i found some bugs
1- when you are playing
video in full screen and you changed the skin so it will go back to media main screen when going to next vedio.
2- if you are in media viewing photos try to go back to main change skin and hit media again and see what will happen.
3- holding back button givs a beep after 2 sec but it just function as normal, if you changed the skin it will not give the beep at all.
4- i can't find go to previous section hot key !!
5- top bar of NAV, CAM, NOTEPAD, and others (i cant remeber now) should be shiftted up by 3 or 4 pixels.
6- TV resets setting when CF restarts.
7- if i am playing video with original Aspect Ratio enabled, when going to next or previous video i have click Aspect Ratio button twice (disable then enable) to get correct Aspect Ratio for file being played.
