Page 3 of 12 FirstFirst 123456789101112 LastLast
Results 21 to 30 of 114
Thread: Centrafuse RC4 Bugs
  1. #21
    Oct 2004
    Netherlands
    Installed RC4 on a winxp system (dutch) but with US time/date/language settings.
    1. GPS speed still doesn't really work (using metric mode) sometimes it just says 1 kph (when i'm doing 30) and lots of the times its about 20 kph off (destinator 3 and tomtom speeds are almost the same as my speedo!)
    navigation in the city/street mode on the "benelux" maps seems to work fine.
    edit and offtopic but i don't see anything about TMC in the future features.. is this scrapped or just very longterm?
    my destinator map resource down permanently
  2. #22
    FLAC ShawJohn's Avatar
    Aug 2004
    On the edge!
    can we please be able to completely remove unwanted modules such as satelite rario? I have no intentions of ever using it, yet I cannot remove it.
    Also sirrius, XM, Radio etc.
    Surely these modules are slowing things down a little when they aren't required?
    3D view still pretty much turns to 2d view when you zoom out
    Can CF be made to grab new windows that an embedded program may spawn? Then use the back arrow to go back to the embedded app from new window.
    John
  3. #23
    ont
    ont is offline
    Oct 2003
    I still have box like characters after the album title for some mp3's. Neither Winamp's, Foobar's nor the Windows ID3tag editor show these.
  4. #24
    VENDOR - Centrafuse veetid's Avatar
    Quote Originally Posted by DaKyy View Post
    I'm not sure if this is a known bug, but still here goes, again.
    I complained couple of days ago that after 3.1 update failed my mp3:s didn't automaticly do the next track procedure after the song ended. I noticed that it was because of certain MP3 files when it did that. They are variable bitrate MP3s. Centrafuse seems unable to calculate correct lenght of the VBR files as the bitrate changes constantly. When I setup CF to show how much is left of the song - It'll show for example when the song is almost at the end that there is still -1:12 left of the song. Then it just jumps to zero and doesn't go the next track.
    This was listed under things to look into... now I know what type of file is causing this, thanks...
    david
  5. #25
    Quote Originally Posted by Merzbow View Post
    Veetid, you can't be serious that you disabled the ability to use the microphone input on the primary sound card for voice? I haven't yet upgraded from RC2, where voice recognition works fine. I already have a very expensive external USB sound card with a very high-quality microphone attached. There is no way I'm going to shove more computer hardware in my car. If you disabled this to support radio or visualizations or whatnot, simply allow us to turn off that stuff (which I certainly don't use). This will be a deal-killer for me and certainly many customers, since there is no way I'm going to give up voice recognition on my front-end.
    USB microphones work great, so do bluetooth... I will look into it... The only reason it worked again in RC2 was because I accidently had some visualization code commented out...
    I could definetly add an option to disable visuals, radio, and XM completly...
    I will look for some workaround, but it's how I get the data to feed to the visual...
    david
  6. #26
    Quote Originally Posted by Shonky* View Post
    The Street/City method of entering a new destination still doesn't work. After selecting the street, right arrow, the city selector remains on the streets.
    You can't type using a regular keyboard - it jumps in the list only. Is that the "keyboard control doesn't work when you use web browser, navigation, or external application because they take over keyboard control" problem?
    When selecting "Go" it should use the currently selected destination rather than having to use right arrow
    eg. I use suburb/street -> enter suburb, right arrow, enter street, right arrow, select number, go OR right arrow. "go" ignores the selected number.
    I am using older Destinator Australian maps. Could that be the problem?
    street name issue works fine with the maps I have from Destinator, depends on your maps and if they are compatible and working...
    keyboard control will work, list views get focus automatically, hit <tab> and you will have control of the buttons again.
    GO does do this, something must be wrong... You can select just a City and hit GO, it will go to just that city, same with a street, except it will auto go to the next screen because it needs to know atleast the city for that street...
    david
  7. #27
    Quote Originally Posted by kASz View Post
    It is in the list, but when I type it it does not appear. I only can see the street when I look for it with the arrows.
    can you give me the map, city, and street so I can reproduce?
    I did use loop from beginging initially, too slow.. Then binary, which doesn't work correctly, then I wrote my own search this method.. Seems to work, but nothing the exact map, city, and street will let me see the error and fix it quickly...
    david
  8. #28
    Quote Originally Posted by chevyunger View Post
    Hi David,
    thanks for making it possible to sort favorites by distance.
    next problem is that the keyboard has no funktion in search address screen, only the osk works.
    thx
    Matthias
    hit <tab> to take focus away from the list view... When you go to any page with a list view I default the focus to the list view... You use <tab> to get out of this focus... hit it again and you will have focus on the main controls on the bottom, then again back to the list view, and so on...
    david
  9. #29
    Quote Originally Posted by Cirion View Post
    I'm not able to delete favorites. They do disappear, but when entering favorites again they reappear.
    is this with all favorites you add? for example add one with a new address, current destination, current location, and see which one you can't remove, or all of them...
    david
  10. #30
    Quote Originally Posted by GReeToZ View Post
    still talking about TMC... It's more on Destinator's end, nothing left for me to integrate really... I am working on it...
    Speed is a known constant issue... Their damn SDK can't seem to give me the right numbers or tell me what they are in...
    david
  1. Centrafuse RC3.1 Bugs
    By veetid in forum CF Bug Reports
    Last Post: 10-06-2006, 06:11 PM
  2. Centrafuse RC4 Release Notes
    By veetid in forum Centrafuse
    Last Post: 09-29-2006, 04:27 PM
  3. Centrafuse 1.5 Bugs
    Last Post: 01-14-2006, 08:03 PM
  4. Centrafuse 1.4 Bugs
    Last Post: 09-27-2005, 10:58 PM
  5. Centrafuse 1.3 Bugs
    By rickster in forum CF Bug Reports
    Last Post: 07-26-2005, 08:51 PM
