Brilliant!
Thanks Zorro, I'll try this out at lunch. I'm happy to see that you are supporting the CF crowd, thanks to you, david and eric for a fantastic product (and anyone else i missed).
Originally Posted by zorro
This is the behaviour if you're using Broadcom (Widcomm) drivers under version 3.0 (see also http://phoco.net/default.aspx?goto=content&id=stacks).
Sure you have no problems with all the other applications coz none of them supports browsing / pairing with BT devices
If you can't swap the BT stack for now, you have to setup the port used using the Extended Configurator. The website @ http://phoco.net has some flash movies which show the handling of it.
For such (very common) problems please visit http://phoco.net and it's forums where most of the issuse were explained and discussed in detail.
Skinning to go... VisualDesigner2!
Brilliant!
replicant
Audi A4 (flickr pics)
Ive noticed the same problem with the web browser as in 1.6. I believe that the issue was brought up before but i dont know if it ever got fixed, the scroll buttons are reversed. check the image.
that one is a 5 minute fix in either the xml's or the graphics...
I think it could be right...
For consumer products it's the right methodology.
I've found two simple bugs...
After removing CF 1.6, I installed RC1 without deleting folders...
When I ran CF, it showed a blank dialog box with a blank button that closes CF when clicked.
So I deleted Fluxmedia folder and installed again. It's working fine now.
The secound one is related to the algorithm for browsing media.
It's a very common thing (I'm programmer too).
When you are at the first row and press |< or at the last row and press >|, it refresh the list in different places.
Try pressing >| at the last row and then press |< back. It will show different songs.
The GPS did not work because the object did not register due to some issue on your system... Missing runtime files of some kind, not sure... I already include all the VC71 runtimes in my MSI and the rest should be on a good install of XP SP2Originally Posted by Maximus
david
Just on initial install, it looks pretty good, but when embedding iGuidance 2.1.3 with iGSkinner 3.5 (Yes, i'm using the old one), it looks right when iGuidance is NOT fullscreen within CF, but, when you go fullscreen, it cuts off the bottom, specifically the area a few pixels below the mute button.
All I did was change the 'NOTEPAD' entry in the external.xml file to point to my iGSkinner install, and then changed the button entry to point to iGuidance instead of NOTEPAD
On the bright side, iGuidance seems to work fine when embedded, other than the cutoff issue, which may (now that I think about it) be due to the fact that there's the bar on the top of the screen.
I'm running 800x600, with CF set to that, so it's possible that the pixel size settings are off.
music pauses when exiting the notepad. haven't tried other external apps yet.
Had this problem with 1.6 also. Wasn't sure if it was just my system.Originally Posted by Jahntassa
Couldn't tell you from my end, I went from 1.4 to 1.7 due to not being able to install 1.5, and the embedding issues I heard of in 1.6Originally Posted by piyaca
