Page 7 of 9 FirstFirst 123456789 LastLast
Results 61 to 70 of 89
Thread: Centrafuse RC3 Bugs
  1. #61
    Jun 2005
    MD, USA
    was thinking you may have missed this. i dont really know if its a bug so much as something i just find akward.
    Quote Originally Posted by tibby01 View Post
    how about the ability to scroll through a text entry box in settings?
    for instance, the traffic web url in settings, you cant see what is typed beyond the end of the entry box.
  2. #62
    VENDOR - Centrafuse veetid's Avatar
    I don't currently have a solution for this... I have considered making them auto scroll every few seconds, but doubt I will make it where you can move it to the right with your finger ever...
    david
  3. #63
    Newbie the_tiger's Avatar
    May 2005
    Uk
    hi david, im using cf as sys shell and my gps is running through bluetooth but wont turn on unless i dont run as sys shell and just an app, thought u said that in this version all startup apps would run still if u use as sys shell, or i might of read it wrong, also do u know if i can use my samsung d900 on the phone thing at mo i cant see my txt or send them can make phone calls and veiw my contacts
    cheers marc.
  4. #64
    FLAC coucouillu's Avatar
    Nov 2004
    FRANCE
    Graphical bug
    When adding music or video or else..in night & day skin:
    (I would add the little square near "Tiga" in the first line...like unknown charactere...
  5. #65
  6. #66
    Quote Originally Posted by the_tiger View Post
    cheers marc.
    If you are set as shell I run everything in the registry run section and the startup folder...
    your bluetooth init stuff must be somewhere else... what should I run?
    david
  7. #67
    Phone Control Moderator zorro's Avatar
    Mar 2004
    Munich, Germany
    cheers marc.
    You may check whether or not a process called BTTray is running.
    The D900 is not very compatible. It has to much inconsistncies and bugs in the firmware.
    Skinning to go... VisualDesigner2!
  8. #68
    May 2006
    Seattleish, WA
    Quote Originally Posted by veetid View Post
    NOTE: Have you tried simply disabling auto play in settings, then plugging in your USB device or HD and then setting it as a music path? This would do what you want right now I think...
    Yeah, you'd think.
    There are other gremlins at work that's still causing you to get the USB_INSERT_NOTIFY event (or whatever MSFT calls it these days).
    I have a couple of registry hacks that I could do to kill the UUID, but then Windows keeps thinking that it's a new device. I'll look at the latest Tweak UI PowerToy and see if that'll squash it in the car - though the method it uses doesn't kill it on my desktop.
    sigh.
    Windows is such a hack.
    Thanks for thinking about it David.
    :: Mark
  9. #69
    Quote Originally Posted by midiwall View Post
    Yeah, you'd think.
    sigh.
    So when you have autoplay disabled in Centrafuse it still auto loads data CD's and USB media? It's not suppose too...
    If I got rid of that, which I can, then you might have what you are looking for...
    david
  10. #70
    May 2006
    Seattleish, WA
    Yeup... There are a couple of layers of notification in Windows. Hitting the AUTOPLAY dialog box is one level, another level gets hit by tools like TweakUI and there's one at the hardware level as well.
    There's a tricky point in disabling crap where Windows will stop responding to things you care about, like stuffing a CD in a drive - not in terms of auto notify, but EVER recognizing that a CD has been inserted. This is an issue for apps like Nero or multi-CD installers which will prompt you for the next CD.
    You can certainly get low enough in Windows core that it won't pass along notify messages, but then NOTHING works.
    It's worth a shot if you think there's value in it. I'm open to being an alpha tester btw.
    :: Mark
  1. New Release Centrafuse 1.20
    By veetid in forum Centrafuse
    Last Post: 10-10-2007, 08:12 PM
  2. Centrafuse 1.6 Bugs
    By Mbai2 in forum CF Bug Reports
    Last Post: 05-10-2006, 11:30 AM
  3. Centrafuse 1.5 Bugs
    By veetid in forum CF Bug Reports
    Last Post: 01-14-2006, 08:03 PM
  4. Centrafuse 1.4 Bugs
    Last Post: 09-27-2005, 10:58 PM
  5. Centrafuse 1.3 Bugs
    By rickster in forum CF Bug Reports
    Last Post: 07-26-2005, 08:51 PM
