Update on the file playing...was a cbr file (192) that had both ID3v1 and ID3v2 enabled w/ info in both.
I also have the song not going to the next song issue...will check to see if its on a vbr file the next time it happens
I also have a 2nd bug re: playlists. When I go to create a playlist for a specific folder it says it creates fine, but it will error when I try to play it. Also if I go to view the list it shows empty (0/0). 8 have been able to create another list just fine. Further, if I try to delete this "bad" playlist it will error then too. I have attached the playlist for you to look at...I think it has something to do with the ID3 tag, but it works fine in winamp (the tags).
Another mug, when playing a video, CF crashes at the end of the video. I'll email you the error log. This is random, sometimes it will start the video again, but other times, it will just crash
Shell mode will not quit into explorer.
GPS speed is still wrong, searching however, seems faster and more accurate to the input.
Well they sort of work for the most part. I don't have any real choice since they are the ones I purchased for a PDA and are all that are available even as far as I know.
Does that mean I should not bother reporting any nav problems?
If I use the City/Street method, selecting a "city" i.e. suburb and then go to just get me to the suburb it says "could not calculate route". Instead I have to use right arrow and then go...
VMS: I haven't noticed any missing street names.
I just switched to RC4 from a much earlier version. I have set up my radio channels in the xml file for use with my radioextreme. When I go into the radio section and click on a number for my preset it switches to that channel but then about a second later it brings up the dialog to 'Enter station name'. Why does it do this every time I change radio stations?
Thatīs what I did, Windows and the Phone is working just fine, I can connect to the serial port manually no problems. As i wrote, PhoCo test program can talk to the phone, but no the wizard.
/SOS/
XP Pro, CF 2.0-newest| Pioneer HU with 7" flip-out (EQ, Surround)
Epia V10000 + nVidia FX5200, Opus 150w, 7" Lilliput, DVD* SlotIn, Wavelan, Bluetooth, GPS, WebCams, DVB-T
