no idea??!![]()
Hi!
i hope someone can help me!
Please!!![]()
whenever i resume my laptop from Hibernation i have no Sound in Centrafuse... (if i switch to Windows while centrafuse is running.. i can listen to mp3s with Winamp... therefore i don't think its a driver problem...)
After restarting centrafuse (not Windows!!!) i get sound.
what could cause this problem??? i don't want to restart centrafuse everytime i resume from hibernate...![]()
Configuration:
CarPC: Laptop IBM Thinkpad T23
OS: Windows XP Pro SP2
Centrafuse: RC4.1 0.99
Soundcard: USB Terratec Aureon 5.1 (connected through PCMCIA USB2.0 Card)
Thank you very much!
Barmy
no idea??!![]()
Do you get ANY sound from CF at all? Button clicks? XM? FM? Movies? CD source? Noise???
Start an MP3 playing then head for the CF mixer. Move each of the sliders from MIN to MAX and note if any of them change the symptoms. i.e., you can hear noise from the card, you can now hear MP3s but not XM, etc.
Do this with both the first and the third mixer panels (I forget their names and I'm not in front of CF right now).
What do you have to do to get audio back? You mentioned restarting CF, but is there anything else? Unplug/Plug the Terratec adapter? Unplug/Plug the PCMCIA card?
:: Mark
thank you for replying!
no nothing.. no button clicks... simply nothing!
I played with all Sliders in CF Mixer... but that is not the problem..
To get the audio back i have to exit centrafuse and start it again...
nothing else....
While starting CF there is a process called "Initialising Audio"....
what is done in this part of the startup? I think this is needed to get the audio back!!
Hey again Barmy... I'm out of ideas, you'll need David (Mr. CentraFuse) to see this. David's pretty good about reading all of these posts, but he's been a bit off on participating in a discussion. You may want to repost your initial post here over in the "official" bugs thread:
Centrafuse RC4.1 Bugs
My gut feel is that CF may be losing track of the audio driver instance after a hibernate, but again, that'll be for David to look into.
You might also want to check and see if there's a "error.log" file in the CF main directory. If so, see if there's anything in there that tracks with the restore from hibernate timeline.
:: Mark
not sure, can't reproduce on any machine I have and this has not been reported before by anyone and no one else seems to have this problem...
note: must be something with the USB Terratec Aureon 5.1 device, never seen or used one...
david
Hi!
I have the same problem now.
Moste Time when i use hibernation, there is no problem in Windows, because the windows sound is there after hibernation, but not in CF. When there is no sound after hibernation, i only have to restart CF, and everithing works fine.
I have no problem, when i hibernate windows without CF (Desktop only), or Winamp is playing.
Only when i hibernate in CF, there is the problem with the sound.
Greetings![]()
US Cars @ www.rollingthunder.at.tf
