Page 5 of 14 FirstFirst 1234567891011121314 LastLast
Results 41 to 50 of 136
Thread: Centrafuse RC3.1 Bugs
  1. #41
    Raw Wave justintime's Avatar
    Apr 2005
    I found a bug, I think? (unless it is a 'feature')
    If you set up or connect to a web page that reloads automatically every 15 seconds, then the LOADING message appears regardless of what screen you are on. For example, I am in Media screen, but every time the web page reloads (behind my media screen) the LOADING dialog pops up in front.
    I think the LOADING dialog message should be disabled if Web is not the frontmost app.
    2002 Honda CR-V
    Spent so far: $1105.90
    ...or even Listen to my music
  2. #42
    VENDOR - Centrafuse veetid's Avatar
    Quote Originally Posted by ont View Post
    Yes, I followed your instructions and have succesfully updated CF (manually).
    I use no navigation as I use CF at home on my htpc.
    I can now reproduce this bug everytime.
    1) Start CF
    2) Go to 'Settings'
    3) Go to 'General'
    4) Click on 'Language'
    5) Choose a language and click 'Ok'
    6) Click 'Save' on the 'General' screen
    A dialog will pop up asking: 'Overwrite current settings?'
    7) Click 'Yes'
    A new dialog will pop up reading: 'Changing skin'
    It will disapear, but CF still displays the 'General' screen and the 'Save' button will stay highlighted. From this point on, everything will be as described earlier.
    I tried it with music playing, music paused, music stopped with either a playlist loaded or not (by simply ejecting all playlists) and it happens everytime. Visualisation is set to display the cover art and I have deleted all other Visualisation files in the folder, because CF had a bad habbit of switching back to a vis when all I want is coverart. CF will eat 99% CPU while this happens. Sometimes other buttons on the 'General' screen stay responsive, sometimes not - but at all times I'm not able to leave the 'General' settings screen; it always crashes CF.
    I cannot reproduce this following the exact steps... Does it create an error.log file? If so please post or email it...
    note: Try to also remove all the plugins from the plugins folder and then re-create the issue... If that does not stop it then set your startup page to MAINPAGE and do not load Media, then try to reproduce it... Trying to narrow down where this could be... And it should be creating an error.log file...
    david
  3. #43
    ont
    ont is offline
    Oct 2003
    No it doesn't create an error log, but I think I nailed the bug down. It only happens if I use my custom skin. I just changed the skin to one shipped with CF and it behaved correctly. Exited CF, fired it up again and changed to my skin it loaded correctly. Did the steps reported and it happend again. The only thing I can think of is that there was some change in the skin system since RC1 because I created the skin using that version. I could send you the skin if you'd like to investigate it further.
  4. #44
    Then it would be something in my changeskin function I need to verify if the skin is properly formatted...
    that helps...
    There was one other user reporting this issue... What skin were you using?
    david
  5. #45
    ont
    ont is offline
    Oct 2003
    Well I modded the Onyx WS Night to fit scale to 800x600. I changed various png's and used the skin editor posted in this forum to edit the xml. I atached the xml to this post. I hope that this helps. If you need more information or files I'll gladly send them to you.
    Attached Files Attached Files
  6. #46
    May 2006
    Seattleish, WA
    Quote Originally Posted by justintime View Post
    I don't think it was necessary to put a NO GUI flag on the application setup dialogs...
    When you set up NON-GUI apps, you leave out the window name param
    Seconded!
    Updates..
    Quote Originally Posted by veetid View Post
    SAPI is setting your mic level at 50 based on how you trained your profile, do you have voice enabled?
    I doubled checked... I don't have voice enabled anywhere in CF. No prompts, not in Nav, no voice control.
    My startup location rights fine on 4 different machines and noone else has reported this...
    I have a repro, and it doesn't involve restarting CF.
    • Settings
    • General
    • Setup
    • RIGHT arrow
    • Startup location
    • Pick a plugin, not a function. "TRAFFIC" will show the bug
    • OK
    • Save
    • Yes
    • Go back to Setup (no restart required)
    • RIGHT arrow
    • Note "Startup location" is blank.
    :: Mark
  7. #47
    Quote Originally Posted by midiwall View Post
    Seconded!
    Updates..
    • Settings
    • General
    • Setup
    • RIGHT arrow
    • Startup location
    • OK
    • Save
    • Yes
    • RIGHT arrow
    non-GUI flag removed, no window name I assume non-GUI plugin...
    The MIC getting set to 50 might be because you have it set as your line-in device for XM or Radio... I set this level because if users have it too high and don't know to adjust it, which they can adjust later through the mixer, then the sound is distorted... I guess I should remeber where you set it and save it maybe... Is it causing an issue?
    You are right... I wasn't testing with a plugin/web link... I will get this fixed...
    david
  8. #48
    Jun 2005
    David nav searching is taken longer again in this release.
  9. #49
    VMS
    VMS is offline
    Low Bitrate VMS's Avatar
    Apr 2006
    I have one other person who has received this bug, I have to track it down... The only thing I changed was add that new visual... Try removing all the visuals from the visuals folder, back them of first of course, then try to reproduce as hard as you can...
    If it does not happen again then it's simply that new visual I added, hopefully... That is the most generic .NET error possible and leads me no where to find the solution, I hoping it's just the new visual I added...
    Let me know...
    david
    Not the visual, i've just deleted all the vis and still got the error, i think its in the skin.
    Vehicle Media Systems
    Australia Car PCs www.vmscarpc.com.au
  10. #50
    May 2006
    Seattleish, WA
    Thank you!
    Yes, it definitely is. THIS is the cause of my reported issues with the audio from (my) XM "doubling", i.e., I hear the direct playback from the XM receiver (via the MIC input) and the delayed playback from the WAV output.
    fwiw, it's happening on return from hibernate as well. i.e., not just on CF startup.
    :: Mark
  1. New Release Centrafuse 1.20
    By veetid in forum Centrafuse
    Last Post: 10-10-2007, 08:12 PM
  2. Centrafuse 1.6 Bugs
    By Mbai2 in forum CF Bug Reports
    Last Post: 05-10-2006, 11:30 AM
  3. Centrafuse 1.5 Bugs
    By veetid in forum CF Bug Reports
    Last Post: 01-14-2006, 08:03 PM
  4. Centrafuse 1.4 Bugs
    Last Post: 09-27-2005, 10:58 PM
  5. Centrafuse 1.3 Bugs
    By rickster in forum CF Bug Reports
    Last Post: 07-26-2005, 08:51 PM
