Just saying when Centrafuse loads up, try to then load up the
windows mixer and look in the playback controls... See if the line-in is un-muted, it should be muted and stay muted... Centrafuse is not un-muting it, but if it was already un-muted it might have stayed that way, then causing you too hear two audio sources...
note: If you hit pause you should not hear any audio, if you do then it's not coming from Centrafuse.. After you pause, unplug the cable from line-in, if the audio stops immedietaly, then your line is un-muted and it should not be... I have it on my list to mute the line you set to control on load of XM...
david
