Page 11 of 12 FirstFirst ... 23456789101112 LastLast
Results 101 to 110 of 114
Thread: Centrafuse RC4 Bugs
  1. #101
    Jun 2005
    Slovenia
    Quote Originally Posted by zerodb View Post
    Does anyone use S3 Suspend-to-RAM when leaving their car? I've started doing this and found that Centrafuse slows down MASSIVELY after suspend and resume. After a fresh reboot, it's quick and responsive, but button clicks are at least a full second delayed after being suspended. It appears to get worse after successive suspend-and-resume cycles. Closing CF and reopening it doesn't solve the problem, so it may be a Windows issue and not a CF one.
    I'm using S3 and haven't seen any of this. Probably one of your drivers, like David said.
    I'm seeing though that after S3 my touchscreen sometimes starts to react right-click-like (i.e. whenever I go to the desktop and press on one of the icons it acts like I've pressed the right mouse button). I have a feeling this only happens if I have CF enabled, that it works normally if I don't.
  2. #102
    Jun 2005
    Slovenia
    Quote Originally Posted by andro View Post
    And again, on the subject of crashing. I noticed today that in the middle of nowhere where surely there is no WLAN available, the connection sign was green (and when it crashed, the wlan manager said that there's no networks available). Soon after that, CF crashed. I'm really starting to think it's related to connectivity. I'll try to disable wlan altogether and see whether it still crashes.
    Does anybody that has got this problem also a similar (wlan-wise) config?
    Oh yes, again, nothing in error.log. Just old stuff from Oct 9 when it last crashed and I had to start it again, but nothing noteworthy.
    After that, I've disabled the WLAN (pulled it out alltogether). No crash since, so I bet it must be something in this area. David, help :-)
  3. #103
    Raw Wave
    Jun 2002
    Virginia
    Quote Originally Posted by theflygtiguy View Post
    1. i clicked on XM radio, and the xm did not play, the song titles did not come up and no sound was coming out.
    Have you double-checked that you've designated the correct com port # in setup of the XMPCR in CF? It will be the number of the port that says "USB Serial Port" in XP device manager.
    Though there are a couple of known issues with XM in CF, what you're describing is not one of them.
  4. #104
    May 2006
    Seattleish, WA
    Quote Originally Posted by kbreeden View Post
    For reference:
    Centrafuse Known Issues
    The double/triple tracking sounds familiar, but I hadn't heard it get faster & faster. I've had the random non-responsiveness happen as well, but it's pretty infrequent.
    David's supposedly focusing on XM issues this time, but considering all the other things that popped up (or are still broken) in RC4, I think we may get pushed down on the pile again.
    :: Mark
  5. #105
    SOS
    SOS is offline
    Jan 2005
    Quote Originally Posted by veetid View Post
    It would be in the settings.xml, make sure this file is not corrupted and still valid XML...
    both your visual and auto starting music should be working...
    david
    I can open the file in a browser and it shows XML, so it should be valid?
    As mentioned, this has never worked, even after total reinstall, set to start up in main menu. When i click media it loads the playlist and takes 1-2 seconds, so it looks like the entire plugin/module is not loaded on startup of CF.
    Deleted main.dat and ran a repair via the MSI installer. Still both problems.
    Deleted the settings file, started CF (changed to day skin, so I know it worked :-) ), still both problems.
    Disabled Visuals by clicking the thumbnail (any other way of disabling?), stop start CF. Still both problems
    Deleted the error log, started CF, started media, switched off visuals, return to main menu, shut down CF from main menu, started CF again, no music, went to media and music starts and visuals also start. No error log is created.
    /SOS/
    XP Pro, CF 2.0-newest| Pioneer HU with 7" flip-out (EQ, Surround)
    Epia V10000 + nVidia FX5200, Opus 150w, 7" Lilliput, DVD* SlotIn, Wavelan, Bluetooth, GPS, WebCams, DVB-T
  6. #106
    Sep 2005
    Pomona, CA
    I noticed something weird about the daytime Onyx skin: When I am using the Nav (Destinator) the top bar with all the buttons and the info about the GPS turns really small and is in the upper left hand corner of the map, and all the space it is supposed to occupy is black. If I put the Nav in full screen it is fine - if I use the night skin the full screen is messed up in this manner, but when not in full screen it is fine. Anyone else seen this?
    Carputer Progress:
    Re-do fabrication of screen [DONE]
    Add mini-USB and micro-USB power from M2-ATX [DONE]
    Teardown PC [100%]
    Add HDMI > VGA converter [0%]
  7. #107
    Newbie theflygtiguy's Avatar
    Sep 2006
    Bellevue, WA
    No, i have not tried that, but i'll see if i can get the XM playing with this.
    Thanks for the info and the link.
    Audi A8L
    CENTRAFUSE
    EN15000, 1g DDRII | 200g Media | Bluetooth
    Rear Camera | Dvd | Edge | Nav | Internet | XM
    www.mkippen.com
  8. #108
    VENDOR - Centrafuse veetid's Avatar
    Quote Originally Posted by fatejd View Post
    this was reported, looking into it...
    think it's just bad data entered into the XML file for that skin...
    david
  9. #109
    Sep 2005
    Pomona, CA
    david
    Coolio, thanks.
    Have you had a chance to look into adding the SHN codec to the player as well?
    Carputer Progress:
    Teardown PC [100%]
  10. #110
    I got this to happen to me once, but never again... Can you easily reproduce this problem? Is it only with the Onyx Day skin? Does it go away when you exit and startup the application again?
    david
  1. Centrafuse RC3.1 Bugs
    By veetid in forum CF Bug Reports
    Last Post: 10-06-2006, 06:11 PM
  2. Centrafuse RC4 Release Notes
    By veetid in forum Centrafuse
    Last Post: 09-29-2006, 04:27 PM
  3. Centrafuse 1.5 Bugs
    Last Post: 01-14-2006, 08:03 PM
  4. Centrafuse 1.4 Bugs
    Last Post: 09-27-2005, 10:58 PM
  5. Centrafuse 1.3 Bugs
    By rickster in forum CF Bug Reports
    Last Post: 07-26-2005, 08:51 PM
