Page 2 of 2 FirstFirst 12
Results 11 to 17 of 17
Thread: GPS Bug
  1. #11
    Sep 2005
    Pomona, CA
    I'm noticing that the GPS is very unpredictable in this manner for me as well. I have mine go into hibernation each time, and sometimes when it resumes, it doesn't lock onto any satellites at all in CF. Sometimes it takes a minute or 2, sometimes it's quick, within 30 seconds. I'm not sure the issue on this, but I'll continue to try to get a good repro...
    Carputer Progress:
    Re-do fabrication of screen [DONE]
    Add mini-USB and micro-USB power from M2-ATX [DONE]
    Teardown PC [100%]
    Add HDMI > VGA converter [0%]
  2. #12
    VENDOR - Centrafuse veetid's Avatar
    a new navigation engine will be in the next release that will hopefully improve the receiver connection issues...
    it should have the SiRF issues fixed for sure...
    david
  3. #13
    Sep 2005
    Pomona, CA
    Thanks for the update, looking forward to it.
    It's only been recently that it had issues. Like today, when I booted up coming home from work, CF didn't connect to the receiver (I checked XPort and it had GPS info coming in) until I slowed down after about 10 minutes of driving, when I was almost at my destination. I've noticed a lot of time it updates once I slow down or stop after moving for a little while (5+ minutes, maybe?).
    I figured out that my GPS was interfering with my Bluetooth (both using COM ports), so that was the problem I was having. I have disabled the bluetooth on my phone and it works much better now.
    Carputer Progress:
    Teardown PC [100%]
  4. #14
    Glasgow
    i still have this issue in 1.13 am i the only on or is there others.
    Works fin on clean start but when i resume from hibernation i cant get a lock and if i do it only lasts a few mins.
  5. #15
    I will add code to close GPS port and reopen it on resume from hibernation/standby and I believe this will fix your issue...
    I don't have the issue, but the extra code will not hurt anything...
    david
  6. #16
    Glasgow
    thanks david!
  7. #17
    Glasgow
    just an update on this
    I have tried using xport with no luck and think i have hit another bug.
    When the destinator pauses as if i am stuck in the same location doing the same speed etc, i go to settings and change the port to another port given by "xport", when i go back to the nav screen nothing has updated other than it switches to 3d / night view.
    When i do a restart and change the port the gps works and works great until about 5 mins into my journey it then just pauses again. I have checked to see fi the gps still has a signal when it pauses and it does.
    Not got a clue what to do with this one.
  1. PPC Car GPS and MP3 mini How To
    By hotrod_nut in forum General Hardware Discussion
    Last Post: 02-25-2008, 01:24 PM
  2. Replies: 6
    Last Post: 02-04-2006, 09:22 AM
  3. My GPS scenario & Bluetooth quest.
    By gizak in forum GPS
    Last Post: 04-12-2005, 12:11 PM
  4. Replies: 8
    Last Post: 03-26-2005, 10:29 AM
  5. few gps questions
    By fuctup in forum GPS
    Last Post: 03-02-2005, 01:40 AM
