Page 3 of 7 FirstFirst 1234567 LastLast
Results 21 to 30 of 66
Thread: Centrafuse XLE RC1 Unknown Bugs
  1. #21
    Variable Bitrate bishooman's Avatar
    Jan 2006
    Kuwait
    sorry but another one
    weather plugin is not showing images
    this the error log
    Code:
    01/08/2006 12:36:05 AM
    Could not find a part of the path "C:\Program Files\Flux Media\Centrafuse\plugins\Weather\weatherdata\cc.xml".
       at System.IO.__Error.WinIOError(Int32 errorCode, String str)
       at System.IO.FileStream..ctor(String path, FileMode mode, FileAccess access, FileShare share, Int32 bufferSize, Boolean useAsync, String msgPath, Boolean bFromProxy)
       at System.IO.FileStream..ctor(String path, FileMode mode, FileAccess access, FileShare share)
       at System.Xml.XmlDocument.Save(String filename)
       at weather.weather.updateData(Boolean checkdates)
    plugins/Weather/weatherimages/.png
       at System.Drawing.Image.FromFile(String filename, Boolean useEmbeddedColorManagement)
       at System.Drawing.Image.FromFile(String filename)
       at weather.weather.loadWeather(Boolean checkdates)
    01/08/2006 12:36:31 AM
    No connection could be made because the target machine actively refused it
       at System.Net.Sockets.Socket.Connect(EndPoint remoteEP)
       at PhoneControl.PhoCoInterface.Init(Int32 pi_iPort, String pi_sHost)
       at phone.phone.buildControls()
    01/08/2006 12:36:39 AM
    01/08/2006 12:49:31 AM
    Object reference not set to an instance of an object.
       at PhoneControl.PhoCoInterface.Deinit()
       at phone.phone.closePhone()
    We Exist because there is no patch for human Stupidity !!
    We need you ALL Here !!
  2. #22
    VENDOR - Centrafuse veetid's Avatar
    Quote Originally Posted by bishooman
    this the error log
    Code:
    Does the file "C:\Program Files\Flux Media\Centrafuse\plugins\Weather\weatherdata\cc.xm l" exist? If not delete everything in the weatherdata folder and reload, to force it to redownload the latest information...
    david
  3. #23
    Mar 2006
    Hi !!!
    Some issues to improving or bug killing on CF1.7:
    - On fullscreen when playing music the mouse pointer should auto hide, it's some lame the visuals showing with the pointer on top off it. It should be like when playing videos the mouse pointer hide
    - On fullscreen when playing videos the previous button doesn't work good, if you want to play the previous video, you must leave fullscreen then hit the previous button
    - On fullscreen when playing videos, there is a little problem, when you hit the mouse button one, two or more times on the area that should apear the mini-menu, simple doesn't work you may hit like a crazy man but the menu doesn't shows. But if you hit on any place out of the mini-menu area, there isn't any problem the mini-menu shows, then the problem is other issue, the pointer is hiding then you must move it down to apears on the mini-menu to see what are you doing.
    - The best user friendly on fullscreen video/audio should be as you hit the mouse or touch the lcd screen the pointer should apear, but if you move the mouse for mistake the pointer shouldn't apears.
    - Don't know if there is any hotkeys, that simply does
    previous - play - next - fastForward
    Well next is "Control + F" i know, but what about the others basics ?
    - Still hotkeys, what about the directions keys (up - down - left - right) to control CF if you doesn't have a mouse, it should work like a tv or dvd set .
    should be very usefull
    This two last points i don't know if is already possible, if yes , forget this two
    - I have other issues but maybe David will resolve them on the next release.
    What do you think about it, David ??
    Thor
  4. #24
    Raw Wave justintime's Avatar
    Apr 2005
    Not a true bug, but would you consider adding elipsis (...) to the album name right below the album covers in the Media Manager, when it gets truncated?
    You are already doig that in the MainTitle, and it works great
    2002 Honda CR-V
    Spent so far: $1105.90
    ...or even Listen to my music
  5. #25
    Constant Bitrate 2 STanGeR's Avatar
    Aug 2005
    Terre Haute, IN
    I am having a wierd video problem also. Whenever I hibernate with a video playing in fullscreen, once I resume from hibernation, the video isn't in fullscreen anymore, it is back to the Media menu, and no matter what I do, the video will not go back into fullscreen. If I let the video finish, the next video will start in fullscreen. I am not sure if it is only me, but I didn't have this in 1.6.
  6. #26
    Apr 2005
    David, would you consider adding audible feedback to 'hold button' routines? I think would be best if they beeped like all other button's regular click function. So we know when 4 secs have passed by...
    Did not see this one mentioned in your list, as a possible enhancement.
    Thanks.
    2002 Honda CR-V
  7. #27
    Quote Originally Posted by justintime
    Thanks.
    let me find a beep and give it a shot...
    david
  8. #28
    Apr 2005
    I hope you're kidding?! I was hoping you would use the same BUTTONCLICK.MP3 file for this?!
    2002 Honda CR-V
  9. #29
    Already added it, works good...
    david
  10. #30
    FLAC coucouillu's Avatar
    Nov 2004
    FRANCE
    Quote Originally Posted by 2 STanGeR
    David already know about that.
  1. New Release, Centrafuse RC1 (1.7)
    By veetid in forum Centrafuse
    Last Post: 08-02-2006, 01:14 PM
  2. Centrafuse XLE RC1 Bugs
    By veetid in forum CF Bug Reports
    Last Post: 07-30-2006, 05:19 PM
  3. Centrafuse Known Issues
    Last Post: 07-12-2006, 04:37 PM
  4. Centrafuse 1.3 Bugs
    By rickster in forum CF Bug Reports
    Last Post: 07-26-2005, 08:51 PM
