I do. Same exact thing. After coming out of sleep it won't lock onto any sats until the PC has been restarted.
i've only recently noticed this bug,
first of when i turn of te pc i turn it off, no hirbirnation or anything fancy,
i click on the NAV button a wait, what started of as an odd occourance is now constance occurance, the GPG will not lock on any sat's ( i normally get 8 or 9 ) i restared the pc a few times and then i locks onto the sat's , i do not knwo why this happens....
Anyone else get this problem?
Use Xport3, it fixes the problem
I found this issue and working on a fix...
I want to get it into RC3, all depends on if Destinator gets it to me today, which is going by fast...
david
hmmm Xport3 , never heard of it, only using com port 3 at the mo. i had alot of trouble geeting the GPS to work so being honest i dont want to mess about wit it . But hey at least i know i'm not te only one and a fix is on thte way , Yay to Dave. when ever you come to ireland i'll buy you a print m8 ;D
This has been fixed and will be in RC3...
david
i have the same problem but not on waking from sleep mode. I have the Globalsat BU-353 gps receiver and when i turn on the pc it doesn't necessarily lock to satellites every time i open centafuse. instead when i use the gpsinfo app it locks to 8-9 satellites. So when i have this lock problem i first open gpsinfo then close it and enter centrafuse.
i only use nmea mode because sirf doesn't work at all but it is not stable.
