not sure which section these would fall under.. but
1 the program needs to only allow 1 instance. it should not load itsself the second time if attempted.. or make this an option.. it gets really annoying when you have to click off 100's of the ini data not saved messages.
2 when in navigator , if you open a dialog. and a voice prompt comes up.. it hides the dialog and you cant do anything inside of cf..... all dialogs should be forced to be always on top.. i have noticed this happen in the media player, and in the settings menu... this happens if i have a dialog open and the program is about to tell meabout a turn, or the signal low message..
