Page 13 of 14 FirstFirst ... 34567891011121314 LastLast
Results 121 to 130 of 136
Thread: Centrafuse RC3.1 Bugs
  1. #121
    VENDOR - Centrafuse veetid's Avatar
    Quote Originally Posted by justintime View Post
    another known bug in 3.1 that I did not see in the RC4 Release notes:
    Title scrolling is not working correctly! Sometimes, when you play a song with a long name, the title starts scrolling in a very strabge manner... it scrolls to the end, and then it loops through the last 4 steps of the scroll procedure.
    Try it out with a long name and see what I mean. It works for SOME long names, and it fails for others. I cannot find a pattern. It was not happenning in RC3.0
    I have this listed on my known issues to look into after I get RC4 released, I cannot reproduce it...
    david
  2. #122
    Quote Originally Posted by coucouillu View Post
    I see it at each release since Version 1.6....I wondered it was due to my non standard resolution...
    It has been there... It's a stupid .NET drawing error... I will look back into it, I actually forgot about it...
    david
  3. #123
    Constant Bitrate urosbe's Avatar
    Mar 2005
    David, is it possible to put volume command to "higher priority"? I am using Via Epia SP 1.3 and I have noticed that pressing keyboard shortcut to volume up/down is working with a very short delay. Is it not so smooth. If you can do anything about it.
    Another thing I have noticed is progress bar (volume). There are cca 20 steps (||||||||||||||||||||). 0 is MIN, 20 is MAX. What I have noticed is that:
    - from 1 to 10 is MIN+1
    - from 11 to max is working great (11 is MIN+2, 12 is MIN+3... 20 is MAX).
    You should delete 2-10, because volume stays the same.
    I have the latest Vinyl drivers (6.70b) and I am using logaritmic volume.
    Uros
    System: VIA EPIA EN15000,512 MB DDRII,M2-ATX,300GB HDD,XENARC 1020TSV,VoomPC case
    USB: Powermate,WinTV+FM,WLAN 54G,Bluetooth,Haicom GPS mouse SIRFIII
    Software: Windows TinyXP Rev06+MinLogon+EWF+HORM+Centrafuse 1.2
    Honda delSol project
    CarDomain
  4. #124
    Raw Wave justintime's Avatar
    Apr 2005
    Quote Originally Posted by veetid View Post
    I switched to the regular Onys skin, and the issue manifests itself there too, but not as obvious. Only a few frame loops at the end of long name scrolling sequence.
    With my Nexus skin, it loops endlessly! It must have to do with the size of the title label, and the code behind the scrolling sequence. Just thought I'd give more pointers.
    2002 Honda CR-V
    Spent so far: $1105.90
    ...or even Listen to my music
  5. #125
    Quote Originally Posted by urosbe View Post
    Uros
    try turning logaritmic volume off with those drivers, I believe it's built in and does not need to be enabled in Centrafuse....
    david
  6. #126
    Oct 2006
    http://img413.imageshack.us/img413/6264/errorvc4.png
    If I go online and find the BASS library/program/whatever, and take the dll and put it inplace of this one, I hear the startup sound, it says "Welcome to Centrafuse, click to setup your options..." I click OK and I get:
    http://img244.imageshack.us/img244/6598/error2zj9.png
    Then I need to alt+F4 it cause it freezes there.
    Can you PLEASE upload the previous working version somewhere? It worked perfectly fine for me and the few bugs it had didn't bother me at all.
    Please...
  7. #127
    Quote Originally Posted by k00zk0 View Post
    Please...
    your install has to be messed up... files appear missing based on that stack trace...
    I would uninstall everything and manually delete ALL folders that Centrafuse has every been installed in, reboot, then install RC4 which I will be releasing maybe tonight, if not tomorrow... Waiting to hear back from a tester to verify the new version of PhoneControl that is integrated...
    david
  8. #128
    Oct 2006
    I tried installing it several times, with and without different versions of .NET framework, after reboots, after clearing stuff, nothing works.
    I JUST reformatted a day ago, my computer is running like new and it worked just fine on my last install of XP.
    I hope RC4 will work.
    The thing is it works if I replace bass.dll, but it freezes when its "loading plugins", but next time I try to start it it gives the bass.dll error again.
  9. #129
    Newbie theflygtiguy's Avatar
    Sep 2006
    Bellevue, WA
    Phone control setup throws exception
    1. Active sync is working perfectly (and connected when doing setup)
    2. i am connected through usb
    3. bluetooth is ready and is discoverable.
    i run the centrafuse phone control setup.
    1. search for bluetooth works perfectly
    2. go to next screen and it searches for serial (why no usb??)
    3. throws exception right away.
    i am using an epia m1000 with windows xp pro - all updates are done.
    Centrafuse RC3.1
    Phone is a Tmobile SDA.
    full res:
    http://www.photoalbumupload.com/albu...controljpg.JPG
    Audi A8L
    CENTRAFUSE
    EN15000, 1g DDRII | 200g Media | Bluetooth
    Rear Camera | Dvd | Edge | Nav | Internet | XM
    www.mkippen.com
  10. #130
    Sep 2006
    Bellevue, WA
    i have the full exception if you need it i can e-mail it to you.
    Audi A8L
    CENTRAFUSE
    www.mkippen.com
  1. New Release Centrafuse 1.20
    By veetid in forum Centrafuse
    Last Post: 10-10-2007, 07:12 PM
  2. Centrafuse 1.6 Bugs
    By Mbai2 in forum CF Bug Reports
    Last Post: 05-10-2006, 10:30 AM
  3. Centrafuse 1.5 Bugs
    By veetid in forum CF Bug Reports
    Last Post: 01-14-2006, 07:03 PM
  4. Centrafuse 1.4 Bugs
    Last Post: 09-27-2005, 09:58 PM
  5. Centrafuse 1.3 Bugs
    By rickster in forum CF Bug Reports
    Last Post: 07-26-2005, 07:51 PM
