Page 16 of 23 FirstFirst ... 67891011121314151617181920212223 LastLast
Results 151 to 160 of 226
Thread: Centrafuse RC2 Bugs
  1. #151
    Mar 2005
    Pomona, CA
    It will still need to buffer something initially, otherwise the audio won't be upconverted to more than 2 channels, correct? I imagine that the buffer/recorded audio could be a few hundred milliseconds... was that your plan? A fraction of a second is "instant" enough for me, but you had me scared using that word as I am afraid you might lose the buffer entirely, making the upconverting 'feature' dissapear at the same time.
    I hope I was clear with my concern?
  2. #152
    May 2006
    Seattleish, WA
    Quote Originally Posted by sivart321 View Post
    My baseline for the past 6 weeks has been "A.I.M.E.E.", that app switches pretty durn quick. Right now, I'm seeing a total of about 12 seconds for CF to switch to a new channel and start playing audio.
    update: I played with this on the way in to work. I'm seeing either 9 seconds or 12 seconds. 9 seconds comes when I bounce back & forth repeatedly between two channels. If I go away from the XM plugin, and let CF sit idle for "a while" (at least an hour on my system) then come back into XM, the first channel switch will be 12 seconds. The additional 3 seconds is more than likely from something being swapped in, either via Windows or CF itself.
    :: Mark
  3. #153
    Jun 2002
    Virginia
    Quote Originally Posted by midiwall View Post
    Is anybody else having trouble getting all of the XM channels to load properly?
    I also have a couple of questions about the channel refresh setting:
    1. What does it do (yes, I know that it refreshes the channels, but why is it necessary to refresh the channels?)
    2. How often should I refresh the channels?;
    3. When I refresh the channels should I just hit OK when the refreshing channels window comes up or is the window supposed to disappear after it finishes doing what it's doing?
    Sorry if I'm being dense about this, but I'm wondering if this setting has something to do with all of my channels not loading properly.
  4. #154
    May 2006
    Seattleish, WA
    new bug...
    • Starting at XM favorites screen, with XM audio playing
    • Put system into hibernate (soft press on PC power button)
    • Resume from hibernate
    • CF restores with XM plugin showing, in FAV screen.
    • "LOADING" message comes up
    • CF is hung
    100% repeatable
    :: Mark
  5. #155
    Mar 2006
    I don't know if this is a problem with me or if it has been listed or fixed (I tried looking!) When I try to switch songs a lot it will stop playing all together... This happens roughly 30 minutes into playing and all I have to do is restart CF and reload it. This happened in RC2 and in RC1 (which I am currently using). I don't know if anyone else has experienced this problem or has any suggestions.. thanks!
  6. #156
    Jun 2006
    It's asking me for my serial number again... and when I enter it, it still doesnt get out of trial mode...
    Please help!!!
  7. #157
    Jan 2004
    This is a bug, when running in dual screens.
    The DVD, and video a starting i monitor 2, and its working fine.
    But when your are hearing music, and want to have the vis. in monitor 2, its not starting there automatic, you have 2 make a click in the vis square.
    Then the vis. a in monitor 2, and CF in monitor 1, but now you cant controle CF, but only click in the song list, you cant use any of the buttons, until you click in the vis. square again to close it.
    Also a nice future would be to move the gps to screen 2.
  8. #158
    Banned RPM_VR4's Avatar
    Nov 2004
    L.A.
    Ok, I got one. The other day I was getting a lot ot the next-track causing a FastForward issue, so I had to keep hitting play/pause in order to get it to play again instead of FFing. After doing that a bit, I got it in a state where it was playing 2 songs at the same time. One song changed with navigation/play/pause, but the other one would never pause or anything. I had to exit CF and restart it in order to make it stop playing the 2nd song.
    BTW: It's not just next-track that sticks causing FF, I have had the favorites button get stuck (causing a load of the favorites playlist) and the page-down button get stuck (causing continual scrolling/looping of the now-playing list)
    David: When can we expect a new release that doesn't have sticky buttons?
  9. #159
    VENDOR - Centrafuse veetid's Avatar
    Quote Originally Posted by RPM_VR4 View Post
    The sticky button is the only bug remaining before I release RC2.1...
    I was not able to reproduce it on a machine until last night...
    the issue can happen on any button that can be held down, so that includes volume up/down, fastforward, rewind, dim, page up/down, dim, back, and favorties...
    The mouse up event stopped firing for some reason, which is what tells the system to stop the threads from the hold fucntionality...
    I am working on it and hope to have it solved tonight...
    david
  10. #160
    Raw Wave justintime's Avatar
    Apr 2005
    That makes a lot of sense... had not made the connection that it only happened on buttons that allowed hold-down. Good detective work on that one. Looks like we will finally have a release with single click back!
    2002 Honda CR-V
    Spent so far: $1105.90
    ...or even Listen to my music
  1. New Release, Centrafuse RC1 (1.7)
    By veetid in forum Centrafuse
    Last Post: 08-02-2006, 01:14 PM
  2. Centrafuse 1.6 Bugs
    By Mbai2 in forum CF Bug Reports
    Last Post: 05-10-2006, 11:30 AM
  3. Centrafuse 1.5 Bugs
    By veetid in forum CF Bug Reports
    Last Post: 01-14-2006, 08:03 PM
  4. Centrafuse 1.4 Bugs
    Last Post: 09-27-2005, 10:58 PM
  5. Centrafuse 1.3 Bugs
    By rickster in forum CF Bug Reports
    Last Post: 07-26-2005, 08:51 PM
