Some of my albums play out of order but I cannot verify if they worked in 1.5 either.
I will be looking into it soon, as well as other issues with my id3 tags.
I noticed today that track sorting does not work (at least for me). It used to work in prior versions with same music files I am testing.
If I turn the SORT BY TRACK feature ON, then it will play files in alphabetical order (go figure). And if I turn that feature OFF, it seems to sort by some strange nonsense order.
Anyone reproduced this bug? Have not heard anyone mention it.
2002 Honda CR-V
Spent so far: $1105.90
...or even Listen to my music
B Smoov
Project Status: 90% Complete
Next Step: TIVO for Radio
Ampie Case :: MII10000 Mobo :: M1-ATX PSU :: 512MB RAM :: 2.5" HD, 60GB, 5400rpm, 16MB Buffer :: DWW-700H :: Centrafuse
i noticed this too. some of my albums are sorted alphabetically when i checked the id3 tags and they have the track numbers. i haven't figured out why yet but i'll post if i do...
Has a bug been filed on this? Anyone figure out the root cause? I've yet to really investigate but its pretty annoying so id like to make sure it gets fixed in the next version.
B Smoov
I checked out some albums that I know sort incorrectly in CF using Tag & Rename and noticed the ID3V2 Tag lists the Track# as ##/## as in "Track ## of ## Tracks"...
The tracks that do sort correctly have the Track# field of the ID3v2 tag set to simply ## as opposed to ##/##
Reposting this as a bug
EDIT: I think iTunes does this to the ID3 tags, as it has the "Track ## of ##" option. Do you both use iTunes?
B Smoov
yes, that is it!! i removed the /## from one of my album's that wasn't sorting correctly and rebuilt my library and now it is correct. thanks for fixing this, have you put it in the proper bugs section so it can be fixed in 1.7?
EDIT: I do use iTunes, and i see in the comments that these files were encoded by iTunes so that seems to be the culprit.
That is strange. none of my MP3s have track number as ##/## (I always clean that out so it shows only ##), yet my sorting is not correct. Will have to test this again!
2002 Honda CR-V
That is very interresting... Both the ID3v1 and ID3v2 tags are set correctly?Originally Posted by justintime
B Smoov
Mine in sorting backwards by track number. Using ID3v1 tags only.
1984 BMW 323i (E30)
[==========] 90%
EPIA MII10000
256MB RAM
40GB 2,5" HD
Lilliput 7" TS
Hacked Travla C134
Haicom CF GPS
i had an album sort backwards... i assumed it was the same issue but probably not... either way i'd investigate and post a bug under Media Bugs
B Smoov
