This has been fixed, I will release an update soon...I have my SE K800i connected via BT and serial, and this works just fine.
When going through the config wizard, i get all the way up to selecting preconfigured profiles, and I choose Sony Ericssson K800i and get the error: //Options/SonyEricsson New has an invalid token with the details attached at the bottom.
If I choose continue it looks like itīs working though, but :-)
Code:See the end of this message for details on invoking just-in-time (JIT) debugging instead of this dialog box. ************** Exception Text ************** System.Xml.XPath.XPathException: '//Options/SonyEricsson New' has an invalid token. at System.Xml.XPath.XPathParser.ParseXPathExpresion(String xpathExpresion) at System.Xml.XPath.XPathNavigator.Compile(String xpath) at System.Xml.XPath.XPathNavigator.Select(String xpath) at System.Xml.XmlNode.SelectSingleNode(String xpath) at PhoneCtlWizard.Form1.listBoxProfiles_SelectedIndexChanged(Object sender, EventArgs e) at System.Windows.Forms.ListBox.OnSelectedIndexChanged(EventArgs e) at System.Windows.Forms.ListBox.WmReflectCommand(Message& m) at System.Windows.Forms.ListBox.WndProc(Message& m) at System.Windows.Forms.ControlNativeWindow.OnMessage(Message& m) at System.Windows.Forms.ControlNativeWindow.WndProc(Message& m) at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam) ************** Loaded Assemblies ************** mscorlib Assembly Version: 1.0.5000.0 Win32 Version: 1.1.4322.2032 CodeBase: file:///c:/windows/microsoft.net/framework/v1.1.4322/mscorlib.dll ---------------------------------------- PhoneCtlWizard Assembly Version: 1.7.5.39208 Win32 Version: 1.7.5.39208 CodeBase: file:///C:/Program%20Files/Flux%20Media/Centrafuse/PhoneControl.NET/PhoneCtlWizard.exe ---------------------------------------- System.Windows.Forms Assembly Version: 1.0.5000.0 Win32 Version: 1.1.4322.2032 CodeBase: file:///c:/windows/assembly/gac/system.windows.forms/1.0.5000.0__b77a5c561934e089/system.windows.forms.dll ---------------------------------------- System Assembly Version: 1.0.5000.0 Win32 Version: 1.1.4322.2032 CodeBase: file:///c:/windows/assembly/gac/system/1.0.5000.0__b77a5c561934e089/system.dll ---------------------------------------- OpenNETCF.Desktop.Communication Assembly Version: 2.9.2455.20183 Win32 Version: 2.9.2455.20183 CodeBase: file:///C:/Program%20Files/Flux%20Media/Centrafuse/PhoneControl.NET/OpenNETCF.Desktop.Communication.DLL ---------------------------------------- System.Xml Assembly Version: 1.0.5000.0 Win32 Version: 1.1.4322.2032 CodeBase: file:///c:/windows/assembly/gac/system.xml/1.0.5000.0__b77a5c561934e089/system.xml.dll ---------------------------------------- System.Data Assembly Version: 1.0.5000.0 Win32 Version: 1.1.4322.2032 CodeBase: file:///c:/windows/assembly/gac/system.data/1.0.5000.0__b77a5c561934e089/system.data.dll ---------------------------------------- zBTHelper Assembly Version: 1.0.1.19907 Win32 Version: 1.0.1.19907 CodeBase: file:///C:/Program%20Files/Flux%20Media/Centrafuse/PhoneControl.NET/zBTHelper.DLL ---------------------------------------- System.Drawing Assembly Version: 1.0.5000.0 Win32 Version: 1.1.4322.2032 CodeBase: file:///c:/windows/assembly/gac/system.drawing/1.0.5000.0__b03f5f7f11d50a3a/system.drawing.dll ---------------------------------------- Infragistics.Win.v3.1 Assembly Version: 3.1.20041.15 Win32 Version: 3.1.20041.15 CodeBase: file:///C:/Program%20Files/Flux%20Media/Centrafuse/PhoneControl.NET/Infragistics.Win.v3.1.DLL ---------------------------------------- Infragistics.Shared.v3.1 Assembly Version: 3.1.20041.15 Win32 Version: 3.1.20041.15 CodeBase: file:///C:/Program%20Files/Flux%20Media/Centrafuse/PhoneControl.NET/Infragistics.Shared.v3.1.DLL ---------------------------------------- Infragistics.Win.UltraWinTabControl.v3.1 Assembly Version: 3.1.20041.15 Win32 Version: 3.1.20041.15 CodeBase: file:///C:/Program%20Files/Flux%20Media/Centrafuse/PhoneControl.NET/Infragistics.Win.UltraWinTabControl.v3.1.DLL ---------------------------------------- Infragistics.Win.Misc.v3.1 Assembly Version: 3.1.20041.15 Win32 Version: 3.1.20041.15 CodeBase: file:///C:/Program%20Files/Flux%20Media/Centrafuse/PhoneControl.NET/Infragistics.Win.Misc.v3.1.DLL ---------------------------------------- OpenNETCF.Net.Bluetooth Assembly Version: 1.4.50709.0 Win32 Version: 1.4.50709.0 CodeBase: file:///C:/Program%20Files/Flux%20Media/Centrafuse/PhoneControl.NET/OpenNETCF.Net.Bluetooth.DLL ---------------------------------------- Interop.BTSTACKSERVERLib Assembly Version: 1.0.0.0 Win32 Version: 1.0.0.0 CodeBase: file:///C:/Program%20Files/Flux%20Media/Centrafuse/PhoneControl.NET/Interop.BTSTACKSERVERLib.DLL ---------------------------------------- Accessibility Assembly Version: 1.0.5000.0 Win32 Version: 1.1.4322.573 CodeBase: file:///c:/windows/assembly/gac/accessibility/1.0.5000.0__b03f5f7f11d50a3a/accessibility.dll ---------------------------------------- ************** JIT Debugging ************** To enable just in time (JIT) debugging, the config file for this application or machine (machine.config) must have the jitDebugging value set in the system.windows.forms section. The application must also be compiled with debugging enabled. For example: <configuration> <system.windows.forms jitDebugging="true" /> </configuration> When JIT debugging is enabled, any unhandled exception will be sent to the JIT debugger registered on the machine rather than being handled by this dialog.
david
LinkBack URL
About LinkBacks
