Page 22 of 23 FirstFirst ... 121314151617181920212223 LastLast
Results 211 to 220 of 226
Thread: Centrafuse RC2 Bugs
  1. #211
    VENDOR - Centrafuse veetid's Avatar
    Quote Originally Posted by dune View Post
    Can we get a hot-fix for the sticky button issue? I've been too close to blowing out my speakers.
    I apologize... It's coming... It took me a long time to find it and fix it...
    I have it fixed and just need to package everything up....
    Check the progress reports and known issues threads for updates, I updated them tonight...
    david
  2. #212
    Low Bitrate dune's Avatar
    Dec 2003
    Dallas, Texas
    Cool, thanks for the hard work!
    tango/dune
    Infiniti QX4 2002 project (done!... for now)
  3. #213
    Raw Wave justintime's Avatar
    Apr 2005
    Quote Originally Posted by veetid View Post
    david
    Loos like you have all the really annoying bugs taken care of, plus much more. I have high hopes for this release! Hope you manage to get it out soon, and as-is!
    2002 Honda CR-V
    Spent so far: $1105.90
    ...or even Listen to my music
  4. #214
    May 2006
    Seattleish, WA
    ref: Centrafuse RC3 Release Notes
    I don't see any mention of the constant "hang on return from hiberation"? I reported it here:
    http://www.mp3car.com/vbulletin/show...48&#post903848
    :: Mark
  5. #215
    Quote Originally Posted by midiwall View Post
    I couldn't reproduce it and noone else said it happened to them... I modified some code relating to the loading dialog and was hoping it would fix your issue... We will know soon when I get this new release out, if it doesn't fix it I will get on it and figure it out...
    david
  6. #216
    May 2006
    Seattleish, WA
    david
    'k... fair 'nuff.
    Thanks David.
    :: Mark
  7. #217
    VMS
    VMS is offline
    Low Bitrate VMS's Avatar
    Apr 2006
    RC3
    Vehicle Media Systems
    Australia Car PCs www.vmscarpc.com.au
  8. #218
    Sep 2005
    Bay Area, CA
    Nav is almost useless to me because of two bugs, both in the interface that lets you choose an address to navigate to:
    1. If I try to type in a city name with a space in it, the interface refuses to scroll based on any letters after the space. For example, in CA if I type in "San Jose", it will stop at "San Bernadino" since that's the first city beginning with "San" alphabetically. I have to manually scroll to San Jose.
    2. Even worse - and this is a deal killer - only the street base names are printed, and not their type. For example, there are like 10 entries for "Almaden", all listed only as "Almaden" - without the "Blvd" or "Expr" or "St" afterward. This makes it absolutely impossible to navigate to any address on a road named "Almaden" because I have to randomly pick the correct "Almaden" from the list.
    (EDIT): To clarify, I'm using the California maps I installed from a copy of Destinator PN that I purchased.
  9. #219
    Quote Originally Posted by Merzbow View Post
    #2 is a listed known issue and I will look into #1
    david
  10. #220
    Variable Bitrate bns2000's Avatar
    Nov 2004
    Russellville, AR
    Recived this error when I pressed cancel on import cd
    See the end of this message for details on invoking
    just-in-time (JIT) debugging instead of this dialog box.
    ************** Exception Text **************
    System.NullReferenceException: Object reference not set to an instance of an object.
    at MSWEBDVDLib.IMSWebDVD.get_PlayState()
    at AxMSWEBDVDLib.AxMSWebDVD.get_PlayState()
    at centrafuse.dvd.updateInfo()
    at centrafuse.dvd.updateTimer_Tick(Object sender, EventArgs e)
    at System.Windows.Forms.Timer.OnTick(EventArgs e)
    at System.Windows.Forms.Timer.Callback(IntPtr hWnd, Int32 msg, IntPtr idEvent, IntPtr dwTime)
    ************** Loaded Assemblies **************
    mscorlib
    Assembly Version: 1.0.5000.0
    Win32 Version: 1.1.4322.573
    CodeBase: file:///c:/windows/microsoft.net/framework/v1.1.4322/mscorlib.dll
    centrafuse
    Assembly Version: 0.96.0.0
    Win32 Version: 00000.00096.00000.00000
    CodeBase: file:///C:/Program%20Files/Flux%20Media/Centrafuse/centrafuse.exe
    cfplugin
    Assembly Version: 0.0.0.0
    Win32 Version: 0.0.0.0
    CodeBase: file:///C:/Program%20Files/Flux%20Media/Centrafuse/cfplugin.DLL
    CodeBase: file:///c:/windows/assembly/gac/system.windows.forms/1.0.5000.0__b77a5c561934e089/system.windows.forms.dll
    System
    CodeBase: file:///c:/windows/assembly/gac/system/1.0.5000.0__b77a5c561934e089/system.dll
    System.Drawing
    CodeBase: file:///c:/windows/assembly/gac/system.drawing/1.0.5000.0__b03f5f7f11d50a3a/system.drawing.dll
    ReflectionCleaner
    Assembly Version: 1.0.0.0
    DESTSDKLib
    Win32 Version:
    CodeBase: file:///C:/Program%20Files/Flux%20Media/Centrafuse/DESTSDKLib.DLL
    System.Data
    CodeBase: file:///c:/windows/assembly/gac/system.data/1.0.5000.0__b77a5c561934e089/system.data.dll
    System.Xml
    CodeBase: file:///c:/windows/assembly/gac/system.xml/1.0.5000.0__b77a5c561934e089/system.xml.dll
    Bass.Net
    Assembly Version: 2.3.0.4
    Win32 Version: 2.3.0.4
    CodeBase: file:///C:/Program%20Files/Flux%20Media/Centrafuse/Bass.Net.DLL
    Xheo.Licensing
    Assembly Version: 2.1.5000.0
    Win32 Version: 2.1.5000.28
    CodeBase: file:///c:/windows/assembly/gac/xheo.licensing/2.1.5000.0__798276055709c98a/xheo.licensing.dll
    System.Web
    CodeBase: file:///c:/windows/assembly/gac/system.web/1.0.5000.0__b03f5f7f11d50a3a/system.web.dll
    System.Web.Services
    CodeBase: file:///c:/windows/assembly/gac/system.web.services/1.0.5000.0__b03f5f7f11d50a3a/system.web.services.dll
    cam
    CodeBase: file:///C:/Program%20Files/Flux%20Media/Centrafuse/Plugins/Cam/cam.dll
    obdii
    CodeBase: file:///C:/Program%20Files/Flux%20Media/Centrafuse/Plugins/OBDII/obdii.dll
    tv
    CodeBase: file:///C:/Program%20Files/Flux%20Media/Centrafuse/Plugins/TV/tv.dll
    weather
    CodeBase: file:///C:/Program%20Files/Flux%20Media/Centrafuse/Plugins/Weather/weather.dll
    AxInterop.SHDocVw
    Assembly Version: 1.1.0.0
    Win32 Version: 1.1.0.0
    CodeBase: file:///C:/Program%20Files/Flux%20Media/Centrafuse/Plugins/Web/AxInterop.SHDocVw.dll
    Interop.SHDocVw
    CodeBase: file:///C:/Program%20Files/Flux%20Media/Centrafuse/Plugins/Web/Interop.SHDocVw.DLL
    web
    CodeBase: file:///C:/Program%20Files/Flux%20Media/Centrafuse/Plugins/Web/web.dll
    Ras
    Assembly Version: 1.0.2387.32421
    Win32 Version: 1.0.2387.32421
    CodeBase: file:///C:/Program%20Files/Flux%20Media/Centrafuse/Ras.DLL
    DLink
    Assembly Version: 1.0.2395.30370
    Win32 Version: 1.0.2395.30370
    CodeBase: file:///C:/Program%20Files/Flux%20Media/Centrafuse/RadioModules/DLink/DLink.dll
    Radiator
    Assembly Version: 1.0.2395.30373
    Win32 Version: 1.0.2395.30373
    CodeBase: file:///C:/Program%20Files/Flux%20Media/Centrafuse/RadioModules/Radiator/Radiator.dll
    RadioXtreme
    Assembly Version: 1.0.2395.35974
    Win32 Version: 1.0.2395.35974
    CodeBase: file:///C:/Program%20Files/Flux%20Media/Centrafuse/RadioModules/RadioXtreme/RadioXtreme.dll
    Microsoft.DirectX.AudioVideoPlayback
    Assembly Version: 1.0.2902.0
    Win32 Version: 5.04.00.2904
    CodeBase: file:///C:/Program%20Files/Flux%20Media/Centrafuse/Microsoft.DirectX.AudioVideoPlayback.DLL
    AxInterop.MSWEBDVDLib
    Win32 Version: 1.0.0.0
    CodeBase: file:///C:/Program%20Files/Flux%20Media/Centrafuse/AxInterop.MSWEBDVDLib.DLL
    Interop.MSWEBDVDLib
    CodeBase: file:///C:/Program%20Files/Flux%20Media/Centrafuse/Interop.MSWEBDVDLib.DLL
    Accessibility
    CodeBase: file:///c:/windows/assembly/gac/accessibility/1.0.5000.0__b03f5f7f11d50a3a/accessibility.dll
    System.Management
    CodeBase: file:///c:/windows/assembly/gac/system.management/1.0.5000.0__b03f5f7f11d50a3a/system.management.dll
    Freedb
    Assembly Version: 1.0.0.1
    Win32 Version: 1.0.0.1
    CodeBase: file:///C:/Program%20Files/Flux%20Media/Centrafuse/Freedb.DLL
    ************** JIT Debugging **************
    To enable just in time (JIT) debugging, the config file for this
    application or machine (machine.config) must have the
    jitDebugging value set in the system.windows.forms section.
    The application must also be compiled with debugging
    enabled.
    For example:
    <configuration>
    <system.windows.forms jitDebugging="true" />
    </configuration>
    When JIT debugging is enabled, any unhandled exception
    will be sent to the JIT debugger registered on the machine
    rather than being handled by this dialog.
    CENTRAFUSE™ From Flux Media
    The Ultimate Infotainment Interface
    Download V1.20 from there site now!!!!
    Download the new 2.0 RC1 From here Linky
  1. New Release, Centrafuse RC1 (1.7)
    By veetid in forum Centrafuse
    Last Post: 08-02-2006, 12:14 PM
  2. Centrafuse 1.6 Bugs
    By Mbai2 in forum CF Bug Reports
    Last Post: 05-10-2006, 10:30 AM
  3. Centrafuse 1.5 Bugs
    By veetid in forum CF Bug Reports
    Last Post: 01-14-2006, 07:03 PM
  4. Centrafuse 1.4 Bugs
    Last Post: 09-27-2005, 09:58 PM
  5. Centrafuse 1.3 Bugs
    By rickster in forum CF Bug Reports
    Last Post: 07-26-2005, 07:51 PM
