New one...
Browsing Media by Artist is a bit sideways because you're using "Artist" instead of "Album Artist". I consider this a bug and not a non-feature because if I'm looking for a compilation or a tribute album, I can't find it.
I'd suggest using "Artist" only if "Album Artist" isn't present.
:: Mark
What type of disc is in the CD drive? Is it CDA or WMA/MP3 data?
This concept (that of inserting a USB disk device with WMA/MP3 data on it) started working for me(*) at RC 4. But, I'm using a USB thumb drive and/or an iRiver H10 mounting as a HD. It sounds like CF may be getting confused if there's a USB based CD drive in the mix.
(*)fwiw, "working for me" is defined as "Plug H10 into USB port while CF is running. CF ignores the USB_INSERT notice and doesn't scan the device. I can then go to Media | Music Folder, see the USB device as a drive letter browse it that way".
:: Mark
I have updated the known issues thread....
Centrafuse Known Issues
david
I only get GPS lock failures when in Sirf mode, which I use as the Holux GR213 will do dead reconing and nav smoothing through hardware in sirf mode but apparently not in NMEA mode. In sirf the position on the map is sort of predictive based on speed and heading so more accurate at high speed.
When lock fails if I close CF and open SirfDemo, select source (com3 57600) and connect, it sees no satelites until I syncronise the gps & baud rate, it then scrolls through all the different speeds on the port and finishes with com3, 57600 :wack: Then it sees satellites.
Only seems to do this in Sirf mode though, any ideas why?
My Nissan 200SX @ Silverstone
NOW SADLY WRITTEN OFF!
My Car's spec list + pics
Stealth CarPC fab'ing...
I have got to bring up the need for a minimize button again... even one that is some sort of advanced option that can be disabled or enabled in settings. With the speed (or lack of) that CF opens, I can't be continually exiting CF entirely to do a few things that I need to do in windows.
I understand that CF is meant to skin windows entirely, and even be used as a system shell, but that minimize button would be a welcome addition for many users.
There was talk of making an autoit script, or even a plugin, but I can't imagine it would be that hard to integrate into the current code? I really don't have any idea though.
Sorry if this is the wrong place for this, too...
2002 Honda CR-V
Spent so far: $1105.90
...or even Listen to my music
