speed is not correct in nav, known issue
On more thing, it ws i imperial mode i got a lock, the normal in this contry is metric?
But why was my speed saying 20Mph, when driving 80km/h, and at 90km/h 26mph
at 60km/h it was saying -17mph?????
"playback of your line in channel un-muted"... umm, I'm confused. I have the "input line to control" defined to the XM plugin in CF, and I haven't done anything else to either mute or unmute any input. It's the only line-in in my system, and XM is the only thing on it.
Oh... I see what you're saying. But then isn't this a catch-22? The XM plugin needs to know what line to read from (so you tell it in config), but then is the plugin manager actually unmuting the line as it loads the XM plugin?
I'll play with it some more this morning. Thanks David.
:: Mark
posted some further niggles with RC2's NAV in the thread about missing NAV features...
I'll not cross post so they will stay where they are for now
John
My Nissan 200SX @ Silverstone
NOW SADLY WRITTEN OFF!
My Car's spec list + pics
Stealth CarPC fab'ing...
Same problem here. I am unable to install on my desktop even though I have uninstalled the previous version, deleted the fluxmedia folder and removed all references to "flux" and "centrafuse" from my regsitry. I saw David's explanation about version numbers, but I haven't seen any guidance for completing the install once this message is encountered. Help would be appreciated.
Dr. Ron Paul for President 2008
Hope for America - http://www.ronpaul2008.com
Who is Ron Paul? - Why do we need Ron Paul?
CarPC Newbs Start Here: All your questions answered, as if by E.S.P.
Manually deleting the Flux Media folder and sub folders should allow you to install RC2...
This will not be a problem with anymore releases, All new versions will work with your same RC2 release candidate serial number, no more "invalid license" and requesting a serial number everytime...
david
Don't know if it was already reported but the navigation does not really work for me.
when i navigate somewhere it gets the street correct but not the number.
When i put in my own address it sends me further down the street. Same when i put in other addresses of people i know
i'm using the 2006 (destinator 6) maps and i thought they did work in RC1
my destinator map resource down permanently
I just returned from a 2k mile road trip using CF RC2 the entire way and note the following:
General Impressions:
I must say I'm impressed. Pleasant surpises were stability, better sound quality and the way IG3 embedded perfectly.
David, I don't know if you did any thing more with the sound, but it seemed to be crisper. That's not to say that it couldn't still use DSP plug-in support, which I hope is on your future features list, but the sound quality is no longer a deal-killer for me.
Bugs
I encountered many of the bugs mentioned in this thread, the most annoying being the sticking key and web browser problems. I see from the update that they have been addressed or are being addressed.
I had lots of problems with XM using the XMPCR, however. The channels were very slow to load. Even then, the "ALL" portion of the channels only showed through channel 110, the "Talk" portion of the channels showed nothing and it continually forgot my favorites. I'm also unclear on what the "Refresh Channel List " setting in settings is supposed to do. If I click it a window comes up that says "Channel List Refreshing" and the window stays there until I hit OK. It seems to have no impact on the channels, however, and there's nothing contained in the settings box once I hit OK. Can someone explain how that setting works or is supposed to work?
Overall, good on yer, David and Fluxmedia!
Just saying when Centrafuse loads up, try to then load up the windows mixer and look in the playback controls... See if the line-in is un-muted, it should be muted and stay muted... Centrafuse is not un-muting it, but if it was already un-muted it might have stayed that way, then causing you too hear two audio sources...
note: If you hit pause you should not hear any audio, if you do then it's not coming from Centrafuse.. After you pause, unplug the cable from line-in, if the audio stops immedietaly, then your line is un-muted and it should not be... I have it on my list to mute the line you set to control on load of XM...
david
