Page 20 of 23 FirstFirst ... 1011121314151617181920212223 LastLast
Results 191 to 200 of 226
Thread: Centrafuse RC2 Bugs
  1. #191
    Jan 2004
    Quote Originally Posted by veetid View Post
    make sure you don't have hold and right click turned on in your touch screen drivers, this will cause issues like you are describing...
    david
    I mean that CF are showing to little, its useless in a small contry if you only get the poi thats 10km close.
    It should be 100km or more.
    IN CF:
    IN CF - BUT USING DESTINATORS OWN MENU:
  2. #192
    VENDOR - Centrafuse veetid's Avatar
    Quote Originally Posted by clemen View Post
    IN CF:
    I will check the radius... I don't set it, I left it to the default... I will look into this...
    david
  3. #193
    Raw Wave justintime's Avatar
    Apr 2005
    I had a problem with adding too many features... time for some stability
    AMEN! I have a few suggestions to improve the product, but I am keeping my mouth shut as to not disstract David from the main objective (fixing bugs).
    We all need a stable release like we need water!!!!
    2002 Honda CR-V
    Spent so far: $1105.90
    ...or even Listen to my music
  4. #194
    Right now I have it set to 25KM....
    I guess I should make this an option, most GPS software doesn't, but I can...
    What does everyone else think... What is a good POI radius...
    100km is way to large.... I don't want to see a gas station 60 miles away and think I can make it, but maybe that is why it should be configurable...
    This is also an option un-experienced users could mess with to hurt their navigation experience if they didn't understand...
    maybe only an option in an XML file...
    thoughts?
    david
  5. #195
    Raw Wave tj!2k4's Avatar
    Oct 2004
    My suggestion would be to make it an option in the GPS plugin confguration.
    One of the features I really appreciate about CF is the overall sleek, integrated setup, and the ease of setup.. not having to jump through hoops (for instance editing XML).
  6. #196
    Quote Originally Posted by tj!2k4 View Post
    config option it is then
    david
  7. #197
    FLAC ShawJohn's Avatar
    Aug 2004
    On the edge!
    this will explain where all my POI's have gone
    I regularly do 50+ mile drives (80km) so a 25km radius is no good for me
    I like the idea of setting your own radius
    Why not have a button which changes from 'SHOW All' to 'SHOW LOCAL' and have it change from say 20km to full map region. Best of both world, you could also add a setting to adjust local poi distance.
    Being able to import POI's in OV2 format directly to POI's folder NOT Favourites. Otherwise when you add a favourite, say a friends house, it makes it hard work to find amongst 30-40 other POI Favourites. This seems to be what happens with my D3 extra POI's. The 'My Favourites' option is half way down a big POI list.
  8. #198
    Oct 2004
    Canada
    OK i found that the stickey button bug can also be an advantage for my on the volume.
    for instance if i were on say low volume 1 or 2 and i wanted to go to full i would press the volume up 2 times really fast and let it get stuck. then as it gets near full volume i would press the volume up again to stop it. same with volume down if i almost home and i have the volume up i double click the volume down and the volume gets stuck and when the volume is almost at min i hit the volume down and it stops it.
    I think if this was implemented it would be very usefull to get to full volume and min volume without holding your finger on the button
  9. #199
    Apr 2005
    And that seems sooooo intuitive to me!
    Quote Originally Posted by gt__1 View Post
    2002 Honda CR-V
  10. #200
    That's funny... you found something good out of my bug... pretty cool....
    I just spent over a week tracking this bug down....
    Not a bad idea though, but it would definitely be an option you could change... Someone hits volume up and does not stop it fast enough in their decked out car and blows their windows out
    david
  1. New Release, Centrafuse RC1 (1.7)
    By veetid in forum Centrafuse
    Last Post: 08-02-2006, 12:14 PM
  2. Centrafuse 1.6 Bugs
    By Mbai2 in forum CF Bug Reports
    Last Post: 05-10-2006, 10:30 AM
  3. Centrafuse 1.5 Bugs
    By veetid in forum CF Bug Reports
    Last Post: 01-14-2006, 07:03 PM
  4. Centrafuse 1.4 Bugs
    Last Post: 09-27-2005, 09:58 PM
  5. Centrafuse 1.3 Bugs
    By rickster in forum CF Bug Reports
    Last Post: 07-26-2005, 07:51 PM
