Nevermid I figured it out.
David: How can I disable the visulizations? On the m2 12k the visuls gives problems. When I select full screen I can not get out of it unless I quite centrefuse by control, alt, delete. I know you mentioned that the via boards was not handling the visuals well that's why I rather remove them.
Opus case. MB 899 core duo 2.0ghz
Dual vga out, 400 gb hard drive, Centrefuse front end
zapco 1000.4 for zapco 6.5 componets
zapco 1100.1 for 2 13" W6.
Can you share with us how you did this? I've racked my brain trying to figure it out, and I've ended up just moving the .vis files to a subfolder. Now I have to click 5 times to get back to album art if I click by mistake. no lock up though...![]()
I'll tell you if you trade your car for the informationOriginally Posted by CTS_V
j/k, I don't know how it's done but I love you car.
lease is up July 7...
What do I get next? Must be:
4 door, assembled in North America, under $75k - Work requirements
Stick and RWD/AWD - My requirements
any suggestions?
edit: Mbai2, your install is absolutely gorgeous, nice work and nice ride.
Hmm...not many nice cars fit those requirements. The only one I can think of is the CTS-V. The rest are either too expensive or too cheap.Originally Posted by CTS_V
I removed all of the files in the visual folder except for the config file. It is located in //flux media/centrefuse/visuals.Originally Posted by CTS_V
