Page 9 of 10 FirstFirst 12345678910 LastLast
Results 81 to 90 of 96
Thread: Centrafuse RC4.1 Bugs
  1. #81
    Low Bitrate Flappy's Avatar
    Jun 2004
    Netherlands
    When i play video's fullscreen, i takes about 30sec's tapping on the screen before controls pup up. I use a Sempron 3000+ with 512MB, so hardware speed can't be the issue.
    AsRock AM2 dual VGA
    AMD Sempron 3000+
    512MB DDR
    3,5" 80GB harddrive
    Liliput 7"
    TFT 15"
    M2-ATX
    0% [OOOOOOOO-] 100%
    My install
  2. #82
    VENDOR - Centrafuse veetid's Avatar
    Quote Originally Posted by Flappy View Post
    Might be your double click speed settings in your touch kit? does it do it when using a mouse?
    There were some improvments to the pulling up of the sliders in this upcoming release as well, I found some bad code...
    The CPU isn't spiked when you are trying is it? The video isn't stuttering is it?
    david
  3. #83
    Aug 2006
    another bug i noticed and i think it's carried on from RC4 as I noticed it then as well. When you've queued anything (either video/audio, playlist/non-playlist) in Shuffle mode it re-shuffles all over again when you come out of hibernation. So say you've got 5 tracks:
    1 *
    2 *
    3 *
    4 <- current track
    5
    (* denotes it's already been played).
    when you come out of hibernation it loses the previous shuffled tracks and:
    1 <- current track that is playing
    2 *
    3
    4 * (track that was playing)
    5
    hope that makes sense.
  4. #84
    Sep 2005
    Pomona, CA
    So, it plays a different song when it comes out of hibernation than it was when you went into hibernation?
    Carputer Progress:
    Re-do fabrication of screen [DONE]
    Add mini-USB and micro-USB power from M2-ATX [DONE]
    Teardown PC [100%]
    Add HDMI > VGA converter [0%]
  5. #85
    May 2006
    Seattleish, WA
    A new one... I just configured a new CarPC from scratch and found a new issue with RC 4.1. I'm getting a string of font errors:
    11/21/2006 4:24:50 PM
    Font 'Century Gothic' doesn't support style 'Regular'.
    at System.Drawing.Font.Initialize(FontFamily family, Single emSize, FontStyle style, GraphicsUnit unit, Byte gdiCharSet, Boolean gdiVerticalFont)
    at System.Drawing.Font..ctor(String familyName, Single emSize, FontStyle style, GraphicsUnit unit, Byte gdiCharSet)
    at centrafuse.Plugins.CFPlugin.setlabelskin(String whichlbl, MouseEventHandler clickEvent, MouseEventHandler downEvent)
    I get 6 of these each time I start CF.
    :: Mark
  6. #86
    Quote Originally Posted by midiwall View Post
    You must have changed the skin.xml file and changed the font style... Are you using the default skin?
    david
  7. #87
    May 2006
    Seattleish, WA
    Quote Originally Posted by veetid View Post
    Nope, Nope and Yeup. This happened straight out of the box. Fresh install of XP SP2, .NET 1.1, CF RC4.1.
    The new box isn't fired up at the moment, but I figure I'm looking to see if all the <FONTSTYLE> tags flipped to "Regular"? And then to fix this I should kick them to "Bold"?
    I'll fire it up in a bit and let you know what I see....
    :: Mark
  8. #88
    Aug 2006
    fatejd - no it plays the same song but say if you were playing a whole album it will re-shuffle all the album songs again so some of the songs that you already played before hibernation are back in the mix again when you start playing after hibernation. make sense? in other words, shuffle only shuffles properly when you play a whole selection before you hibernate.
  9. #89
    May 2006
    Seattleish, WA
    I'm on the box now...
    The skin is set to Onyx WS. All of the hundreds of FONT data elements in both WS Day and WS Night show:
    <FONTNAME>Century Gothic</FONTNAME>
    <FONTSTYLE>Bold</FONTSTYLE>
    If I look at the available fonts from the control panel FONTS applet, I do NOT see "Century Gothic", but I see "Century Gothic Bold". If I open WRITE, I see a choice for "Century Gothic", and if I highlight a section of text, I see no difference between "Bold" and "not Bold". (the font itself definitely looks bold)
    fwiw, this new box is an M10000, using the on-board video. All drivers are the latest available from the Via website.
    :: Mark
  10. #90
    Variable Bitrate AlienEclipse's Avatar
    Jul 2003
    Dunedin - New Zealand
    David,
    when is the advanced graphics mode coming back? Because it makes Centrafuse that much better.
    I'm going to add a nVidia FX5200 based PCI graphics card to my M10000 board, coz the onboard graphics is seriously lacking.
    We are, will have and forever will be...
    But not tommorrow!
  1. Centrafuse RC4.1 Release Notes
    By veetid in forum Centrafuse
    Last Post: 10-19-2006, 04:32 PM
  2. Centrafuse RC3.1 Bugs
    By veetid in forum CF Bug Reports
    Last Post: 10-06-2006, 06:11 PM
  3. Centrafuse 1.5 Bugs
    Last Post: 01-14-2006, 08:03 PM
  4. Centrafuse 1.4 Bugs
    Last Post: 09-27-2005, 10:58 PM
  5. Centrafuse 1.3 Bugs
    By rickster in forum CF Bug Reports
    Last Post: 07-26-2005, 08:51 PM
