Page 10 of 14 FirstFirst 1234567891011121314 LastLast
Results 91 to 100 of 136
Thread: Centrafuse RC3.1 Bugs
  1. #91
    VENDOR - Centrafuse veetid's Avatar
    Quote Originally Posted by justintime View Post
    David,
    If you are not able to reproduce this yet, it might be because the default skin for web plugin does NOT cover the bottom bar where the random button is located. My skin does cover that area with fullscreen web vieweing, so apparently that is what causes the random button not to refresh correctly....
    got it... on section change I willl run an update random button function
    david
  2. #92
    May 2006
    Seattleish, WA
    I have a new one... you're gonna love this.
    So, given the bug with not being able to refresh XM channels, I replaced my satchannels.xml file with one from a fresh install of RC3 (not RC3.1). My channels are back (which of course makes sense) and I'm back to using the XM plugin instead of AIMEE. But, here's the fun...
    CF is set to startup in XM. It does, and I get audio right at startup. But, it's VERY loud and distorted. Hunting around, I can trace this back to the MIC level being set to 50 when CF loads. So, I turn down the level like I've been doing. _BUT_ when I go BACK into the XM plugin, the MIC level goes back to 50. No lie. 100% repeatable.
    As well, when I come back out to MIXER, the MIC level slider is still at 0, but the level is clearly up. I drag the slider up, then back down, and the level goes back to 0. I click back into the XM plugin and... The MIC level comes back to 50.
    What's VERY strange is that this didn't happen before. "Before" is defined as RC3 (NOT RC3.1) and before I first clicked on "refresh channel list" for the XM plugin under RC3.
    Since I first did that, I upgraded to RC3.1, so is it possible that something changed at 3.1 in how you manage the audio when a plugin gets focus?
    :: Mark
  3. #93
    Newbie bowtie4532's Avatar
    Sep 2005
    Little Rock, AR
    Quote Originally Posted by midiwall View Post
    This is the same thing that is happening to me.
    97 Firebird 7" Lilliput Touch Screen
    AMD Athlon 3800+ DSATX
    Centrafuse RC5
    PPC 6700 Sprint Phone w/Bluetooth
    Bluetooth GPS
  4. #94
    May 2006
    Seattleish, WA
    Quote Originally Posted by bowtie4532 View Post
    ! Dood... I think you're the first person to have the same XM issues that I am. David will be so happy! (seriously - I think he thinks I've been making all this up!)
    :: Mark
  5. #95
    I believe you... I will focus on these XM issues as soon as I get the next release out...
    It will be my main focus...
    david
  6. #96
    Sep 2006
    Quote Originally Posted by veetid View Post
    I will look into it, but we are not working on supporting Greek on our first initial release, but will shortly after...
    i have spoken with Destinator and everything can be worked out, just not enough time in the day!!
    david
    Thank you David, I am waiting anxiously to hear what you find out.
    Given that it is only the city names problematic, whereas everything else encodes perfectly ok (like streetnames and all the rest), I feel optimistic
    Harry
    EDIT: This is what error.log says right after trying to display the city names
    28/9/2006 11:13:10 μμ
    Object reference not set to an instance of an object.
    at DESTSDKLib.DestClass.LoadCheckedPOI()
    at GPS.menudialog.menudialog_Load(Object sender, EventArgs e)
    and this is what it reads after browsing through POIs, History etc.
    28/9/2006 11:13:25 μμ
    at DESTSDKLib.DestClass.get_CategoryName(Int32 Index)
    at GPS.menudialog.loadPOIFolders()
    28/9/2006 11:13:36 μμ
    at DESTSDKLib.DestClass.GetMapHistoryPointArray()
    at GPS.menudialog.loadMapHistory()
    28/9/2006 11:19:28 μμ
    28/9/2006 11:19:47 μμ
    at DESTSDKLib.DestClass.SaveCheckedPOI()
    at GPS.menudialog.menudialog_Closed(Object sender, EventArgs e)
    Cheers
  7. #97
    Newbie LEiPiE's Avatar
    Aug 2006
    The Netherlands
    I'm pretty positive it's related to the visuals, especially after seeing your error.log... If the music is playing, the visuals are loaded in memory and ready to render if you to the media screen...
    I known where to start looking now... great job!
    Cheered too soon I guess...
    I've disabled the music autostart, restarted CF and did absolutely nothing and now got this in the errorlog at the moment of startup:
    9/28/2006 11:56:31 PM
    at centrafuse.obdii.resetChip()
    and CF crashing with the same error after about 20 min of sitting idle...
    Trying to reproduce this behaviour, it just resorted to putting in the
    at centrafuse.main.loadVisuals()
    right after startup.
    Dunno if it's gonna crash again as it has only been a few minutes.
    I must say: with RC2 (I think) I've made a roadtrip (on a different machine also) and didn't come across this error. Didn't play any music, only used the navigation, was actually a test (needed to pickup something 300km from home and could use some navigation).
    Not much of a help I guess... isn't there a way to intercept that general .net error and have CF log what it was doing or something? Or maybe I could run it through some tracer? I have no .net experience, but I have basic debugging skills
    CarPC: "Carma" (Car Audio & Route Management) (about 70% ready)
    P4 1.8GHz / 512MB / 4GB CF
    Asus TVFM + B/W camera
    15" touchscreen 1024x768
    BU303
    2x 100Ah
    reinstalling
    And all this in a Dutch 1972 Citroën HY van called "MurpHY".
  8. #98
    Quote Originally Posted by LEiPiE View Post
    It actually is a lot of help....
    try removing the OBDII plugin by deleting the directory in the plugins folder... Then see if you still get the error...
    david
  9. #99
    I have fixed both the errors you have seen in your error.log as well as made some changes I think were causing the issue... RC4 will be out soon and we will see...
    david
  10. #100
    Mar 2006
    columbia, mo
    Delete your main.dat file, and re index your music library. Worked for me!
    ya didnt work, it just F**ked up cf :/
  1. New Release Centrafuse 1.20
    By veetid in forum Centrafuse
    Last Post: 10-10-2007, 08:12 PM
  2. Centrafuse 1.6 Bugs
    By Mbai2 in forum CF Bug Reports
    Last Post: 05-10-2006, 11:30 AM
  3. Centrafuse 1.5 Bugs
    By veetid in forum CF Bug Reports
    Last Post: 01-14-2006, 08:03 PM
  4. Centrafuse 1.4 Bugs
    Last Post: 09-27-2005, 10:58 PM
  5. Centrafuse 1.3 Bugs
    By rickster in forum CF Bug Reports
    Last Post: 07-26-2005, 08:51 PM
