David, no idea what this error log means? This has been happening to me a lot lately. Happens listening to single albums, individual tracks, and 700-song playlists.
I know this has been brought up before but I didn't see it on a quick scan of the bug reports.
It doesn't seem to follow any particular pattern, but about once every hour or so of operation I get a full audio player freeze (CF responds to commands but the sound is gone and the track counter stops moving). It always happens either upon skipping from one track to the next or upon loading another track from the library.
Today I pulled the error.log and got this:
Originally Posted by error.log
Closing CF and reopening makes it functional, but the current playlist is lost and I have to reload my selections from the library.
I couldn't find the post, but some time ago another user posted issues with song hanging on "next track" on an occasional and apparently random basis. If it's somehow pushing an index value out of range, I can't imagine this being related to some other component of my system.
I am planning on rebuilding my setup with a different motherboard soon; I'll try eliminating everything but windows and CF and see if I can recreate it.
Peugeot 206 1.4 HDi
Intel Mini-ITX Mainboard
Celeron 1.2ghz
256mb DDR-2 533
80gig 3.5" SATA HDD
Sb Live 5.1 w/ KXProject Drivers
M2-ATX
8" Lilliput TS LCD
100% installed and working :D
Interesting; I'm also using kx drivers. Can you check your error.log after this happens and see if you're returning the same error I have?
I also have a problem with sound resuming after hibernation which I suspect is a KX issue, but I think I've asked you before and you don't have this problem.
The question is, why would a driver issue cause CF to issue an error within itself? If the problem is at the driver level, I would expect CF to continue as if nothing was wrong, but in CF the timer freezes at some arbitrary value, and something is obviously corrupted since the playlist doesn't come back upon restart.
will see my error.log but iirc it does not create one... by the way kxdrivers 3138i out yesterday, maybe it fixes.. will try
Peugeot 206 1.4 HDi
Celeron 1.2ghz
256mb DDR-2 533
80gig 3.5" SATA HDD
M2-ATX
8" Lilliput TS LCD
When yours hangs, I'm assuming you have to close CF and open it again to get music back. When you do this, does it "remember" your playlist or not?
Oh, and thanks for the update, I'll get the new KX drivers too.
