Page 3 of 10 FirstFirst 12345678910 LastLast
Results 21 to 30 of 96
Thread: Centrafuse RC4.1 Bugs
  1. #21
    May 2006
    Seattleish, WA
    Quote Originally Posted by veetid View Post
    cannot reproduce this... can anyone else? Do you have phone enabled? Try not with XM...
    I have a 100% repro. I'm not using phone nor Destinator. I tried it with onboard WMA (repro), tried it with embedded XM (repro) then disabled embedded XM (device = NONE, port = NONE) and confirmed it happens with AIMEE as well.
    I'll play some more.
    Dunno what to tell ya' about the mixer control... Windows can get the levels to full mute.
    :: Mark
  2. #22
    Variable Bitrate bns2000's Avatar
    Nov 2004
    Russellville, AR
    Well I had to go back to rc4. RC4.1 wouldn't work on my rear speakers or sub. idk what you did but its weird. I mean the sliders don't work right at all. I move it up it goes up but nothing happens. I mean what ever you did to RC4 made my rear and sub work but now its like it was removed in 4.1 and screwed up in the mixer bad.
    CENTRAFUSE™ From Flux Media
    The Ultimate Infotainment Interface
    Download V1.20 from there site now!!!!
    Download the new 2.0 RC1 From here Linky
  3. #23
    ont
    ont is offline
    Oct 2003
    #1
    Forwarding to the next song takes around 1-2 seconds. In RC4 pressing on the next song button would play the next song imediatly, now it doesn't do anything for 1-2 seconds (doesn't react to key presses, no sound) and then plays the next song.
    #2
    This bug is there since RC1 and I've pointed it out everytime. This time it got even worse. You don't seem to filter the id3tag fields correctly it seems, because there is a square character behind the album name, in this version more albums are affected. Real showstopper! BTW: Neither foobar2k, itunes, wmp nor Winamp show these characters.
    I'll attach an image this time, so I hope it get's noticed!
  4. #24
    Sep 2005
    Pomona, CA
    Quote Originally Posted by ont View Post
    #2
    I notice this in RC4 for some song title tags, but I haven't seen it for any album tags. I figured it was my tags that were in error, but I never investigated.
    Carputer Progress:
    Re-do fabrication of screen [DONE]
    Add mini-USB and micro-USB power from M2-ATX [DONE]
    Teardown PC [100%]
    Add HDMI > VGA converter [0%]
  5. #25
    FLAC coucouillu's Avatar
    Nov 2004
    FRANCE
    I can't install 4.1
    I got this message "The system administrator configured the policy of your system to forbid this installation ".
    I have got this message on 2 different PC.
    This is the first time I got it. I have successfully instal RC3.
    EDIT: It seems that it is cause by a corrupted installer...
  6. #26
    ont
    ont is offline
    Oct 2003
    Quote Originally Posted by coucouillu View Post
    I can't install 4.1
    Maybe a bad download? I remember that I had that kind of error before with a different program. The fault was the downloadmanager I was using back then, it simply corrupted the file while downloading it. A redownload using the native download dialog fixed it for me!
  7. #27
    Dec 2005
    Tampa, FL
    I must say... Excellent Project
    I am having the same problem as "bns2000".
    1. My rear speakers and sub no longer work. Although they were fine the last 1-2 versions.
    2. When I tried my HQCT I hear the radio station playing but I can not change the channel or get any readouts. Seems like the USB connection is not setup correct. HQCT does work in RR on the same machine...
    3.a. During initial import of my songs (2000), it took more the twice as long.
    3.b. When I went into the media selector and chose that directory the initial spool up time(till I could listen to the songs) was 1-2 minutes.
    3.c. When I clicked the next button (media player, 2000 songs) with random selected I got a skin freeze of 1-2 minutes.
    TIA
    Hardware: VIA-SP13000, M2-ATX, Voom case, HQCT, Linksys WiFi, Bluetooth, 512MB, 80GB, Dynamix 706.
    Software: XP Pro (stripped), Drivers only, Road Runner, CentriFuse, EzSync
    99% done... [never completely finished... a continuing hobby]
  8. #28
    FLAC ShawJohn's Avatar
    Aug 2004
    On the edge!
    if that's 2000 tunes in one directory then I'm not suprised
  9. #29
    Aug 2004
    On the edge!
    my external apps won't work, buttons are blank. They show in the settings list but I cannot select them in the button actions list.
  10. #30
    May 2006
    Seattleish, WA
    Quote Originally Posted by ShawJohn View Post
    Did you delete ALL of the directory that CF RC4 was installed in before installing RC4.1? I've had very similar issues when I didn't...
    :: Mark
  1. Centrafuse RC4.1 Release Notes
    By veetid in forum Centrafuse
    Last Post: 10-19-2006, 04:32 PM
  2. Centrafuse RC3.1 Bugs
    By veetid in forum CF Bug Reports
    Last Post: 10-06-2006, 06:11 PM
  3. Centrafuse 1.5 Bugs
    Last Post: 01-14-2006, 08:03 PM
  4. Centrafuse 1.4 Bugs
    Last Post: 09-27-2005, 10:58 PM
  5. Centrafuse 1.3 Bugs
    By rickster in forum CF Bug Reports
    Last Post: 07-26-2005, 08:51 PM
