Got this when trying to hibernate today...after hitting OK CF just closes.
I got that same message box as I tried if the DUN now works as it didn't with RC3 (the box just stayed on the screen after connection). I pressed the red button and... Well it didn't work (connected to internet ok) and the box stayed on the screen. However about 5 minutes of wait and that box appeared. After pressing ok CF closed. Restarted CF and everything was fine.
Hello all. I don't know if this is an issue with Centrafuse or with Phoco, but here it goes.
I have a smartphone (Windows Mobile 5) that connects to Centrafuse/Phoco through bluetooth no problem. The issue is when I go into Phone control through Centrafuse and pick an option like "Received Calls" or "Missed Calls" or "Dialed Calls" it shows the all the correct information except for the time.
The time it shows for each record is 7 hours later than what my phone shows. I live in Arizona which is -7 hours of GMT. So it looks like the Phone control in Centrafuse is pulling in GMT time.
My timezone is correctly set on the carPC and in Centrafuse. This isn't a big issue, but may be something you or the Phoco guys might want to look into.
Thanks!![]()
Skinning to go... VisualDesigner2!
You can download the latest version of the Adapter to fix that issue here (WM5) or here (WM 2003 SE).
Unpack it into the WinMobile\WCE500 folder (WinMobile folder for WM 2003 SE) then close the Adapter on the phone, rerun the Wizard and let it copy the Adapter once again.
