Page 8 of 10 FirstFirst 12345678910 LastLast
Results 71 to 80 of 96
Thread: Centrafuse RC4.1 Bugs
  1. #71
    Sep 2005
    Pomona, CA
    get the klite codec pack - I love it anyway...
    Carputer Progress:
    Re-do fabrication of screen [DONE]
    Add mini-USB and micro-USB power from M2-ATX [DONE]
    Teardown PC [100%]
    Add HDMI > VGA converter [0%]
  2. #72
    Jun 2006
    I'm having some problems with the radio, i'm not able to easily save the channels, the "saving box" won't always open when i hold the key for more than 5 secs. and when I play the visualisation in full screen in radio mode, i get the title of the last song played in the corner box. These are not important issues.. but have to be mentioned!
    thanks.. keep on the good work
    VIA EN15000 C7 // CTF700 7" Screen // Morex 3688 Black Case
    M2-ATX // 80GB HD
    DVD-RW // PowerMate
    Belkin Bluetooth V1.2 // Hauppauge WinTV FM
    Centrafuse RC5
    JBL GTO 75.4 520W // Pionneer Kevlar 260w Speakers
  3. #73
    May 2003
    Germany
    Quote Originally Posted by Lynsch View Post
    Sorry i dont have the Time to search this complete Forum. But there is a Bug in Navi. Searching for a Town in Germany "Röttenbach" or something else is not working with the Keyboard on the right. There is no ö, ü, ä
    And i cant write it in the Field shown in the left.
    Sorry for this post if this problem already is known.
    greets from germany
    You could add these to the keyboard layout.
    But I think it should work as in every other German Navi. o,a,u also show ö,ä,ü entrys.
  4. #74
    Registered User
    Feb 2006
    Berlin, Germany
    Quote Originally Posted by krog View Post
    No, they dont.
    you have to built a custom keyboard with german keys, what is very easy whit cf.
    but with my old german d3 map there is a problem with ö,ä,ü. sometimes the search dont find what you are looking for.
    eg searching "Köln" is a problem and "Köln" have to be there.
  5. #75
    VENDOR - Centrafuse veetid's Avatar
    I have updated the Known Issues Thread:
    Centrafuse Known Issues
    I have also added a RC4.2 Progress Report Thread:
    Centrafuse RC4.2 Release Notes
    Make sure I don't already have your issue listed or have it fixed...
    david
  6. #76
    Low Bitrate Gore-'s Avatar
    France
    Quote Originally Posted by tonysch View Post
    I must say... Excellent Project
    2. When I tried my HQCT I hear the radio station playing but I can not change the channel or get any readouts. Seems like the USB connection is not setup correct. HQCT does work in RR on the same machine...
    Exactly the same problem
  7. #77
    Variable Bitrate AlienEclipse's Avatar
    Jul 2003
    Dunedin - New Zealand
    Quote Originally Posted by ont View Post
    #1
    Forwarding to the next song takes around 1-2 seconds. In RC4 pressing on the next song button would play the next song imediatly, now it doesn't do anything for 1-2 seconds (doesn't react to key presses, no sound) and then plays the next song.
    #2
    This bug is there since RC1 and I've pointed it out everytime. This time it got even worse. You don't seem to filter the id3tag fields correctly it seems, because there is a square character behind the album name, in this version more albums are affected. Real showstopper! BTW: Neither foobar2k, itunes, wmp nor Winamp show these characters.
    I'll attach an image this time, so I hope it get's noticed!
    What were your mp3's created in. Centrafuse has never had a problem reading 15000+ mp3 that were created with EAC. Ive recently started rebuilding my mp3 collection from my CDs using itunes (coz its fast) and actually adding album art this time. I tested the latest version of Centrafuse with about 1200 of the new mp3 files and it only found 2 albums out of about 55. the first album is fine the second is just an "unkown album" which has the rest of the mp3 files which just lists the file names and not the actual tag info. I tried reimporting several times, each time CF reports it had imported all 1200 but still only shows 2 albums. Also i get the square at the end of the only album CF detected. There is a plus, Cf reads the album art fine! (so far)
    Edit: This could be related to known bug 3: check for "Album Artist" before Artist, if it is available when reading tags
    We are, will have and forever will be...
    But not tommorrow!
  8. #78
    FLAC Jahntassa's Avatar
    May 2005
    Conyers, GA
    Posting from the car... on RC4 and now a fresh install of RC4.1 (Uninstalled 4, deleted the dir, etc)
    After adding a D-Link DIR-450 EVDO Router to utilize my verizon card, CF throws up the error on the attached image. The Router is in its basic configuration except for the wireless encryption and the fact that it uses 192.168.41.0 as the network.
    This is the only thing i've changed. It happens after an 'amount of time', and I can restart CF normally each time. Nothing in the error log.
  9. #79
    Quote Originally Posted by Jahntassa View Post
    can you check the memory when this happens? It could be the memory leak that was causing this, which has already been found and fixed...
    Does it go away for sure when you remove the d-link?
    Try removing the weather plugin and web plugin, both internet related, and see if it goes away...
    david
  10. #80
    May 2005
    Conyers, GA
    Quote Originally Posted by veetid View Post
    david
    CF is using 137 Mb when this happens.
    I gotta unplug the D-Link and see what goes on. I've tried JUST running the weather plugin, and JUST the IE plugin..and it runs fine! But as soon as I open iGuidance (which is wrapped in SKINBedder and was added as an application in CF Settings), a few minutes later that error comes up. CF and iGuidance close, but SKINBedder still shows up on the taskbar.
    It might be iGuidance, but even if it is, why is CF closing??
  1. Centrafuse RC4.1 Release Notes
    By veetid in forum Centrafuse
    Last Post: 10-19-2006, 04:32 PM
  2. Centrafuse RC3.1 Bugs
    By veetid in forum CF Bug Reports
    Last Post: 10-06-2006, 06:11 PM
  3. Centrafuse 1.5 Bugs
    Last Post: 01-14-2006, 08:03 PM
  4. Centrafuse 1.4 Bugs
    Last Post: 09-27-2005, 10:58 PM
  5. Centrafuse 1.3 Bugs
    By rickster in forum CF Bug Reports
    Last Post: 07-26-2005, 08:51 PM
