Originally Posted by
ahew
Hi all,
Just noticed 2 "bugs" and maybe a feature you may want to think about adding:
Bugs:
1. When you go into Library, then select your picture folder (or sub-folder) you can't click on the "+" to Queue the pictures and then save as a playlist. Says something like "Can't load folder" (sorry can't exactly remember the error). Not sure if this was a feature or not to stop people from being able to save pictures as a playlist. However, you can press "Play" to view the files once you've loaded the folder to view the slideshow, you can go back to "Playlist" and click on Queue and actually save the queued files as a playlist. So you can still save the images as a playlist using this method. When you load this playlist it doesn't give you the slideshow option and there's no way to skip between pictures.
2. When you scroll up or down a selection of pictures in the main screen it takes ages to go up and down the list. I can literally count the seconds (5-8seconds) before it skips to the next row of images. This has to be fixed.
Feature:
3. When viewing pictures will there be a way to change the slideshow time as well as a manual way where you can skip through the pictures backwards and forwards?
