The one guy who fixed it was using an old skin... If you are using the default skins in RC3.1, those will not be the problem... If you try to use any non RC3 skin it will fail for sure...
david
david
david,
is there a posibility to let me know what I need to change in my skin's xml to make it compatible with rc3? I just don't want to completly rework the xml to fit every CF release, just so that this bug does not happen!
Just to be sure we're on the same page about this...
When you say "unmute", I'm thinking that you mean in the Windows mixer, right? If so, then yes. If there's some sort of a mute function within CF itself, then I don't know about it.![]()
:: Mark
basically when you set your XM line-in channel Centrafuse is suppose to mute it for you, so it wouldn't matter if it was at 50 or 0 or whatever... It's all about the recording section of the mixer, which I also set and auto select so I can record into the buffer and playback through Centrafuse...
This gives the pause/play/rewind and the ability to modify the XM sound with the EQ...
I guess it's not muting for you for some reason, it does on my M10000, but I have it on my list to look into...
I also think I found a way to speed up the XM channel changingI just have to setup all my XM hardware and get back into XM mode and get all those XM bugs knocked out...
david
My Line In is going to 50 when I go to XM and it is distorted. I am not getting doubling, just too loud. I have to go to the Mixer and turn down the line in and that fixes it, until I go back in to XM and the line in goes right back to 50 and the distortion is back.
97 Firebird 7" Lilliput Touch Screen
AMD Athlon 3800+ DSATX
Centrafuse RC5
PPC 6700 Sprint Phone w/Bluetooth
Bluetooth GPS
It most likely is... I do set the level for record when you use Radio or XM... I guess I should make this configurable or maybe remember what you set in the mixer...
Let me think on it...
david
Yeah make it remember what I set it on would be the best for me. That is the only problem that I am having. Keep up the good work David!
Centrafuse RC5
Bluetooth GPS
