): TX: 010E<CR>
    47:43:78> a(): SENSOR2_CLICK Pg.2 True
    47:43:87> a(): RX: 41 0E A2 <CR><LF>
    47:44:05> a(): RX: 41 0E A2 <CR><LF>>
    47:44:06> a(): RXMSG: 41 0E A2 <CR><LF>
    47:44:09> a(): TX: 0111<CR>
    47:44:22> a(): RX: 41 11 1B <CR><LF>
    47:44:40> a(): RX: 41 11 1B <CR><LF>>
    47:44:41> a(): RXMSG: 41 11 1B <CR><LF>
    47:44:59> a(): TX: 010E<CR>
    47:44:70> a(): RX: 41 0E 9E <CR><LF>
    47:44:90> a(): RX: 41 0E 9E <CR><LF>>
    47:44:91> a(): RXMSG: 41 0E 9E <CR><LF>
    47:44:96> a(): TX: 0111<CR>
    47:45:09> a(): RX: 41 11 1B <CR><LF>
    47:45:27> a(): RX: 41 11 1B <CR><LF>>
    47:45:28> a(): RXMSG: 41 11 1B <CR><LF>
    47:45:42> a(): TX: 010E<CR>
    47:45:52> a(): RX: 41 0E 9C <CR><LF>
    47:45:72> a(): RX: 41 0E 9C <CR><LF>>
    47:45:74> a(): RXMSG: 41 0E 9C <CR><LF>
    47:45:78> a(): TX: 0111<CR>
    47:45:92> a(): RX: 41 11 1B <CR><LF>
    47:46:10> a(): RX: 41 11 1B <CR><LF>>
    47:46:11> a(): RXMSG: 41 11 1B <CR><LF>
    47:46:25> a(): TX: 010E<CR>
    47:46:35> a(): RX: 41 0E A2 <CR><LF>
    47:46:57> a(): RX: 41 0E A2 <CR><LF>>
    47:46:58> a(): RXMSG: 41 0E A2 <CR><LF>
    47:46:71> a(): TX: 0111<CR>
    47:46:84> a(): RX: 41 11 1B <CR><LF>
    47:47:02> a(): RX: 41 11 1B <CR><LF>>
    47:47:04> a(): RXMSG: 41 11 1B <CR><LF>
    47:47:17> a(): TX: 03<CR>
    47:47:27> a(): RX: 43 00 00 00 00 00 00 <CR><LF>
    47:47:47> a(): RX: 43 00 00 00 00 00 00 <CR><LF>>
    47:47:48> a(): RXMSG: 43 00 00 00 00 00 00 <CR><LF>
    47:47:51> a(): TX: 010E<CR>
    47:47:62> a(): RX: 41 0E 9E <CR><LF>
    47:47:82> a(): RX: 41 0E 9E <CR><LF>>
    47:47:84> a(): RXMSG: 41 0E 9E <CR><LF>
    47:47:88> a(): TX: 0111<CR>
    47:48:02> a(): RX: 41 11 1C <CR><LF>
    47:48:19> a(): RX: 41 11 1C <CR><LF>>
    47:48:20> a(): RXMSG: 41 11 1C <CR><LF>
    47:48:42> a(): TX: 010E<CR>
    47:48:54> a(): RX: 41 0E 9E <CR><LF>
    47:48:72> a(): RX: 41 0E 9E <CR><LF>>
    47:48:74> a(): RXMSG: 41 0E 9E <CR><LF>
    47:48:74> a(): TX: 0111<CR>
    47:48:87> a(): RX: 41 11 1B <CR><LF>
    47:49:05> a(): RX: 41 11 1B <CR><LF>>
    47:49:06> a(): RXMSG: 41 11 1B <CR><LF>
    47:49:22> a(): TX: 010E<CR>
    47:49:32> a(): RX: 41 0E A2 <CR><LF>
    47:49:53> a(): RX: 41 0E A2 <CR><LF>>
    47:49:55> a(): RXMSG: 41 0E A2 <CR><LF>
    47:49:59> a(): TX: 0111<CR>
    47:49:73> a(): RX: 41 11 1C <CR><LF>
    47:49:90> a(): RX: 41 11 1C <CR><LF>>
    47:49:91> a(): RXMSG: 41 11 1C <CR><LF>
    47:50:10> a(): TX: 010E<CR>
    47:50:20> a(): RX: 41 0E A4 <CR><LF>
    47:50:40> a(): RX: 41 0E A4 <CR><LF>>
    47:50:41> a(): RXMSG: 41 0E A4 <CR><LF>
    47:50:46> a(): TX: 0111<CR>
    47:50:60> a(): RX: 41 11 1B <CR><LF>
    47:50:77> a(): RX: 41 11 1B <CR><LF>>
    47:50:78> a(): RXMSG: 41 11 1B <CR><LF>
    47:50:95> a(): TX: 010E<CR>
    47:51:05> a(): RX: 41 0E A4 <CR><LF>
    47:51:25> a(): RX: 41 0E A4 <CR><LF>>
    47:51:26> a(): RXMSG: 41 0E A4 <CR><LF>
    47:51:27> a(): TX: 0111<CR>
    47:51:40> a(): RX: 41 11 1B <CR><LF>
    47:51:57> a(): RX: 41 11 1B <CR><LF>>
    47:51:58> a(): RXMSG: 41 11 1B <CR><LF>
    47:51:77> a(): TX: 03<CR>
    47:51:87> a(): RX: 43 00 00 00 00 00 00 <CR><LF>
    47:52:07> a(): RX: 43 00 00 00 00 00 00 <CR><LF>>
    47:52:08> a(): RXMSG: 43 00 00 00 00 00 00 <CR><LF>
    47:52:11> a(): TX: 010E<CR>
    47:52:22> a(): RX: 41 0E A2 <CR><LF>
    47:52:42> a(): RX: 41 0E A2 <CR><LF>>
    47:52:44> a(): RXMSG: 41 0E A2 <CR><LF>
    47:52:49> a(): TX: 0111<CR>
    47:52:80> a(): RX: NO DATA<CR><LF>>
    47:52:95> a(): TX: 010E<CR>
    47:53:09> a(): RX: 41 0E 9C <CR><LF>
    47:53:27> a(): RX: 41 0E 9C <CR><LF>>
    47:53:28> a(): RXMSG: 41 0E 9C <CR><LF>
    47:53:32> a(): TX: 0111<CR>
    47:53:45> a(): RX: 41 11 1B <CR><LF>
    47:53:70> a(): RX: 41 11 1B <CR><LF>>
    47:53:71> a(): RXMSG: 41 11 1B <CR><LF>
    47:53:85> a(): TX: 010E<CR>
    47:53:95> a(): RX: 41 0E A0 <CR><LF>
    47:54:17> a(): RX: 41 0E A0 <CR><LF>>
    47:54:18> a(): RXMSG: 41 0E A0 <CR><LF>
    47:54:22> a(): TX: 0111<CR>
    47:54:34> a(): RX: 41 11 1B <CR><LF>
    47:54:52> a(): RX: 41 11 1B <CR><LF>>
    47:54:54> a(): RXMSG: 41 11 1B <CR><LF>
    47:54:74> a(): TX: 010E<CR>
    47:54:84> a(): RX: 41 0E A2 <CR><LF>
    47:55:04> a(): RX: 41 0E A2 <CR><LF>>
    47:55:05> a(): RXMSG: 41 0E A2 <CR><LF>
    47:55:09> a(): TX: 0111<CR>
    47:55:22> a(): RX: 41 11 1B <CR><LF>
    47:55:40> a(): RX: 41 11 1B <CR><LF>>
    47:55:41> a(): RXMSG: 41 11 1B <CR><LF>
    47:55:54> a(): TX: 010E<CR>
    47:55:70> a(): RX: 41 0E 9E <CR><LF>
    47:55:84> a(): RX: 41 0E 9E <CR><LF>>
    47:55:87> a(): RXMSG: 41 0E 9E <CR><LF>
    47:55:90> a(): TX: 0111<CR>
    47:56:03> a(): RX: 41 11 1B <CR><LF>
    47:56:20> a(): RX: 41 11 1B <CR><LF>>
    47:56:21> a(): RXMSG: 41 11 1B <CR><LF>
    47:56:36> a(): TX: 03<CR>
    47:56:45> a(): RX: 43 00 00 00 00 00 00 <CR><LF>
    47:56:71> a(): RX: 43 00 00 00 00 00 00 <CR><LF>>
    47:56:72> a(): RXMSG: 43 00 00 00 00 00 00 <CR><LF>
    47:56:75> a(): TX: 010E<CR>
    47:56:85> a(): RX: 41 0E A4 <CR><LF>
    47:57:05> a(): RX: 41 0E A4 <CR><LF>>
    47:57:06> a(): RXMSG: 41 0E A4 <CR><LF>
    47:57:10> a(): TX: 0111<CR>
    47:57:22> a(): RX: 41 11 1B <CR><LF>
    47:57:40> a(): RX: 41 11 1B <CR><LF>>
    47:57:41> a(): RXMSG: 41 11 1B <CR><LF>
    47:57:56> a(): TX: 010E<CR>
    47:57:70> a(): RX: 41 0E A2 <CR><LF>
    47:57:87> a(): RX: 41 0E A2 <CR><LF>>
    47:57:88> a(): RXMSG: 41 0E A2 <CR><LF>
    47:57:92> a(): TX: 0111<CR>
    47:58:05> a(): RX: 41 11 1B <CR><LF>
    47:58:25> a(): RX: 41 11 1B <CR><LF>>
    47:58:26> a(): RXMSG: 41 11 1B <CR><LF>
    47:58:40> a(): TX: 010E<CR>
    47:58:50> a(): RX: 41 0E A0 <CR><LF>
    47:58:70> a(): RX: 41 0E A0 <CR><LF>>
    47:58:71> a(): RXMSG: 41 0E A0 <CR><LF>
    47:58:77> a(): TX: 0111<CR>
    47:58:90> a(): RX: 41 11 1B <CR><LF>
    47:59:07> a(): RX: 41 11 1B <CR><LF>>
    47:59:08> a(): RXMSG: 41 11 1B <CR><LF>
    47:59:22> a(): TX: 010E<CR>
    47:59:32> a(): RX: 41 0E A2 <CR><LF>
    47:59:52> a(): RX: 41 0E A2 <CR><LF>>
    47:59:54> a(): RXMSG: 41 0E A2 <CR><LF>
    47:59:58> a(): TX: 0111<CR>
    47:59:70> a(): RX: 41 11 1B <CR><LF>
    47:59:89> a(): RX: 41 11 1B <CR><LF>>
    47:59:91> a(): RXMSG: 41 11 1B <CR><LF>
    48:00:05> a(): TX: 010E<CR>
    48:00:14> a(): RX: 4
    48:00:16> a(): RX: 41 0E 9E <CR><LF>
    48:00:37> a(): RX: 41 0E 9E <CR><LF>>
    48:00:38> a(): RXMSG: 41 0E 9E <CR><LF>
    48:00:42> a(): TX: 0111<CR>
    48:00:55> a(): RX: 41 11 1B <CR><LF>
    48:00:72> a(): RX: 41 11 1B <CR><LF>>
    48:00:74> a(): RXMSG: 41 11 1B <CR><LF>
    48:00:87> a(): TX: 03<CR>
    48:00:97> a(): RX: 43 00 00 00 00 00 00 <CR><LF>
    48:01:17> a(): RX: 43 00 00 00 00 00 00 <CR><LF>>
    48:01:18> a(): RXMSG: 43 00 00 00 00 00 00 <CR><LF>
    48:01:21> a(): TX: 010E<CR>
    48:01:31> a(): RX: 41 0E 9E <CR><LF>
    48:01:52> a(): RX: 41 0E 9E <CR><LF>>
    48:01:57> a(): RXMSG: 41 0E 9E <CR><LF>
    48:01:59> a(): TX: 0111<CR>
    48:01:75> a(): RX: 41 11 1B <CR><LF>
    48:01:90> a(): RX: 41 11 1B <CR><LF>>
    48:01:91> a(): RXMSG: 41 11 1B <CR><LF>
    48:02:10> a(): TX: 010E<CR>
    48:02:20> a(): RX: 41 0E 9A <CR><LF>
    48:02:40> a(): RX: 41 0E 9A <CR><LF>>
    48:02:41> a(): RXMSG: 41 0E 9A <CR><LF>
    48:02:48> a(): TX: 0111<CR>
    48:02:72> a(): RX: 41 11 1B <CR><LF>
    48:02:79> a(): RX: 41 11 1B <CR><LF>>
    48:02:81> a(): RXMSG: 41 11 1B <CR><LF>
    48:02:96> a(): TX: 010E<CR>
    48:03:05> a(): RX: 41 0E A2 <CR><LF>
    48:03:25> a(): RX: 41 0E A2 <CR><LF>>
    48:03:26> a(): RXMSG: 41 0E A2 <CR><LF>
    48:03:30> a(): TX: 0111<CR>
    48:03:43> a(): RX: 41 11 1B <CR><LF>
    48:03:60> a(): RX: 41 11 1B <CR><LF>>
    48:03:62> a(): RXMSG: 41 11 1B <CR><LF>
    48:03:81> a(): TX: 010E<CR>
    48:04:05> a(): RX: NO DATA<CR><LF>>
    48:04:07> a(): TX: 0111<CR>
    48:04:20> a(): RX: 41 11 1B <CR><LF>
    48:04:37> a(): RX: 41 11 1B <CR><LF>>
    48:04:39> a(): RXMSG: 41 11 1B <CR><LF>
    48:04:52> a(): TX: 010E<CR>
    48:04:71> a(): RX: 41 0E 9C <CR><LF>
    48:04:82> a(): RX: 41 0E 9C <CR><LF>>
    48:04:85> a(): RXMSG: 41 0E 9C <CR><LF>
    48:04:88> a(): TX: 0111<CR>
    48:05:01> a(): RX: 41 11 1B <CR><LF>
    48:05:20> a(): RX: 41 11 1B <CR><LF>>
    48:05:21> a(): RXMSG: 41 11 1B <CR><LF>
    48:05:35> a(): TX: 03<CR>
    48:05:50> a(): RX: 43 00 00 00 00 00 00 <CR><LF>
    48:05:70> a(): RX: 43 00 00 00 00 00 00 <CR><LF>>
    48:05:72> a(): RXMSG: 43 00 00 00 00 00 00 <CR><LF>
    48:05:75> a(): TX: 010E<CR>
    48:05:85> a(): RX: 41 0E 96 <CR><LF>
    48:06:07> a(): RX: 41 0E 96 <CR><LF>>
    48:06:08> a(): RXMSG: 41 0E 96 <CR><LF>
    48:06:12> a(): TX: 0111<CR>
    48:06:25> a(): RX: 41 11 1B <CR><LF>
    48:06:42> a(): RX: 41 11 1B <CR><LF>>
    48:06:44> a(): RXMSG: 41 11 1B <CR><LF>
    48:06:57> a(): TX: 010E<CR>
    48:06:72> a(): RX: 41 0E 9A <CR><LF>
    48:06:89> a(): RX: 41 0E 9A <CR><LF>>
    48:06:91> a(): RXMSG: 41 0E 9A <CR><LF>
    48:06:96> a(): TX: 0111<CR>
    48:07:09> a(): RX: 41 11 1B <CR><LF>
    48:07:27> a(): RX: 41 11 1B <CR><LF>>
    48:07:28> a(): RXMSG: 41 11 1B <CR><LF>
    48:07:42> a(): TX: 010E<CR>
    48:07:52> a(): RX: 41 0E A2 <CR><LF>
    48:07:73> a(): RX: 41 0E A2 <CR><LF>>
    48:07:74> a(): RXMSG: 41 0E A2 <CR><LF>
    48:07:74> a(): TX: 0111<CR>
    48:07:87> a(): RX: 41 11 21 <CR><LF>
    48:08:04> a(): RX: 41 11 21 <CR><LF>>
    48:08:06> a(): RXMSG: 41 11 21 <CR><LF>
    48:08:22> a(): TX: 010E<CR>
    48:08:32> a(): RX: 41 0E C0 <CR><LF>
    48:08:52> a(): RX: 41 0E C0 <CR><LF>>
    48:08:54> a(): RXMSG: 41 0E C0 <CR><LF>
    48:08:58> a(): TX: 0111<CR>
    48:08:72> a(): RX: 41 11 1F <CR><LF>
    48:08:89> a(): RX: 41 11 1F <CR><LF>>
    48:08:90> a(): RXMSG: 41 11 1F <CR><LF>
    48:09:09> a(): TX: 010E<CR>
    48:09:19> a(): RX: 41 0E C8 <CR><LF>
    48:09:39> a(): RX: 41 0E C8 <CR><LF>>
    48:09:40> a(): RXMSG: 41 0E C8 <CR><LF>
    48:09:45> a(): TX: 0111<CR>
    48:09:59> a(): RX: 41 11 20 <CR><LF>
    48:09:78> a(): RX: 41 11 20 <CR><LF>>
    48:09:79> a(): RXMSG: 41 11 20 <CR><LF>
    48:09:95> a(): TX: 03<CR>
    48:10:06> a(): RX: 43 00 00 00 00 00 00 <CR><LF>
    48:10:25> a(): RX: 43 00 00 00 00 00 00 <CR><LF>>
    48:10:26> a(): RXMSG: 43 00 00 00 00 00 00 <CR><LF>
    48:10:30> a(): TX: 010E<CR>
    48:10:40> a(): RX: 41 0E C4 <CR><LF>
    48:10:60> a(): RX: 41 0E C4 <CR><LF>>
    48:10:62> a(): RXMSG: 41 0E C4 <CR><LF>
    48:10:75> a(): TX: 0111<CR>
    48:10:88> a(): RX: 41 11 20 <CR><LF>
    48:11:07> a(): RX: 41 11 20 <CR><LF>>
    48:11:08> a(): RXMSG: 41 11 20 <CR><LF>
    48:11:22> a(): TX: 010E<CR>
    48:11:32> a(): RX: 41 0E C4 <CR><LF>
    48:11:52> a(): RX: 41 0E C4 <CR><LF>>
    48:11:55> a(): RXMSG: 41 0E C4 <CR><LF>
    48:11:55> a(): TX: 0111<CR>
    48:11:71> a(): RX: 41 11 20 <CR><LF>
    48:11:87> a(): RX: 41 11 20 <CR><LF>>
    48:11:89> a(): RXMSG: 41 11 20 <CR><LF>
    48:12:02> a(): TX: 010E<CR>
    48:12:12> a(): RX: 41 0E C4 <CR><LF>
    48:12:32> a(): RX: 41 0E C4 <CR><LF>>
    48:12:35> a(): RXMSG: 41 0E C4 <CR><LF>
    48:12:35> a(): TX: 0111<CR>
    48:12:47> a(): RX: 41 11 20 <CR><LF>
    48:12:70> a(): RX: 41 11 20 <CR><LF>>
    48:12:71> a(): RXMSG: 41 11 20 <CR><LF>
    48:12:85> a(): TX: 010E<CR>
    48:13:00> a(): RX: 41 0E C4 <CR><LF>
    48:13:17> a(): RX: 41 0E C4 <CR><LF>>
    48:13:18> a(): RXMSG: 41 0E C4 <CR><LF>
    48:13:18> a(): TX: 0111<CR>
    48:13:32> a(): RX: 41 11 25 <CR><LF>
    48:13:49> a(): RX: 41 11 25 <CR><LF>>
    48:13:50> a(): RXMSG: 41 11 25 <CR><LF>
    48:13:75> a(): TX: 010E<CR>
    48:13:85> a(): RX: 41 0E CE <CR><LF>
    48:14:07> a(): RX: 41 0E CE <CR><LF>>
    48:14:08> a(): RXMSG: 41 0E CE <CR><LF>
    48:14:12> a(): TX: 0111<CR>
    48:14:25> a(): RX: 41 11 1C <CR><LF>
    48:14:44> a(): RX: 41 11 1C <CR><LF>>
    48:14:45> a(): RXMSG: 41 11 1C <CR><LF>
    48:14:63> a(): TX: 03<CR>
    48:14:75> a(): RX: 43 00 00 00 00 00 00 <CR><LF>
    48:14:94> a(): RX: 43 00 00 00 00 00 00 <CR><LF>>
    48:14:95> a(): RXMSG: 43 00 00 00 00 00 00 <CR><LF>
    48:14:99> a(): TX: 010E<CR>
    48:26:30> a(): COM_MONITOR_DELAY reached
    48:33:38> a(): RX: ?<CR><LF>>
    48:33:39> a(): wThread2(): _resetDevice = true, continue
    48:41:33> a(): closeComPort(): COM port closed
    48:41:33> a(): updateComStatusInfo(): Serial connection down
    48:41:40> a(): wThread2() exiting
    48:41:40> a(): wThread1() exiting
    I installed my carpc into my pet Kangaroo, mate.
  6. #26
    VENDOR - Centrafuse Jan_RedGTiVR6's Avatar
    May 2008
    Are you still experiencing this issue with 2.0 RC7?
    Jan Bennett
    Centrafuse Support
  7. #27
    Sep 2007
    Russia, Moscow
    I will look for it tomorrow and of course I'll post the answer.
    I will keep you up to date.
  1. can some one recomend a OBD II reader
    By crash893 in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 05-05-2011, 05:55 PM
  2. Confused about OBD II
    By tom2112 in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 10-19-2007, 01:06 AM
  3. OBD II RS232 or USB Interface
    By bklynkaos in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 01-24-2006, 11:42 AM
  4. OBD II Interface with Software
    By cpeek in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 02-07-2004, 12:53 AM
  5. obd II datalogger building and software
    By backpack09 in forum Off Topic
    Last Post: 08-22-2002, 08:03 PM
