Page 3 of 14 FirstFirst 12345678910111213 ... LastLast
Results 21 to 30 of 136
Thread: Centrafuse RC3.1 Bugs
  1. #21
    VENDOR - Centrafuse veetid's Avatar
    It was the first run for the updater, we have a few things to fix... It mainly seems to fail for just other locals than English because of a stupid DateTime parse...
    I will be doing more regular small updates and I did build in a way to update the updater from the udpater
    Good test run, I posted rigth above here on how to install it manually, that should work for everyone and how most will install in their cars anyway...
    david
  2. #22
    Quote Originally Posted by urosbe View Post
    This is how it looks like when there is incoming call to my mobile phone. I can still click on the buttons and Centrafuse works but center of the screen is frozen. I have to restart Centrafuse then.
    I also noticed my received/dialed/missed call lists are empty. It's the same in RC3 and RC3.1.
    When I install standalone PhoneControl.NET 1.7.3 everything works like a dream (and call lists are displayed too), even incoming call works. It has to be something between Centrafuse and Phoco.
    will you email your error.log file to support...
    Does this happen in all the skins or just the day skin?
    david
  3. #23
    Quote Originally Posted by Shonky* View Post
    1) When using the "Street/City" method to enter a new destination, pressing the right arrow after selecting the street should change the selector box to select the city. The title changes to "Select City - <street name>" but the contents still show the streets.
    2) You can't type into the street/city using a regular keyboard. It takes you to the letter you just pressed and does queue them so you can type a few letters but the delay is very short so it's not really useful.
    what speed machine and what size maps? I had it running in RC3 as a binary search, which was faster but was not exactly accurate... So people thought streets and zip codes were missing...
    So I switched it back to the loop through the list and compare method, with some improvements...
    david
  4. #24
    Jun 2002
    Virginia
    Search Returns No Results if Keyboard Used
    David, I don't know whether it's a bug or intentional on your part, but if I use a physical keyboard rather than the OSK to enter the search parameters for a song, album or artist no results are produced if the parameters contain more than one word. Here's an example:
    "Rolling Stones" keyed in with OSK: Results produced
    "Rolling Stones" keyed in with physical keyboard: No results produced
    "Stones" keyed in with physical keyboard: Results produced
    Because the problem appears to only occur with multi-word searches using the physical keyboard, I'm wondering if the space between the words is not being properly interpreted when entered by a physical keyboard.
    My apologies if this is an intended feature or has already been mentioned in the bug reports.
  5. #25
    SOS
    SOS is offline
    Jan 2005
    CF/PhoneControl issues:
    Sony Ericsson K800i & CF/PhoneControl:
    When opening the address book it is far from complete. I have 200 numbers in my phone, approx 1/4 is showing up, example, I see 2 people with K, i have 12 in the phone.
    Received calls from "hidden numbers" show with an empty number in the list, should display something like "Unknown", "Hidden" or the like.
    SMS inbox shows up empty.
    If you receive 2 SMS and donīt open the first, then when you click yes to read, you see the first, but it should go on to the next one.
    Should not also show whom the SMS is from? Kinda useless not to know
    Signal indicator is wrong, full signal on phone, 2-3 bars in CF. Seems like it only updates when CF is started, but even then itīs not correct.
    /SOS/
    XP Pro, CF 2.0-newest| Pioneer HU with 7" flip-out (EQ, Surround)
    Epia V10000 + nVidia FX5200, Opus 150w, 7" Lilliput, DVD* SlotIn, Wavelan, Bluetooth, GPS, WebCams, DVB-T
  6. #26
    SOS
    SOS is offline
    Jan 2005
    Web/Traffic/more?
    When you enter URLīs it doesnīt scrool, like traffic page, Web start page, etc.
    It getīs whatever youīre writing, but you are writing in the blind when it hits the end of the entry box.
    /SOS/
  7. #27
    Quote Originally Posted by kbreeden View Post
    weird one... never would have found that... added it to my list to check out...
    david
  8. #28
    SOS
    SOS is offline
    Jan 2005
    Skin change times still say AM/PM when my regional settings runs with 24h clock.
    Phonecontrol Incoming/Outgoing call list time is also in 12h clock (and without AM/PM - so when did the call originate :-) ).
    /SOS/
  9. #29
    May 2006
    Quote Originally Posted by veetid View Post
    david
    P4M 1.7GHz (my laptop I'm playing with)
    I have upgraded to RC3.1 now (I had to set the my regional settings to US temporarily). The search problem (3) seems fixed.
    Maps are about 105megs worth.
    The Street/City method is still broken in RC3.1.
    4) also found in the trip planner once you get to the point of adding a destination, the "+" and "-" buttons are overlaid with "Shortest Route" and "Change Map" buttons.
  10. #30
    May 2006
    Seattleish, WA
    Bugs that were reported in RC 3, are still in RC 3.1, and are not on the RC 3.1 list:
    • XM display will sometimes become "confused" and display things such as "46 - Squeeze - Top Tracks - Yes - Long Distance Runaround". "Squeeze" is actually an artist name from a different channel. This field should be {Station Name}.
    • CF is setting MIC LEVEL to 50 on startup
    • Mouse cursor is ON after return from hibernate. Looks like it's related to hibernating when an external app has focus.
    • Startup location shows blank if configured for anything other than "Main Menu". I think it's literally "anything" - it's everything I've tried so far. This is a display-only bug, and will show itself after setting the option, then exiting CF and restarting.
    :: Mark
  1. New Release Centrafuse 1.20
    By veetid in forum Centrafuse
    Last Post: 10-10-2007, 08:12 PM
  2. Centrafuse 1.6 Bugs
    By Mbai2 in forum CF Bug Reports
    Last Post: 05-10-2006, 11:30 AM
  3. Centrafuse 1.5 Bugs
    By veetid in forum CF Bug Reports
    Last Post: 01-14-2006, 08:03 PM
  4. Centrafuse 1.4 Bugs
    Last Post: 09-27-2005, 10:58 PM
  5. Centrafuse 1.3 Bugs
    By rickster in forum CF Bug Reports
    Last Post: 07-26-2005, 08:51 PM
