Page 12 of 23 FirstFirst ... 2345678910111213141516171819202122 ... LastLast
Results 111 to 120 of 226
Thread: Centrafuse RC2 Bugs
  1. #111
    Lum
    Lum is offline
    Variable Bitrate Lum's Avatar
    Jan 2005
    Liverpool, England
    Found an annoying bug.
    was driving along, playing an MP3. I pressed the menu button which turned blue and nothing else happened.
    The music carried on just fine, but the UI never responded again. Had to end task CF to regain control.
    Also the following bugs are still present that have been there since 1.6
    Music is at full volume after resume from hibernate.
    Blank screen after resume from hibernate, requiring either lots of random button mashing, or a 10-15 minute wait for it to appear. The buttons still work though, so if you click in the right place, you can start/pause the music etc.
  2. #112
    Banned RPM_VR4's Avatar
    Nov 2004
    L.A.
    I'm getting a divide by 0 error when switching playlists. This is reproducible. I load one music list and two video playlists. When I startup CF, I can cycle through them all once... on the second time around a divide by 0 error pops up and clicking ok kills CF. Once again, there is no error.log file
  3. #113
    VMS
    VMS is offline
    Low Bitrate VMS's Avatar
    Apr 2006
    I hibernate everything, never had these problems. Hibernate works find, GPS comes on immediately and music starts at the volume you left it. Even if its on mute.
    Quote Originally Posted by Lum View Post
    Vehicle Media Systems
    Australia Car PCs www.vmscarpc.com.au
  4. #114
    Lum
    Lum is offline
    Jan 2005
    Liverpool, England
    Quote Originally Posted by VMS View Post
    I suspect it may be to do with me using a USB soundcard. Are you using something else like PCI or onboard?
  5. #115
    VMS
    VMS is offline
    Apr 2006
    Nah, no soundcards at the moment. My firewire soundcard is on its way so i'll see if that effects hibernate. Don't think it should though
  6. #116
    ont
    ont is offline
    Oct 2003
    After restarting CF it doesn't remember the playlist correctly. I have a mapped network drive with around 700 songs on it and load the complete library (these 700 songs). Next time I start CF there are only the first hundreds of songs in the playlist. the number of songs it remembers is random per restart, varying between 100 and 400 songs. pretty annoying
  7. #117
    May 2006
    Seattleish, WA
    XM bugs
    XM Direct in RC2 is better (it works! ), but there are some issues with the pre-buffering. A couple of bugs show up in this sequence of events:
    • Pick a station and wait for buffer to load. (load wait time already listed as a bug - even just a "buffering" message would be good)
    • Audio output is static while buffer is loading. Sounds like you're already playing back from the buffer. (suggestion: don't start playback until buffer is primed)
    • Audio playback starts, but there are two playback threads running, about 1.5 seconds apart. It sounds like one is "live" and one is delayed from the FIFO.
    • Press PAUSE. The "front" thread is paused and playback is now just from the "other" thread.
    • Switch stations
    • Once the buffer primes with the new station, BOTH playback threads start again. (interesting effect when switching from a techno mix to rock... eww)
    • Set some stations as favorites
    • Pick "FAV", select a station
    • Let play for 10 seconds, select another station
    • repeat 2 more times
    • Stations will now constantly rotate through your selections, with the buffer overlapping
    :: Mark
  8. #118
    VENDOR - Centrafuse veetid's Avatar
    Quote Originally Posted by midiwall View Post
    XM bugs
    • Switch stations
    I am looking into these issues. As for the issue of hearing two audio sources. Do you have the playback of your line in channel un-mutued? Because it should be muted and if muted, it will stay muted and Centrafuse should not be un-muting it...
    This would cause the exact problem you are having. The dual audio is hearing the buffer, which is a few seconds behind, and hearing the direct audio from the XM devices throug the un-muted playback channel at the same time...
    david
  9. #119
    Quote Originally Posted by bishooman View Post
    i found some bugs
    1- when you are playing video in full screen and you changed the skin so it will go back to media main screen when going to next vedio.
    2- if you are in media viewing photos try to go back to main change skin and hit media again and see what will happen.
    3- holding back button givs a beep after 2 sec but it just function as normal, if you changed the skin it will not give the beep at all.
    4- i can't find go to previous section hot key !!
    5- top bar of NAV, CAM, NOTEPAD, and others (i cant remeber now) should be shiftted up by 3 or 4 pixels.
    6- TV resets setting when CF restarts.
    7- if i am playing video with original Aspect Ratio enabled, when going to next or previous video i have click Aspect Ratio button twice (disable then enable) to get correct Aspect Ratio for file being played.
    I cannot reproduce your #6 or #7... When I change the aspect ratio, the new aspect ratio is applied to both the fullscreen and non-fullscreen window, it remembers when it loads the next video...
    Also the TV settings appear to save for me. After you close centrafuse are the settings you chose in the config.xml in the plugins\TV folder? Do you have error.log...
    david
  10. #120
    Jan 2004
    Last day I got a GPS lock, weird - I tryed everything and the lock came after i had gone to setup for navi and restarted CF maybe 10times, but when i was going to find a city to navi to the city I should find was caled Augustenhof, when entered Augu, there wasent anything that looked like augustenhof, but it moved the fokus to something like ap****** I should press the down button several times to find augustenhof, to make the navi, but why could the text import search dosent find it?
    My maps are from D6 - Denmark, Finland, Norway, Sweden
    Version 2005.R2.3622 - map of TeleAtlas. HLG3, Toll roads, Rural, WES2. Signed map.
    David do you want a copy of my xml files to maybe find the button stick problem?
  1. New Release, Centrafuse RC1 (1.7)
    By veetid in forum Centrafuse
    Last Post: 08-02-2006, 01:14 PM
  2. Centrafuse 1.6 Bugs
    By Mbai2 in forum CF Bug Reports
    Last Post: 05-10-2006, 11:30 AM
  3. Centrafuse 1.5 Bugs
    By veetid in forum CF Bug Reports
    Last Post: 01-14-2006, 08:03 PM
  4. Centrafuse 1.4 Bugs
    Last Post: 09-27-2005, 10:58 PM
  5. Centrafuse 1.3 Bugs
    By rickster in forum CF Bug Reports
    Last Post: 07-26-2005, 08:51 PM
